Engine locked up! Need advice! - Page 2 - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 6 Series > F12 / F13 (2012 - 2018)
The all new 3rd generation 6 series coupe (F13) and convertible (F12) forum. The F06 BMW 6 Series Gran Coupe forum is here
Old 05-07-2017, 06:29 AM
Rusty34's Avatar
Rusty34 Rusty34 is offline
Mein Auto: 2016 550i M-Sport~2015 X1
An attorney will get it.
Sent from my SM-N920V using Bimmerfest mobile app
Old 05-10-2017, 12:38 PM
JD30 JD30 is offline
Mein Auto: 2013 BMW 650 ix
Everybody taking the owners' side which, I suppose, is understandable ... but ... something does not add up here.
If the engine seized because the oil level was low, one of two things are likely:
1. The low oil light came on and the owner ignored it and kept driving.
2. The low oil light sensor failed.
If BMW is denying warranty, I'm betting they are going with option 1.
Old 05-10-2017, 01:00 PM
Rusty34's Avatar
It may be that the sensor failed. I think the owner reported that they did not get a low oil warning.
Old 05-10-2017, 01:04 PM
Ewan123ner Ewan123ner is offline
Mein Auto: 650 xi gran coupe
JD, you lost money on your bet. There was no warning for low oil. That's one of my arguments with BMW; I took my car into the local service team for top offs when I got a warning. When I checked the oil level on my idrive, it even showed green.
Old 05-10-2017, 01:33 PM
When I got my new 2013 650 ix, I had about 2,500 miles on the car and the low oil light came on. I was about 5 miles from an auto parts store so I drove there and put in 2 quarts. I've checked it religiously since then, use a quart every 1,200-1,500 miles or so. Depends on how 'spirited' I drive.
"Showed green?" How did you check your oil after the engine locked up?
Old 05-10-2017, 01:56 PM
I wish I could have checked it afterward... but that wasn't possible. I checked my idrive weekly. The service rep confirmed the last time the idrive was checked and it was green. He would not tell me the date, but said it was a couple days before the engine failure. He told me the DCS data is proprietary to BMW. He read it to me, but would not let me see it.
Old 05-17-2017, 01:20 PM
Ace535i's Avatar
Ace535i Ace535i is offline
Mein Auto: I'm still dreaming....
Nobody will know why the engine seized until it's removed and dissected. BMWNA conclusion is just a baseless guess. A 24 month warranty is unacceptable. Does the car now suffer from diminished value with an engine replacement? Good luck selling it to anyone.
Sent from my iPad using Bimmerfest
Old 05-25-2017, 07:55 AM
phuksi phuksi is offline
Mein Auto: X3 3.0
Any update on this case? Would be interesting to hear the root cause?
-p
Old 07-16-2018, 09:57 PM
Captain Cook Captain Cook is offline
Mein Auto: 2010 Alpine White 535xi
Looking for an update as well. I recently had my f10 550 seize up. Although its under CPO I'm expecting a little back lash with the cost of a new engine.
Old 07-22-2018, 07:13 AM
pablo645's Avatar
pablo645 pablo645 is offline
Mein Auto: 650i Convertible
You may want to check this out. The lockup on your motor maybe due to a faulty motor. You can by a new N63 for under $4K from BMW due to the recall.
https://www.bangclasssettlement.com/Home/portalid/0
2012 650-xDrive Convertible. Titanium Silver Metallic - M Package - Driver assist package- Cold weather package - luxury seating package - Bang & Oulfsen system.
Previous Cars:
2008 650 Convertible 6 speed manual
2004 645 Convertible 6 speed manual
1994 540 6 speed manual
Old 11-14-2019, 04:50 PM
enriqxxx enriqxxx is offline
Mein Auto: e90 2010
I have a BMW 328i 2010 rolling like a 20m brake to cross it turned off, I did not want to turn on more as if it were discharged battery, when starting the damper turns, I already tried another battery and with jumper and the same Remove the multi channel run and lower spark plug but I see that the damper gets hard the starter the coals look good. How hard should the crankshaft be? They are so hard and slow down but do not stop with anything, without all those accessory and spark plug turns but very heavy
Old 11-15-2019, 04:38 AM
645/333's Avatar
645/333 645/333 is offline
Michael
Mein Auto: BMW 640i SE Convertible
You are asking your question in the wrong forum, you need to transfer it to the appropriate model forum, then you will receive more pertinent answers. plus you need to get someone to help with your question as much of it is not understandable
Always said I would go back to a 6 series
Old 02-09-2020, 07:06 PM
RoadRunna RoadRunna is offline
Mein Auto:
Wow, this same thing happened to me. It was under (3rd party) warranty when it seized. Right before hiring an attorney the warranty company finally decided to repair the motor. If interested I post a video on this bellow. I should have been on this forum years ago.
_sl_ _sl_
Old 03-14-2020, 05:52 PM
A2thamay A2thamay is offline
Step up off me son
Mein Auto: 15 650i GC & 07 650i Conv
Damn your video was long, dragged out and boring! You wasted all that time to simply tell a 3 minute story! You are not too bright dawg. Damn son.
_sl_ _sl_
