Can I replace the cheap plastic oil drain plug with a steel one? - Bimmerfest - BMW Forums
Old 06-11-2019, 03:04 PM
Rick Lee Rick Lee is offline
Mein Auto: Porsches, BMW's
I don't think I've ever changed the oil in Mrs. Lee's X1 without destroying the drain plug, since I like to dump the oil when the engine is piping hot. Of course, the hex wrench just twists in the groove and strips it. I don't have a spare one handy now and wanted to match it to a steel one. Anyone know the diameter and thread pitch or have a link for one I can order?
2014 BMW X1
2015 BMW S1000R
2017 BMW 330ix wagon
Old 06-12-2019, 08:10 AM
QSilver7's Avatar
QSilver7 QSilver7 is offline
Mein Auto: 2006 X5 4.4/2013 650ix GC
I would recommend looking up the part your need in one of the online part databases...then shop using the correct 11 digit BMW part nbr. You can usually type "BMW xx xx x xxx xxx" (where x=the actual bmw part nbr) into a google search box and find lots of vendors selling that item or a comparable item like a steel or aluminum version of the plug.
If you're not familiar with any online sites...here's 3 of my favs...feel free to save/bookmark the sites for future reference. All 3 sites just require that you enter the last 7 digits of your VIN (the diagrams & part nbrs will be vehicle specific)...or select generically selecting based on the chassis/model/model year/engine/etc that you have:
  1. http://bmwfans.info/parts-catalog/
  2. https://www.realoem.com/bmw/enUS/select
  3. https://bimmercat.com/
Q {BMW CCA Member #191509}
2006 E53 X5 4.4i (Sterling Gray) 12/05 mfg date <<~>> 2013 F06 650ix Gran Coupe` (Black Sapphire) 1/13 mfg date
(SOLD)
97 740iL (Arctic Silver) <<~>> 99 540iT (Orient Blue) <<~>> 95 525IT (Alpine White)
https://www.bimmerforums.com/forum/attachment.php?attachmentid=637911&d=1538398374&thumb=1&stc=1
Old 06-12-2019, 08:14 AM
Yes, I have been buying car parts online since the beginning. But, because this car has a plastic oil pan and plastic drain plug, I'm wondering if it's safe to replace the OEM plug with a steel one. I don't know if the pan's female threads are plastic or steel or if that matters. All I know is that these plastic drain plugs are ridiculous.
2014 BMW X1
2015 BMW S1000R
Old 06-12-2019, 02:49 PM
Tony828 Tony828 is offline
Mein Auto: 2014 X1
I've been changing the oil on my 2014 X1 sDrive using the hex wrench. I, also, change oil when it's real hot to get all potential sludge out. Are you sure you're using the right size hex (Metric & SE)? I never had a problem with mine. The size of the female threads may not match a standard steel one; besides, using a steel plug on a plastic pan is NOT a good idea.
Old 06-12-2019, 04:58 PM
Yes, definitely using the right size. And since the oil change kits come with a new drain plug, probably because BMW expects them to not last through an oil change, I even double check fitment on the new plug before I start.
2014 BMW X1
2015 BMW S1000R
