Bottom coolant hose 2013 X5 - Bimmerfest - BMW Forums
Old 07-10-2020, 07:46 PM
mdocesar mdocesar is offline
Mein Auto:
I am changing most of the hoses/cooling system in my 2013 X5; however, I came across a problem. The hose that we took off from my vehicle is not the same hose that the dealership has, has anyone had this issue? everything looks the same except that it has an extra outlet/nip, please see the pic attached, hope someone can shed some light. I have researched and the hose that has the nip is supposed to be the original part to my vehicle?? Can I get a hose like the one I took out w/o the extra nip? SOS!!
Old 07-10-2020, 09:13 PM
ard ard is offline
Resident Curmudgeon
Seem to recall there was a change in OE replacement parts, someone posted about this. Not sure this is the part, but maybe it gives you something to search around.... someone posted this already
Alignment here: The Definitive Alignment Thread
OE is Original Equipment aka 'BMW Original Parts' aka 'What you buy at the BMW dealer with a BMW label'
OEM is Original Equipment Manufacturer... EITHER the company that made the OE part or.... A part this is identical to the OE part, but is sold by the OEM under their own label
OEM is not what BMW sells
http://www.bimmerzone.com/category/T...ricks_OEM.html
https://www.turnermotorsport.com/t-OEvsOEM
Old 07-11-2020, 03:45 AM
Doug Huffman's Avatar
Doug Huffman Doug Huffman is offline
Nuclear engineer
Location: Washington Island, Wisconsin, thru Death's Door
Mein Auto: CPO2012 X5 35d M57(E70)
Check part numbers at RealOEM.com which also has line drawings of some parts essential features and occasional photographs. We need to know which of the engines you have.
Scepticism and Animal Faith (1923)
Scepticism is the chastity of the intellect, and it is shameful to surrender it too soon or to the first comer: there is nobility in preserving it coolly and proudly through long youth, until at last, in the ripeness of instinct and discretion, it can be safely exchanged for fidelity and happiness.
(The Works of George Santayana p. 65)
Eschew eristical argumentation. I am responsible for what I write, not for your understanding of it.
Old 07-12-2020, 10:13 PM
ard ard is offline
Resident Curmudgeon
This it??
https://xoutpost.com/bmw-sav-forums/...-question.html
Old 07-13-2020, 05:48 PM
smassey321 smassey321 is offline
Mein Auto: 09 X5d, 06 325i, 06 330i
Good find ARD. I think OP got an old stock hose. The part number is the same for both. 2013 won't have the sensor right? I think they got rid of that in 2007.
