2012 650i air conditioning fan issue - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 6 Series > F12 / F13 (2012 - 2018)
The all new 3rd generation 6 series coupe (F13) and convertible (F12) forum. The F06 BMW 6 Series Gran Coupe forum is here
Old 07-08-2020, 07:30 AM
dgfla dgfla is offline
Mein Auto:
hello...A/C is blowing cold but the fan will slow down and turn off and then about 20 sec later it will ramp back on. this will repeat itself after about a minute or two. any thoughts on this, sound familiar?
not a daily driver car and only has 28k...
any help on this would be much appreciated...thank you
Old 07-08-2020, 10:35 AM
645/333's Avatar
645/333 645/333 is offline
Michael
Have tried it in both hot and cold positions, I appreciate putting heat in the car would be no fun but you could see how the fan reacts??? Have you any check control messages???
Old 07-08-2020, 11:31 AM
Mein Auto:
Michael, thanks for the reply, haven't tried the heat but will give it a shot, not sure i have ever used the heat as I live in Florida but will give it go to see if that changes any behavior. I did turn of the a/c and it did the same thing. not sure what the relationship of the fan is to the a/c & compressor or if it is independent.
thank you again..
Old 07-08-2020, 11:40 AM
645/333's Avatar
Michael
There is a complete set of interactions with the Climate system, could also be you are low on coolant given as you said you live in Florida (having never used the heater sometimes a quick recycling helps long term) have you had the system recharged at any time?? it should be done every 4 years in average climate, in your hot climate perhaps 2-3 years. If I remember correctly low A/C coolant can cause issues, it is amazing how many people never think of it in terms of maintenance.
Old 07-08-2020, 01:12 PM
Mein Auto:
Michael.
I do take the car in annually to the BMW dealer for service, not sure if A/C coolant is part of their inspection but I am fairly certain that this has not come up as something they added during these inspections. thanks for your input...
Old 07-08-2020, 01:31 PM
645/333's Avatar
Michael
The A/C at least here in the UK is not included in any servicing, but they do offer a separate service, however many don't bother as I said some think it goes on forever, in fact many turn it off thinking they can save fuel, they don't realise that not using the A/C leads to very expensive repairs, but hey they save 2 mpg !!!!!
Old 07-13-2020, 03:51 AM
PROEASY PROEASY is offline
Mein Auto: F800 GSA
Had this happen on my F10 535.. First replaced the resistor on the blower motor under the hood ($50) as this is the most common cause, did not fix. Then replaced the blower motor ($150) and that fixed it. Took me perhaps 2.5 hours first time to get blower motor asssembly out. 2nd time was the charm perhaps 1 hour once I knew my way around the parts under the hood. See my post in F10 on tricks to speed up the process or pm me
Paul
Old 07-13-2020, 06:03 PM
Mein Auto:
thanks Paul, will dig into hopefully this weekend. much appreciate the info. thank you
