Modification Guide - Bimmerfest - BMW Forums
Closed Thread
Old 06-01-2017, 12:13 AM
F10-N52 F10-N52 is offline
Banned
Mein Auto: 2011 528i RWD
Modification Guide
So you have your new BMW, and obviously you want to mod it. First You must decide what you are looking for (along with many other considerations.) now this bit is important. Your average, factory spec BMW far exceeds the capabilities of your average driver in the road. thoroughly learn the limits of your vehicle Before deciding you want more.
To be very generic and broad, there is:
-power
-handling
-cosmetics
Power: Something like a downpipe and ecu tune is my recommenstion. Catbacks are a very expensive way to get sound with not much power gains. Unless you got nothing better to spend your money on get the downpioe instead. Now If you want to go all out, you get upgraded turbos. But generally an Intercooler, downpipe, chargepipe, ecu tune and high flow exhaust system will satisfy just about any enthusiast out there. Don't get an intake.
Handling: this is a more complex subject - let's start in this order. The first place one should start is by light rims and non runflat, performance tires. Next you address things like a camber adjustment (which will get rid of the factory understeer inducing setup) then suspension. Coilovers are great, but another good option is a performance strut/spring setup like bilstein b8 sport and and Eibach lowering springs. Depending on your driving habits, a limited slip differential will make the difference between a good and great handling BMW, yet for others it's just an expensive mod that many will not properly make use of. LAST, after performance suspension comes performance sway bars. If you're going all out track then youll also want bushings. If you just want good sound without breaking the bank I suggest a muffler upgrade. Unless you're 16 years old and don't care, keep your resonator (it is there for a reason)
Now, for cosmetic this is obviously a subjective task. My opinion is keep the looks of the car proportionate to its power and overall performance, and please keep things tasteful. I won't get into detail on that because IMO performance should be addressed first.
Old 06-01-2017, 03:02 AM
Eagle11's Avatar
Eagle11 Eagle11 is offline
Mein Auto: 2017 330i
Having just leased a 2017 330i, my list is the following.
Power: Will go with a plug and play about $400 for about +30hp.
Handling: lighter rims is a start, however, the cost is not the best way to go, Set of springs for about $250, then another $200 installed then another $200 for alignment. For a good set of light weight rims you are looking at about $1200, then $800 for tires. I'm going for a set of springs on my car, it has 18' which I'm find with. Car needs to be a little lower too much distance between tire and fender.
Have thought about getting a plug and play AMP for the sound system.
2017 330i, 475, KCL3, ZDA, ZPP, 2A5, 494, 4GA, 609, 6CP BMS JB tune and Many Coded goodies
2016 328xi GT, A86, LCOM, ZDA, ZDH, ZLP, ZPP, ZTP, 494, 5AC, 5DF, 5DL, BMS Stage 1, Many coded goodies. ED 8-28-2015 Gone
Old 06-01-2017, 05:51 AM
mbanks21 mbanks21 is offline
Mein Auto: 335i
What's the point of this thread?
Old 06-01-2017, 06:04 AM
khammack khammack is offline
Warning - Thin Air
Mein Auto: 2002 M Roadster/2014 435i
Originally Posted by F10-N52 View Post
... Your average, factory spec BMW far exceeds the capabilities of your average driver in the road. thoroughly learn the limits of your vehicle Before deciding you want more. ...
Number one on your list should be "Thoroughly learn your limits by taking some drivers training before making any performance modes.".
How many threads have you seen about some yahoo getting into a car that exceeds their skills and making a mess of the car, themselves or things around them?
This should really be a requirement before anyone drives on public roads because over and under estimating your skills and/or the limits of your car are the cause of most issues on the road.
2014 435i M-Sport, Mineral Gray, Black Dakota Leather, Driver Assistance Pkg, Prem Pkg, Tech Pkg, 8 Speed Sport AT, Heated Front Seats, Active Cruise Control, BMW MPPK w/MPE, BMW Limited Slip Diff, BBS CH Wheels.
2002 M Roadster, Steel Gray Metailic, Gray Nappa Leather, Black Soft Top, Steel Gray Metailic Hard Top, TC Kline Double Adj Shocks with H&R Springs, Stromung Exhaust, SSR Type C Wheels.
Old 06-01-2017, 06:13 AM
Closem Joe Closem Joe is offline
Mein Auto: locally
Amen Brother!
Old 06-01-2017, 06:33 AM
John MS John MS is offline
Mein Auto: 2014 Glacier Silver 328i
Originally Posted by closem joe View Post
amen brother!
