Alignment pin adjust - Bimmerfest - BMW Forums
Old 07-04-2017, 04:23 PM
alexqkama's Avatar
alexqkama alexqkama is offline
Mein Auto: 2008 328i
how to remove the alignment pin on the front struts to gain some positive camper, The camper is -2.2 and need to be -1. according to Sears which could not do the right wheel and claimed that did not have the tool to remove the pin......
Old 07-04-2017, 05:43 PM
CALWATERBOY DUE CALWATERBOY DUE is offline
Banned
Mein Auto: 09 E93 335i somewhat mod
Set your Google to E90 remove strut alignment pin
If you got -2.2 Camber [camper's almost right] she oughtta handle great and you got no alignment pins. What exactly's the deal again?
And....did you mention Sears? DUDE! We simply do NOT go to Sears. No, no, no, no, no. We go to a reputable Indy specializing in BMW's or failing that, we go to.....the dealer....pic of typical SA greeting BMW driver is below:
Old 07-04-2017, 06:08 PM
FLBimmer FLBimmer is offline
RLTW
Mein Auto: 2013 LMB 335is
If you are at -2.2 camber and you still have the pins in and obviously no camber plates then you have much bigger issues to deal with.
Sent from my LG-H810 using Bimmerfest mobile app
2013 LMB 335is |MHD custom tune | Full M3 DCT drivetrain-M3 GTS flash-M3 GWS-KOMBI-DSC/SZL conversion | IG @ clustersandcoding
Old 07-04-2017, 07:41 PM
F10-N52 F10-N52 is offline
Banned
Mein Auto: 2011 528i RWD
Agreed, that doesn't sound right at all.
-2.2 is extremely excessive for street use unless you corner like you're on a race track.
And like calwaterboy said, sears for an alignment? On a BMW? Why??
Old 07-05-2017, 09:03 PM
alexqkama's Avatar
OK guys, I did not want to say it, but the car had a minor accident. I do not think taking the car to a "reputable Indy" would change the outcome......
My question is: would I be able to change the camper from -2.2 to -1 if I remove the pin??
Old 07-05-2017, 11:23 PM
Banned
Prob not - don't bother - find what's bent/broken; fix that instead.
Dude!
Old 07-05-2017, 11:24 PM
Banned
Also, trust me, your car has no camper.
Old 07-06-2017, 10:34 AM
RLTW
You pull the pin to give you more CAMBER, not less. Something is bent or out of whack. With the pin in you should be within factory spec which is under -.5. There's very little positive camber adjustment and the only way to increase negative camber is to use M3 arms, pull the pin, and use camber plates which is all going in the opposite direction that you need to go.
