4x4 dsc malfunction on x5 3.0 2009 - Bimmerfest - BMW Forums
Old 10-14-2017, 07:25 PM
jayatl jayatl is offline
Mein Auto: x5 3.0
Every morning I get a high voltage battery drain message...car rides fine...should I buy a new battery
Sent from my SM-G950U using Bimmerfest mobile app
Old 10-14-2017, 08:12 PM
ard ard is offline
Resident Curmudgeon
Huh.
Title says "4x4 dsc malfunction on x5 3.0 2009"
yet your post has zero discussion of any errors, malfunctions, etc...only that you have a 'high battery drain message" (not 'VOLTAGE', correct?)
Sure, buy a battery.
OEM is not what BMW sells
Old 10-14-2017, 08:14 PM
Mein Auto: x5 3.0
My bad I'm mad n tired lol..the 4x4 dsc message comes up
Is it because of the battery?
I did the wheel turn to the right and left. The light stays on and message still up...need help
Old 10-14-2017, 08:15 PM
Mein Auto: x5 3.0
No codes
Old 10-15-2017, 04:36 AM
Doug Huffman's Avatar
Nuclear engineer
Troubleshooting high closed-circuit current.
No. High drain warnings are not caused by the battery, but by an uncontrolled load on the battery while the car is OFF. A drain >80 mA in an E70 will trip the warning.
newTIS.info beta
Home / BMW E70 X5 xDrive35d SAV / Repair Manuals and Technical Data / 61 General vehicle electrical system / 61 20 Battery /
Closed-circuit current measurement
https://www.newtis.info/tisv2/a/en/e...attery/YDj5gs8
Old 10-15-2017, 08:09 AM
RPsX5d RPsX5d is offline
Mein Auto: X5 35d, MY2011 150,000 mi
OP - given your June 2017 join date (newbie), let me suggest a few things that might help you get some useful information/suggestion from this forum . . .
  • You write "No codes" - does that mean you actually scanned for fault codes and it returned zero codes (seriously doubt it!) . . . OR . . . did you mean besides the 4x4 iDrive message, you are not seeing any other messages?
  • If you did scan for codes, which scanner did you use? Carly (specific to BMW)?
  • What specific code(s) did you read?
  • You indicate your car is MY2009 - is it still on the factory-original battery? Are you the original owner? If the battery was replaced, when was it replaced - documentation from the previous owner?
  • You indicate it is an X5 3.0 - gas / diesel? I think you meant 3.0i, gas.
  • Is anything plugged into the car overnight? e.g. the WiFi/Bluetooth dongle plugged into the OBD II port (drains battery even when the car has shut down and is in full sleep mode)
  • This is a WAG . . . Do you have the "Comfort Access" (Option 322)? If you have this option - does any of the outside door handles feel warm to touch? If yes, that might be your problem.
Answer these questions and you may get suggestions that you can act on.
Yes, even on this forum, as with everything else - garbage in garbage out!
Old 10-15-2017, 11:38 AM
ard ard is offline
Resident Curmudgeon
Welp, I was going to ignore and wait for some 'self help'...
But how old IS the current battery? Doncha think that might be a useful factoid?
Old 10-15-2017, 11:53 AM
Mein Auto: x5 3.0
Replaced a year ago
Mein Auto: x5 3.0
Crank amps at 835. Should be 900
Old 10-15-2017, 12:53 PM
Nuclear engineer
Clearly, to this engineer, the voltage is too high!
Old 10-15-2017, 12:55 PM
Mein Auto: x5 3.0
But I get high battery drain
Old 10-15-2017, 03:26 PM
ard ard is offline
Resident Curmudgeon
Replaced a year ago
Likely you have some kid of parasitic drain in your electric system that is draining the battery.
A one year old battery should not need replacing.
That would be my first guess.
Is your driving pattern very short drives? Do you hang out in the garage playing tunes and detailing the car with doors open? These can lead to electric issues....
