Left hand dipped beam failure - Headlight Issues with new bulb on 2010 E70 - Bimmerfest - BMW Forums
Old 07-13-2020, 06:06 AM
kapheen kapheen is offline
Mein Auto:
Hi All,
I've got a 2010 X5 E70 that is having issues after replacing the front left bulb. (I thought it blew - seems it didnt) . I checked to see if the new bulb was faulty with the right side and all is OK there. The old bulb is actually working fine also.
No matter what - the front left will not turn on. There is bugger all room behind there to acurately see what is going on.
Any advice? Could it be a fuse or worse?
Cheers.
Old 07-13-2020, 06:35 AM
Gary214 Gary214 is offline
Mein Auto: 2011 X5 50i M-Sport
I hard speed bump must have dislodged a loose connector. If you can't access it, get it to any car mechanic . I myself had similar issues and got all the bulbs replaced at the same time as a preventative measure if they were never replaced. The beams became brighter.
Old 07-13-2020, 06:40 AM
Doug Huffman's Avatar
Doug Huffman Doug Huffman is online now
Nuclear engineer
Worse.. Read about the FRM and its function.
Old 07-13-2020, 06:14 PM
paramedic1079 paramedic1079 is offline
Mein Auto: 2011 X5 35i M-sport
Originally Posted by kapheen View Post
Hi All,
Cheers.
I had a similar issue with my 2011. Turns out it was a faulty shutter mechanism and the entire headlight needed to be replaced to the tune of 3k...needless to say I was over the car at that point and sold it.
Old 07-13-2020, 06:48 PM
ard ard is offline
Resident Curmudgeon
Is the ballast good? These are HID bulbs with a ballast, correct?
Alignment here: The Definitive Alignment Thread
OE is Original Equipment aka 'BMW Original Parts' aka 'What you buy at the BMW dealer with a BMW label'
OEM is Original Equipment Manufacturer... EITHER the company that made the OE part or.... A part this is identical to the OE part, but is sold by the OEM under their own label
OEM is not what BMW sells
http://www.bimmerzone.com/category/T...ricks_OEM.html
https://www.turnermotorsport.com/t-OEvsOEM
Old 07-14-2020, 03:43 AM
Mein Auto:
Thanks All.
All other lights work - as do the windows etc... Just the front left hand side.
Car is booked back into the auto electrician - hopefully he'll identify what it is. He has already seen the car once with the same issue where he repaired some of the wiresheilding which had melted. They are standard H7 bulbs (not Xenon).
Hopefully it's just a wiring harness or something... not the FRM. I would expect more issues with the car if it was the FRM. The shutter mechanism does not sound good ...
Will let you know.
dipped beam failure, headlight, headlight bulbs