+2
Old 06-01-2017, 08:53 AM
bear-avhistory's Avatar
2020 Z4 M40i
Mein Auto: 2020 Z4 M40i
Kevin
CURRENT:
2020 Z4 M40i
2019 Chevy Suburban 4X4 RST 420BHP
2013 BMW 135is JB4 convt 6MT
2009 Yamaha V-Star
1998 Ford Ranger 4X4 Splash 5MT
1965 COBRA 550BHP FORD Racing COYOTE TKO-600
FFR Cobra Mk-IV COYOTE 5MT Build Thread
480 WHP of BURBBLES
I LOVE THE SMELL OF BURNT 100 IN THE MORNING
Old 06-01-2017, 09:37 AM
Orient330iNYC's Avatar
Orient330iNYC Orient330iNYC is offline
Flying monkey herder
Mein Auto: Daihatsu Terrios
and what was the point of opening the same thread across multiple forums?
Past: 2001 330i ZSP/ZPP/Step
Past: 2004 S60R 6MT Sport
Past: 2013 335i 6MT ZMM/ZDH/ZTP/3AG/494/508
Past: 2016 F34 335i xDrive ZCW/ZDA/ZDH/ZTP/ZMP/2V5/5DL
Present: 2019 G01 M40i ZDA/2VF/ZPP/ZPX/688/3AC
Old 06-01-2017, 09:40 AM
Banned
You need performance struts to match your lowering springs. The springs by themselves won't result in optimal ride/handling.
Old 06-01-2017, 09:42 AM
Banned
You're very right, and I hope people use their judgement and choose to learn the limits safely. But I've learned the limits of my vehicle on the streets (it's a 528i, the limits are not that high) just like many of my friends did. Is it the best idea? Probably not. Can you do it safely on an empty street? If you practise responsibility I don't see why not.
Old 06-01-2017, 10:25 AM
Eagle11's Avatar
Only if you are going to race your car, but if you don't plan on racing then springs are good enough for street driving and occasional track days.
Old 06-01-2017, 10:28 AM
Mein Auto: 335i
Please don't encourage him
Old 06-01-2017, 10:36 AM
Eagle11's Avatar
Why not, it's fun and I'm bored.
Old 06-01-2017, 11:09 AM
xxthe_remedyxx xxthe_remedyxx is offline
Mein Auto: 2014 320i
What I'm getting from this thread:
Don't modify leased vehicles.
Old 06-01-2017, 11:16 AM
Banned
Not true. You want to always avoid lowering springs unless you already have performance struts. Do your research.
Banned
So how did your resonator delete turn out?
Old 06-01-2017, 11:27 AM
Mein Auto: 335i
Everyone that hears it loves it as do all the members I encourage to do it. How's your NA 5 series working out?
Old 06-01-2017, 01:27 PM
Banned
Alright man, if you like the sound with a resonator delete I can't complain. You did what you liked best to you're exhaust and that's the end of it. Honedtly, I like my 528i a lot. I modded the exhaust and it honestly sounds really good. The engine is responsive and torquey enough to rip through tiny traffic openings and it sounds amazing. The RWD handling is stellar. Heavy car but looks and drives great. I didn't expect this much from a 528i to be honest.
https://youtu.be/Q6mOXna3dx8
Old 06-01-2017, 01:28 PM
2020 Z4 M40i
Outside of never learning how to drive properly, khammack's advice, way too many people screw up a perfectly good car with hard core race parts that have no place on a street car.
Its the old case of following the cool guys with monkey see monkey do instead of actually understanding what they are doing.
Kevin
CURRENT:
2020 Z4 M40i
2009 Yamaha V-Star
480 WHP of BURBBLES
Old 06-01-2017, 03:26 PM
Banned
Yup... have seen this before myself. First you should learn the limits of your car in stock form. If you're not responsible enough to do so on the street, you take performance driving classes
Old 06-01-2017, 08:34 PM
Eagle11's Avatar
Dude I guess 20 years of Road racing doesn't give me any creditably on suspension set up.
Old 06-01-2017, 08:35 PM
Eagle11's Avatar
I agree to a point, but I doubt installing springs falls under the same category as maybe taking a 320i and dumping 15k into and trying to go as fast as a 340i.
Old 06-01-2017, 11:12 PM
LRW70's Avatar
LRW70 LRW70 is offline
Mein Auto: F30 340i & 328iM Sport
outside of never learning how to drive properly, khammack's advice, way too many people screw up a perfectly good car with hard core race parts that have no place on a street car.
+1
Things aren't always as they seem...
Lou W
BMWCCA Member 526239
Old 06-02-2017, 09:48 AM
Banned
Performance lowering springs compress your factory struts too much. Your average street strut is not designed to be compressed this much. It will wear out quicker since it has to work harder (move more) in order to compress. A quick google search of lowering springs and you'll find what I am talking about. For example, bilstein makes these HD b6 struts (not high performance) and they specifically mention that your warranty will be void if you put lowering springs on because they are designed to be used with normal length springs. If you M performance suspension from the factory or something along those lines then you're fine. But otherwise handling, ride quality and overall strut wear would be improved if you have something like the bilstein b8 sport struts to complement the aggressive springs. I also recommend Eibach or ACS springs over H&R.
  #25
Old 06-02-2017, 10:47 AM
Mein Auto: 335i
Come on man, didn't you google "shocks" before you opened your mouth? Geez!
Closed Thread
