2004 bmw x3 3.0L - Bimmerfest - BMW Forums
Old 07-11-2019, 12:58 PM
Marvn Marvn is offline
Mein Auto:
2004 bmw x3 3.0L
Check engine light on showing p0171 and p0174. I replace plugs,fuel filter, disa valve, oxgen sensors but the code keeps coming back. Not sure what else to do.HELP
Old 07-11-2019, 09:12 PM
hornhospital's Avatar
D'oh, You Kids!
Mein Auto: E24x2,E36x2,E30x1, F150
Welcome to Bimmerfest!
I moved your posting to the E83 forum (X3, 2004-2010) so you can get model-specific help.
Quotes to live by:
Ken Kanne, Silverhill, AL, Bimmerfest Site Moderator
BMW-CCA #441426
1993 325is M3 clone"Ashlyn"; 1993 325is "Elvira"; 1985 635CSi "Katja"; 1984 633CSi "Sylvia"; 1987 325is "Odette";1995 318is"Bebe"
Old 07-12-2019, 04:09 AM
BMWaufKS BMWaufKS is offline
Mein Auto: 2008 X3
1) Clean the MAF, and replace the air filter (if neither are new)
2) Get a BMW-specific code reader such as the Creator C310; there's plenty of double-secret codes.
3) Do a smoke-test to look for vacuum leaks. I hear a very common one on M54s is a cracked intake boot, so if you are very-able you may proactively want to remove, clean, and inspect it carefully for cracks.
Others with M54s will hopefully give you more ideas.
P.S. Soon, make a signature file, for your future posts, with basic info about your X3. See below for an example.
Since 1/2016, restoring a
2008 BMW X3 M-Sport, N52, automatic ("#1")
Modifications:
All stock except dashcam
Since 3/2017, also restoring a
2008 BMW X3 base-model, N52, automatic ("#2")
Modifications:
Dashcam, cargo cover, cargo mat
Old 07-12-2019, 08:51 AM
jeepo23 jeepo23 is online now
Mein Auto: 2008 X3, 6 Speed
Are those not vacuum leak codes?
Old 07-12-2019, 04:14 PM
Mein Auto:
I change intake gasket trottle body gasket air filter pcv system replaced.
Also do a smoke test no leak was found.
Am also experiencing rough idle and rpm Serge.
Old 07-12-2019, 05:13 PM
dukedkt442 dukedkt442 is online now
Mein Auto: X3, 442, S15, F150
Very first thing I'd look at is the rubber bellows in the air intake; M54 is notorious for them. Both banks lean supports that idea. Valve cover gasket is another vacuum leak source. It doesn't seem to be misfiring so you can eliminate misfires as a lean source.
Old 07-12-2019, 06:49 PM
Mein Auto:
Valve cover gasket seems nice and dry
Old 07-12-2019, 11:55 PM
dynagroove dynagroove is online now
Mein Auto:
90% sure you have a vacuum leak somewhere. I purchased a 2004 X3 3.0L last year and had the same codes. There are multiple places that your motor can leak from. I'm going to tell you what I did. I replaced all soft parts on the top end: valve cover gasket + grommets, intake boot, entire CCV system, dip stick tube o-ring, dip stick o-rings, DISA valve rebuild + gasket, throttle body gasket, intake manifold gasket, FI gaskets, vacuum lines, vacuum plugs, other parts I'm sure I'm forgetting. I did a bunch of other work while I was in there, but that's what I did to address the vacuum leak.
Get a scanner. You can get OBD Fusion for $10 for your phone and a $20 LE BT adapter - that's all you'll need for this job. There is a ridiculous amount of information out there on how to fix P0171 & P0174. Spend some time searching and you'll find everything you need.
Old Today, 07:39 AM
legalfee's Avatar
legalfee legalfee is offline
Mein Auto: 2004 X3 2.5i 5AT
Old Today, 09:14 AM
codog2 codog2 is offline
Mein Auto: 5
I've gotten that code at least three times on my 2005 (200k). First two times - cleaned MAF and it went away. Last time (6 month ago) - needed to replace CCV valve. At the time I was also getting the occasional huge plume of smoke at start up, occasional erratic idle.
Old Today, 02:50 PM
Mein Auto:
I did all that but the code still coming back. Am going to change the dip stick oring seal next.
