P0205 code with check engine light on. - Bimmerfest - BMW Forums
Old 03-16-2014, 05:53 PM
charruatibe charruatibe is offline
Mein Auto: 1997 528i, 2001 325i
1997 528i. P0205 code with check engine light on. Car misfires when accelerated, especially up hills. What should I check/replace?
thank you in advance!
Old 03-16-2014, 07:22 PM
bartelbe's Avatar
bartelbe bartelbe is offline
Mein Auto: 2xe39,e34,e32,e36
Cylinder #5 injector circuit malfunction/open. Try swapping the injector to another location and see if the fault moves.
Old 03-17-2014, 06:25 AM
Are the injectors easy to remove and swap? Also which is #5?
Old 03-17-2014, 10:42 AM
bartelbe's Avatar
The task is fairly easy for a diy'er. You would be exposed the fuel so precautions should be taken. The injectors go in order from front of engine to rear so start at the first one and count in too #5. You only have #6 so should be that hard to figure out. Of course you did ask so this may be better left to a pro. One word of advice if you decided to diy bleed the fuel pressure from the rail.
Old 03-17-2014, 01:45 PM
edjack edjack is online now
Mein Auto: '97 540i 6 speed
http://www.obd-codes.com/p0205
Old 03-17-2014, 01:58 PM
Thank you very much!
