**Z4** DIY Guides (Post links here) - Page 3 - Bimmerfest - BMW Forums
Old 05-25-2009, 06:16 PM
Ron Stygar's Avatar
Ron Stygar Ron Stygar is offline
19,585 Miles
Mein Auto: Z4 M Coupe 6LL93033
Wind deflector Single Parts
Old 05-28-2009, 08:15 PM
Ron Stygar's Avatar
19,585 Miles
Simultaneoe Pedals
Old 06-04-2009, 07:59 PM
Ron Stygar's Avatar
19,585 Miles
Z4M Ride Height
Old 06-08-2009, 10:31 PM
[email protected] cmsnow@pacbell. is offline
Mein Auto: 2006 ///M Roadster
Z4M: Leather Z Triple Gauge Install
This DIY post summarizes the process of installing the Z4 Complete Gauge Kit which can be found here. This post also aggregates other posts related to the topic.
In general the Leather Z kit is well designed and comes complete with gauges, mount, sending units, wiring, and detailed pictured instructions. The posts below provide you with additional details to make your install go smoothly. My install was for the S54 gauges and included the Leather Z Power Socket Relocation kit found here. Since I did not have the luxury of doing this in one shot I broke the process into six steps and completed it over several days allowing me to drive the car after each step. All together everything worked upon first try. I would recommend this DIY to anyone with moderate or intermediate mechanical skills.
Step 1 install the Z4 Power Socket Relocation Kit adding the radio Aux In.
See this post for tips: https://www.bimmerfest.com/forums/sho...d.php?t=180804
Step 2 mount gauges and hook up to dim lighting.
See this post for tips: https://www.bimmerfest.com/forums/sho...d.php?t=214992
Step 3 install the water temp sending unit which requires draining and replacing the coolant.
See this post for tips: https://www.bimmerfest.com/forums/sho...d.php?t=190021
Step 4 install the oil pressure sending unit which requires disassembly of the air intake system.
See this post for tips: https://www.bimmerfest.com/forums/sho...d.php?t=210399
Step 5 wire the sending units tie wrapping along the away finally passing through the firewall to the gauges.
See post above for wire routing tips.
Step 6 connect the gauges to the sending wires and switched power.
See this post for tips for finding switched power (not in the instructions):
https://www.bimmerfest.com/forums/sho...switched+power
2006 BMW Z4 ///M Roadster
Titanium Silver / Black / Premium Package
Strong Strut / Supersprint Sport & X-pipe / Zeck CDV / UUC Short Shifter / ZHP Knob / Leather Z Triple Gauges / RPI Scoop / GapTech RCH+
Photo Gallery here
Old 06-30-2009, 10:11 PM
Ron Stygar's Avatar
19,585 Miles
Z4 M Coupe cupholder delete
Removed the passenger side cupholder and replaced it with the blank cover.
Will be doing the same on the drivers side when the parts show up.
Will probably install the V1 remote there.
Each cup holder is minus ~ 8 -oz.
Old 07-27-2009, 09:59 PM
Ron Stygar's Avatar
19,585 Miles
Emergency Call Button
Old 07-28-2009, 09:46 AM
Ron Stygar's Avatar
19,585 Miles
Z4 Alarm parts 65 73 0 309 944 (May 2007)
Old 08-03-2009, 12:07 AM
Ron Stygar's Avatar
19,585 Miles
Speed Bleeder valves
https://www.bimmerfest.com/forums/sho...d.php?t=375609
Old 08-10-2009, 02:51 PM
Ron Stygar's Avatar
19,585 Miles
Bump stops
Old 09-27-2009, 07:35 PM
Ron Stygar's Avatar
19,585 Miles
Z4 Headlight adjustment
http://www.mcmaster.com/
Old 10-16-2009, 05:43 AM
car62 car62 is offline
Mein Auto: Z4MC AW/IR
Pressure brake bleeder
I am not endorsing this vendor because their service has been not completely satisfactory at times, but this product is an excellent tool to have that allows easy one person flushing and replacement of brake fluid for the brake and clutch system.
Old 12-15-2009, 06:49 PM
Ron Stygar's Avatar
19,585 Miles
Z4: Remove Door Trim Panel
https://www.bimmerfest.com/forums/sho...d.php?t=210510
Old 12-15-2009, 07:20 PM
Ron Stygar's Avatar
19,585 Miles
Rattling Noise from the Rear of the Door Panel
Old 12-17-2009, 10:05 PM
Ron Stygar's Avatar
19,585 Miles
S54: Catalyst Protection While Car is Low on Fuel
Old 12-17-2009, 10:07 PM
Ron Stygar's Avatar
19,585 Miles
Oil Temp/Oil Sensor S54
Old 12-19-2009, 08:47 PM
Ron Stygar's Avatar
19,585 Miles
Z4-M HP/Torque NA and Euro
NA Z4-M:
HP = 330 / 246KW (246000/746 = 330) (246000/735 = 335)
Torque = 262 lb-ft / 355 Nm
Euro Z4-M:
HP = 343 / 252KW (252000/735 = 343) (252000/746 = 338)
Torque = 269 lb-ft / 365 Nm
So NA is 8 HP less than Euro.
Old 01-23-2010, 09:42 PM
Ron Stygar's Avatar
19,585 Miles
Z4 Coupe Trunk Water Leak
Old 01-24-2010, 08:42 AM
Ron Stygar's Avatar
19,585 Miles
Z4 Door Sill Trim Scratched
Old 01-24-2010, 10:01 AM
Ron Stygar's Avatar
19,585 Miles
Z4 Seats Noise
Old 01-26-2010, 09:00 PM
Ron Stygar's Avatar
19,585 Miles
Z4 Third Brake Crack
Old 01-26-2010, 09:36 PM
Ron Stygar's Avatar
19,585 Miles
Z4 Rattle Noise Convertible Top
Old 03-04-2010, 03:03 PM
Ron Stygar's Avatar
19,585 Miles
Cooling System: Long Term Antifreeze/Coolant
Old 03-07-2010, 12:22 PM
Ron Stygar's Avatar
19,585 Miles
Z4 Camber Caster Plate Instructions
Old 03-08-2010, 11:19 PM
Ron Stygar's Avatar
19,585 Miles
Z4M Rear Axle Camber, Toe Adjust
ID:	275702   Click image for larger version
ID:	275703   Click image for larger version
Old 04-02-2010, 08:58 PM
Ron Stygar's Avatar
19,585 Miles
CTEK 7002 Battery Charger
http://www.ctek.com/EN-US/eLearningUS/Default.aspx
http://www.ctek.com/Manuals/new_US7002_EN.pdf
When charged in normal it draws .03 ampere.
Battery Tender draws .06 ampere.
I added a aluminum plate on the bottom of the CTEK with 1/2" height spacers.
Was going to match the bottom of the CTEK, but too much time doing it by hand.
1 each Plate 4" x 8" x 1/8" aluminum. (polished with 220 wet paper)
2 each Spacer 3/8" hex, 1/2" height w/ 8-32 male / female.
2 each Nut nylon lock stainless.
2 each Screw 8-32 1/2" counter sink stainless.
Back on the garage floor doing its thing.
