Trans question - Bimmerfest - BMW Forums
Old 12-10-2016, 11:14 AM
iezzif iezzif is offline
iezzif
Mein Auto: 2001 740iL
Trans question
Have to replace the trans in my 2001 740iL with sport package. Are all 5HP 24 the same whether you have the sport option or not? Are there other BMW series that have the same trans?
Old 12-10-2016, 11:41 AM
ogregev ogregev is offline
Mein Auto: E38
I have a 5hp24 in a 2001 740il that I'm parting out that I'll let go for cheap if you come take it out. The car was on the road until the owner overheated the engine.
You are in central CT and this car is in Staten Island NY about 2-3 hours away from you.
Old 12-10-2016, 11:43 AM
Mein Auto: E38
And I assume the sports package has a different torque converter, so you'd retain your old one.
How does $200 sound?
Old 12-10-2016, 05:52 PM
noodlesandsam noodlesandsam is offline
Mein Auto: 00 750iL, 99 540iT, 05 MC
All 740iL's have the same transmission setup - 5hp24 without steptronic. 740i's - shorty's and 750il's were the e38's that came stateside with the steptronic feature. It should be the same.
Old 12-11-2016, 01:42 PM
u.nanimous u.nanimous is offline
Certifiable BMW Whackjob!
Mein Auto: 1999 740iS, 2008 335xi
And to clarify that a little further...ALL E38 750's that came to the states are L's and have the 5HP30 transmission while the early 740's also had the 5HP30 but switched to the 5HP24 around 1998 (not sure of exact build date/model year).
Others that used the 5HP24 would be the E39 (540) and I believe E53 (X5) as well as other manufacturers such as I believe Land Rover which they put the M62 in.
As far as the torque converter goes, I think the different torque converter was originally only in the sporty shorty (you can double check by searching for posts likely by QSilver7).
2005 Venture Extended LT - what else you gonna drive when you have 6 kids, cargo and still want better than 10MPG
1999 740iA - long term project/summer DD
2000 Impala LS - RIP 12/23/2016, officially totaled by insurance company
2001 330xiA - fXtXeX/son project - now April's car
2008 335xiA - winterbeater Impala replacement
2002 530i/5 - 2.5 years searching...and it is John's car
1989 535i/5 - the spare car
2002 325xiA - to be Charlotte's when she gets her license (?2019?)
Old 12-11-2016, 06:09 PM
Yes - high stall torque converter used in 740i - shorty sport, and e39 sport automatics
Old 12-11-2016, 06:24 PM
Rudie's Avatar
Rudie Rudie is offline
Wide boy
Mein Auto: 1999 BMW 328iC
Beware, I think the valvebody differs between the sport and non sport 5HP24's.
2007 Volvo XC90 V8 - 2006 BMW 750Li - 2005 Volvo V70R
Old 12-12-2016, 04:32 AM
The seller posted his vin in another thread. The op should look up the transmissions in realoem, and see if they match
Old 12-12-2016, 03:13 PM
iezzif
Thanks for all the help! Ogregev, I appreciate the offer but do not want to remove equipment. I needed clarification as to what the difference was between the Sport package BMW e38 and standard where the 5HP 24 was concerned. Is it just a software change that enables the trans to be the sport?
Old 12-12-2016, 03:44 PM
Mein Auto: E38
AFAIK the only difference is the stall speed of the converter, although Rudie thinks the valve bodies are different. Since the converter is an external part (basically), it's not a big deal to just use the old one.
Old 12-12-2016, 06:47 PM
There is only one valve body for the 5hp24 from 9/98 production on to the end of the run. The 740i - short wheelbase sport had the steptronic feature, the high stall torque converter, and a 3.15 final drive ratio. 740iL sports were less 'sport' optioned. I'd guess that the Ogregev transmission is exactly the same as the one iezzif needs
Old 12-12-2016, 06:55 PM
Mein Auto: E38
And if nobody buys it, it gets crushed with the car in 4 weeks.
Old 12-13-2016, 07:19 AM
iezzif
Crushed? Ooooohh, not a great ending to such a beautiful car! Sounds like the old shock comedy ransom note routine of shooting the puppy if I don't get XXX.
The parts yard said that the trans part was labeled A5S440ZTE. The first 7 numbers and digits are consistent with the 740iL. Don't know what the TE stands for.
Old 12-13-2016, 08:10 AM
Mein Auto: E38
Yeah, legally it has to be dismantled, and the yard has a few, so it'll go right into the crusher.
Hopefully somebody will want the transmission, windshield and hood because those parts are too big for me to keep.
5hp 24, transmission
HTML code is Off
