Battery replacement. - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > M3 & M4 > F80/F82/F83 M3 and M4 (2015 - Current)
F80 BMW M3 sedan, F82 BMW M4 coupe and F83 M4 convertible forum. This 5th generation M3 and all new M4 features a 3.0 liter twin turbo engine (engine code S55) 425hp and 406lbs of torque! Heavy use of light weight materials makes this generation lighter and faster then the outgoing E9x M3.
Old 07-10-2020, 04:20 PM
Leekay07 Leekay07 is offline
Mein Auto: MY12 550I,MY09 X5.
Hi,
My 2015 battery ran low this week after a 420 mile drive. I think its a problem with the demands of my aftermarket speakers and my need to run 2 phones from dead and the nav and radar detector. But anyway dealer said it needs to be replaced. My question is do we have an alternative (aftermarket battery supplier) that is known to work. Giving BMW 2350 to replace it seems just OTT
If you like customer service. Don't look beyond a BMW.
Old 07-12-2020, 09:16 PM
ard ard is offline
Resident Curmudgeon
Edit: this assumes it isn't a weird li-Ion battery...
Alignment here: The Definitive Alignment Thread
OE is Original Equipment aka 'BMW Original Parts' aka 'What you buy at the BMW dealer with a BMW label'
OEM is Original Equipment Manufacturer... EITHER the company that made the OE part or.... A part this is identical to the OE part, but is sold by the OEM under their own label
OEM is not what BMW sells
http://www.bimmerzone.com/category/T...ricks_OEM.html
https://www.turnermotorsport.com/t-OEvsOEM
Old 07-13-2020, 12:40 PM
Technic's Avatar
Technic Technic is offline
Mein Auto: 2017 M3
Originally Posted by Leekay07 View Post
Hi,
Dealer is charging full MSRP ($1946) and ~2hrs of labor (~$150/hr).
There is no aftermarket equivalent for this Li-ion battery as it is tied to the IBS system of the ECU for monitoring and charging.
Save $800 by getting it yourself in here and code it if you know -otherwise pay a coder to register the battery to your car: https://www.getbmwparts.com/oem-part...ry-61218047221
This battery should last much longer than 5 years, you should check alternator condition as this battery is mosly charged when decelerating or when the ECU detects excessive low charge condition. If you are playing music or accessories a lot while not driving then you may have shot the battery without even noticing.
Old 07-13-2020, 01:21 PM
ard ard is offline
Resident Curmudgeon
Kinda thought that was the case.
Seems the low water mark on price may be 1200 ish? If you shop hard enough.
Id lean on BMW and the dealer for a goodwill. Although if youve already agreed/bought into "its my fault" then not so much. I recall they could goodwill up to a year past the 4 yr warranty, no?
Old 07-13-2020, 02:38 PM
Doug Huffman's Avatar
Doug Huffman Doug Huffman is online now
Nuclear engineer
That is not so. The integral battery charge controller circuitry supplants and replaces the function of the Intelligent Battery Sensor - IBS. Li-ion batteries have integrated BCS.
Old 07-18-2020, 04:34 AM
Still waiting for the dealer to install my battery in the mean time my battery is reporting 12.57v I have not charged it for 9 days. But my car still starts first time and it still spewing out codes for everything from Pedestrian detection not working, Rear locking diff malfunction, Active suspension fault, Crash avoidance fault, ABS sensor fault.
List goes on but yet everything electronically including nav radio. Work no issues no low battery warnings or anything.
Old 07-25-2020, 07:54 AM
So I gave the dealer some crap told them that they are just picking the easy target and that none of the codes show it as being the battery. They now diagnosed it as a bad left rear speed sensor.
Old 07-27-2020, 03:59 PM
ard ard is offline
Resident Curmudgeon
Well that is certainly a different tune....
