07 525xi drivetrain noise advice - Bimmerfest - BMW Forums
Old 12-02-2016, 04:40 PM
hubcap hubcap is offline
Mein Auto: 2007 525xi
Hi All,
Have 101k trouble free miles on my auto 07 525xi and have kept up with maintenance recommended here on the forum.
Last 500 miles a noise started from bottom of engine. Originally thought it was wheel bearing but noise is only there when engine under load/accelerating, it disappears when coasting or I place it in neutral on highway. Its a growl/rumble from low end of engine, increases as you accelerate.
Took into indy, no codes, no issues with drvesafts, or bearings so they recommended a transmission fluid changed and new pan, car is shifting a little smoother but same noise is still there and they are stumped. Getting concerned as have 1200 mile trip coming up.
Been reading forum - could it be the x drive or transfer case? Anyone had similar issue or advice on next move to diagnose or try to correct?
thanks in advance John
Old 03-15-2017, 01:18 PM
Finally got to the bottom of this through process of elimination, fluid service for diff fixed it
Sent from my iPhone using Bimmerfest mobile app
Old 03-15-2017, 01:51 PM
dannyb1027's Avatar
dannyb1027 dannyb1027 is offline
Mein Auto: 2008 528xi
Great info
Sent from my Nexus 6P using Bimmerfest mobile app
525, differential, noise, transmission, xdrive
