I was driving one day and it stuttered and shut off. Now the car won't start it barely cranks. It's getting fuel, has a new battery, everything still works inside It just doesn't start. I even took the valve cover off to see it it was the chain and guides but they look fine to me the chains not loose or anything. I'm lost on what it could be.
Well it does turn over just very weak. This is why I had changed the battery because I thought It would be battery. But the car stuttered and turned off which I don***8217;t think would have anything to do with starter. But I***8217;ll give it a look
If starter and battery are good, then the next thing to check will be fuel supply/fuel pump. How many miles? And is it N26 in PZEV state, or confirmed as N20? Is there any CEL/fault code?
Yes it a n20 and I had checked the fuel by pullin a line and priming it and gas shoots out. So I got fuel. Just to add on I am on bootmod3 so idk if it can be that. Mileage is 109k
Related Threads
BimmerFest BMW Forum
11.4M posts
754.1K members
Since 2001
