Valve adjustment video... - Bimmerfest - BMW Forums
E34 (1989 - 1995)
Old 07-07-2019, 06:38 PM
Radian's Avatar
Radian Radian is offline
Mein Auto: '91 535i 5-spd
Fresh from the editing room:
Good food, good people, good times.
Old 07-11-2019, 10:10 PM
skuhlke skuhlke is online now
Mein Auto: E34 535i Touring
Great video and production. I donít have an M30, but if was done for an M50 engine this would be a great reference
Sent from my iPhone using Bimmerfest mobile app
Old 07-13-2019, 03:17 PM
rav31 rav31 is offline
Mein Auto: 2001 540i/6 Tisilver/gray
@ radian....good video, nice job. Just curious; Bentley shows placing the feeler gauge between lifter eccentric 'wheel' & valve tip. You set it between lifter & cam. Why? Is one better than the other? I have always measure between wheel & valve. Also, I liked the way you used the open end wrench & torque wrench to set torque. I just used my 'torque hand'! Very clean top end too. How many miles on it?
Here's another link for the procedure. Gale's Page
I also use a remote start on my "old' timing light & pins #11 & 14 on diagnostic socket to turn engine. I permanently marked them so I know which they are.
BMW CCA #132981 Tarheel Chapter,
Old Yesterday, 06:28 AM
Monsignor's Avatar
BMW CCA Memeber #445389
Mein Auto: Sig
M50's use hydraulic lifters, which are self adjusting. If you are hearing the tappet (ticking), you may want to bleed your lifters, so start with the following:
- Check your oil level and quality. Should not be low or overfilled. Rubbing the oil between your fingers should be slick and smooth, no granular bits or stickiness. Light gold/brown color is good.
- Run your M50 until it is at operating temp
- Then hold the revs at 2500-3000 RPM for 3 minutes
- Let idle for 15-20 seconds
The tappet should be gone; if it isn't, repeat the process (I wouldn't do it more than 3 times). If it still doesn't work, then change your oil with the expensive, real good, BMW recommended, BMW provided, oil. then try bleeding it.
1995 525iA 250k mi
2003 350Z 91k mi - SOLD
1984 733i/5 105k mi
2014 F-150 45k mi
Instagram: @Titan_E34
Snapchat: Titan_E34
