Starter replacement? - Bimmerfest - BMW Forums
Old 03-04-2017, 10:12 AM
hubcap hubcap is offline
Mein Auto: 2007 525xi
Hi
My 2007 525xi has no crank on ignition, AAA helped me get home and they said battery tests fine so am looking for advice - is my next step to just replace the starter?
Cars been great, have 105k on it, recently had brakes and transmission fluids done, water pump and new plugs, this is first breakdown.
And if so is it a major job, or could I tackle it myself?
Old 03-04-2017, 11:17 AM
dharmabmw dharmabmw is offline
Mein Auto: 2006 530Xi
You can easily DIY but you will need to remove the intake manifold, etc to get to it. Make sure you have all the parts required before tackling the job, including, gasket parts and crankcase breather tubes which tend to break.......
Old 03-04-2017, 11:22 AM
Thanks, I am looking at Pelican site now for parts, planning on a Bosch starter. Any other maintenance I should tackle while am at it?
Sent from my iPhone using Bimmerfest mobile app
Old 03-04-2017, 11:36 AM
toga94m toga94m is offline
Mein Auto: 2006 530xiT
Originally Posted by hubcap View Post
Hi
Quick/free/easy test is to unplug the IBS connector, small two-pin blue connector wired to the battery ground terminal. Don't do the yellow BST connector on the red battery terminal. A broken IBS can eventually annoy the car into not even trying to crank. Been there done that.
Name:	ibs 20170107_151311.jpg
2006 530xiT 6MT - 150k miles - 3rd owner - sport & cold packages
Old 03-04-2017, 12:52 PM
Thanks will take a look at that now, what should I expect to occur once disconnected? That the starter should then get current to crank over?
Old 03-04-2017, 01:19 PM
If disconnecting IBS works and the car starts, then you're fine. I left mine broken and unhooked for months before the weather warmed up and I replaced it.
If it doesn't change anything and car still won't start, oh well, no harm done and you ruled out a possible cause of your problem.
Old 03-04-2017, 02:24 PM
Does your engine have DISA flaps? If so, you could examine them when the manifold is off, since the inboard one can only be accessed with it removed. Also, give the oil separator a good cleaning. Also only accessible with the manifold off.
Old 03-04-2017, 07:11 PM
Thanks!
Old 03-15-2017, 01:17 PM
Job done it was the starter, thanks for the diagnostic advice and tips
