BMW X1 warning. - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > X Series > X1 F48 (2016 - current)
Second generation F48 BMW X1 builds on the success of it's predecessor. Increases in power, interior and cargo space keep it a leader in the small SUV field.
Old 11-24-2017, 01:39 AM
amircod77 amircod77 is offline
Mein Auto: BMW X1 2016
BMW X1 warning.
My cars has been giving me a warning lately telling me to secure against rulling.
Not sure what im doing wrong. Its my first car.
X1 2016.
Sent from my LG-H990 using Tapatalk
Old 11-24-2017, 11:14 AM
Ridin'Dirty's Avatar
Ridin'Dirty Ridin'Dirty is offline
'17 X1 - Rooster Cruisin'
Mein Auto: '93 "Beemer" R100r
"Rulling" or do you mean rolling? If it is the latter, this warning is suggesting that you apply the parking brake.
Old 11-24-2017, 11:15 AM
Rolling probably. Cant remember .
Old 11-24-2017, 11:29 AM
From a little research here on Bimmerfest, one possible explanation is as follows: "The Secure Against Rolling alert comes up if you put the transmission into Neutral and take your foot off the brake". Could that been the situation when you saw this message? Another possibility is that you may have moved the car with the door open OR have the transmission in neutral, unhook the seatbelt and get out of the car with the engine running.
Old 11-24-2017, 11:30 AM
Probably.
It only happened this morning.
Im sure its not that important.
Im just worried cause its my first car.
Old 11-24-2017, 11:43 AM
I totally understand...6 months into ownership here and I still have my nose in the owners manual at least once a week.
Old 11-24-2017, 12:38 PM
IIDX IIDX is offline
Mein Auto: X1
It's likely not happening when the car is in park, should be one of the instances that the others mentioned. If you are an incline and put the car in park, it will automatically apply the parking brake.
Old 11-25-2017, 09:01 AM
DDGator's Avatar
DDGator DDGator is offline
Mein Auto: 2015 528i M-Sport
I see this message when the car is in gear and the door is open (or not quite latched).
Nothing to worry about.
DDGator
328i - Alpine White/Dakota Black/Sport Line (PC delivery in May 2013)
528i - Carbon Black/Mocha/M-Sport (ED pick-up was 7/11/15)
Old 08-12-2019, 03:56 PM
rahuljha rahuljha is offline
Mein Auto:
X1 2016.
Did the issue resolve? I too am having the same issue with my 2016 BMW X1. It does not affect the drivability but im concerned since its asking me to take it for service. Were you able to get this fixed? Thanks
Old 12-09-2019, 12:19 PM
miguel_x1 miguel_x1 is offline
Mein Auto:
Same issue with BMW X1 Sdrive 2.0 2017
Hi,
I took the car for service and the dealer sent it back with that warning message. It says something like this "Secure vehicle with parking brake when stationary..."
the msg is displayed when the car is started and when is turned off.
During this week, i will take it to service to check what is wrong.
pictures:
https://ibb.co/9cqLSb7
https://ibb.co/gzPY8FH
This is from Chile, BMW X1 Sdrive 2.0 2017 with 40.000 kms
Regards
Miguel
Old 12-11-2019, 11:04 PM
Mein Auto: X1
The shifter interlock has failed. You probably can hear it clicking when the car is on, and in park. Press on the brake pedal, you can feel and hear the solenoid clicking through the shifter.
There's some kind of defect with so many failing. Mine failed at about 40k miles and was replaced under warranty.
It won't affect driveability. It's meant to prevent you from shifting from park into gear without pressing on the brake pedal.
Old 12-12-2019, 04:26 AM
Mein Auto:
Hi IIDX,
I took the car to service and they told me the same, that the shifter interlock has failed. The service is going to replace the item under warranty.
Thanks.
