Car put itself in park mode would not drive - Bimmerfest - BMW Forums
Old 05-23-2019, 07:43 AM
bimmerbingo bimmerbingo is offline
Mein Auto: 2016 X6 50i
I was parked on an inclined driveway and realized my parking was shoddy so put it in reverse and car put itself back in park once I hit the gas, said secure vehicle against rolling. I tried this several times, eventually I got to the base of the driveway but once my rear wheels the flat surface I heard a machine gun grinding noise sound coming from the back... the transmission?
I turned off the car and let it sit for a minute or so and was able to drive up the driveway again but am really starting to worry now. Luckily I have extended warranty on it but I don't trust it anymore.
Could it have been a safety feature because I didn't put my seatbelt on while backing off? I did put my seatbelt on when I climbed up the driway the second time so I thinking that is likely the case.
Is the transmission toast now, should I have it checked? Had the car for almost 4 years and ran flawless.
2016 X6 50i M-Sport (mine), x-drive, CPO, alpine white
2015 435i M-Sport (mine), x-drive, CPO, sapphire black metallic, MPPK, MPBK, MPE
2015 X5 50i M-Sport (hers), x-drive, CPO, carbon black metallic
2015 328i M-Sport (hers), x-drive, new, alpine white
2007 328i (mine), rwd, used, silver
Old 05-23-2019, 08:13 AM
tex2670's Avatar
tex2670 tex2670 is offline
You Don't Need to Know
Mein Auto: '14 328xi Sport Line
It has nothing to do with your seat belt.
Did you open your door to check your positioning while you were backing up? It won't let you do that--the car will do exactly what you are describing. (or was your door just not fully closed?)
2014 328i xDrive | Black Sapphire / Black Red Dakota | Sport Line | Premium Pkg | Lighting Pkg | Cold Weather Pkg | Driver Assistance | Nav | Sport Automatic Transmission
Old 05-23-2019, 08:52 AM
Hmm, yeah now that you mention it I think it's likely it wasn't fully closed. Hopefully i didn't break anything.
Old 05-24-2019, 05:46 AM
Elk Elk is offline
Mein Auto: ~
The car is working as designed.
As I recall, you can drive with the door open with the seat belt on if you need to be able to see through the open door.
It is unlikely you hurt anything but, if so, I suspect the damage would be to the parking pawl.
