X5M 21'' winter tires set up - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > X3 M, X5 M, X6 M, Z3 M & Z4 M > F85 X5 M and F86 X6 M (2016 - Current)
The BMW X5 M and X6 M are high-performance derivative of the X5 and X6. Introduced at the 2014 LA Auto Show and appearing in dealerships in 2015. Both modeles are powered by BMW's S63tu twin turbo charged V8 making 567 HP and 553 lb-ft of torque, the most power for any BMW xDrive vehicle.
Old 06-15-2018, 09:33 AM
cocon cocon is offline
Mein Auto: bmw
Hey guys I am having a hard time finding winter tires in 21'' for X5M. Any inputs will be appreciated
Old 06-16-2018, 07:23 AM
moutso moutso is offline
Mein Auto: 2018 X6M
Not sure if you're the same person I just responded to on another forum. In my opinion don't settle for 20". Get 21", you can just swap the tires and use the same rims. The Yoko 21" winter tires are amazing. Don't be discouraged, they aren't even out yet. Just call Tire Rack. Should be in stock shortly. One of the biggest reasons you got your car is because how amazing the 21" tires look...won't look as good with the 20". Just be patient!
Pick attached with my Yoko 21".
Old 06-16-2018, 10:02 PM
Mein Auto: bmw
I opted for 21''. What are you running on the fronts since those are not available in 285/35/21? 295 maybe? if so any rubbing?
Spoke to Tirerack they will release 285 for the fronts this fall so I will be getting those for the winter set up!
Old 06-17-2018, 06:20 AM
Mein Auto: 2018 X6M
Wait till they are available in the Fall. I got the same exact size as the summer tires your car comes with. Fit perfectly on my bmw rims. I think you can order them starting anyday now. Just keep calling Tire Rack. Don't deviate from the same size of your stock/summer tires.
On my OLD x6m I did that and the rim stuck out on the tire a little and was always getting dinged.
Just be patient
Old 08-06-2018, 03:46 AM
matzaman matzaman is offline
Mein Auto: 2012 BMW X5 35d
Are you looking to have the car look good or perform well in the winter? It's been pretty well proven that low sidewall winters are a bad choice for winter performance. You'd be better off with a different size rim and tire package. Plus, winter driving will ruin your "summer" rims.
I tried what you're suggesting on my e70 and the rims wound up pitted from the salt and the car felt slippery in the New England snow.
On my f15 I went with a dedicated bmw rim and snow/ice in a smaller diameter (bigger sidewall) and the car was a tank.
Old 08-10-2018, 09:49 AM
Kief's Avatar
Kief Kief is offline
Mein Auto: 2018 F80 ///M3 ZCP
Thanks for sharing the 285 Yokos will be available.
I picked up my X5M last week, which came equipped with the black 612M, which I'm not a really big fan of, so I elected to use them for my winter setup. I purchased the silver 612M as my summer setup. I'm really looking forward to these 21" Yoko winters, as they come in the same stock summer sizes, and they are relatively cheap!! Hope they don't discontinue them, otherwise we are only left with the very expensive Pirelli RFT!
2018--F85///X5M
2018--G01 X3 M40i*
2018--F80///M3 ZCP Tanzanite
2017--F-Type Coupe R*
2017--F80 ///M3 ZCP*
2016--F-Type Coupe R*
2015--F15 X535i*
2015--F82 ///M4 [ED 6/26/14]*
2015--V60 Polestar (#62:80)*
2012--E92 335is*
2011--E70 X5d*
2011--E89 Z435is*
2009--E89 Z435i*
2008--E92 335i [ED 2/23/08]*
2007--MkV GTI*
2006--R53 Cooper S (JCW) 6MT*
2006--E90 330i*
2005--E83 X3*
2004--E83 X3*
2003--E46 325Ci*
*retired
Old 10-02-2019, 10:44 AM
graymatr graymatr is offline
M5
Mein Auto: 2016 BMW X5M
Did you spray tint the tail lights?
Old 11-29-2019, 09:57 AM
Zielinski292 Zielinski292 is offline
Mein Auto:
I have a set of Blizzaks with rims and factory BMW tire pressure monitors. around 5k miles total as I had a 3 mile commute to work daily. Located in Mass. Used on a 16' x5m with plenty of clearance.
