Where is passenger compartment aerial located? - Bimmerfest - BMW Forums
Old 05-23-2019, 02:50 PM
Profess0r Profess0r is offline
Mein Auto:
So i've recently changed the dashboard on my F32 and the keyless start decided to stop working. Everytime i want to start the ignition/engine, i have to hold the key up to the steering wheel column.
I ran ISTA+ and it came up with fault 804107 : Aeriel in passenger compartment, front: line disconnection
Now i'm not sure where to look to diagnose the problem. Is it behind the glovebox? I assume I've not hooked it back to where it's supposed to be, or I've shorted the aerial. Any advice would be appreciated.
Old 05-23-2019, 03:06 PM
pshovest pshovest is offline
BMW CCA 69606
Mein Auto: '15 435i '10 535i '08 X5
https://www.newtis.info/tisv2/a/en/f...erial/BmQ2ygZi
Expose the ring antenna and trace wires.
Not clear how ISTA can distinguish between line disconnection and antenna failure
Old 05-23-2019, 03:14 PM
Mein Auto:
thanks for the response, i'll have a look behind the steering wheel cover.
Also i'd like to add that, i never disengaged the battery when i done the dashboard change. In hindsight it was a really bad idea, so i'm guessing that had something to do with the antenna not working.
