A/C Head Scratcher - Bimmerfest - BMW Forums
Old 07-10-2019, 02:47 PM
320kplus's Avatar
320kplus 320kplus is offline
Mein Auto: 98 e39 540i
A/C Head Scratcher
2013 E70 xDrive35i...
Air blows cold on driver's side, warmer on passenger side. Both sides are on the same temperature [60°] with Max button on. Is this indicative of low free on or something more troubling? Thanks in advance.
Sent from my SM-N960U using Tapatalk
Old 07-10-2019, 02:54 PM
Doug Huffman's Avatar
Nuclear engineer
Commonly a fouled side of the Hot-water Control Valve.
BMW IHKA HVAC is a hot water temperature controlled system with the engine heat radiator heat exchangers after down airstream the AC evaporator. The evaporator is always fully loaded and cabin set temperature(s) maintained by a PWM signal to the HCV from the IHKA control module / panel.
https://www.bimmerfest.com/forums/at...1&d=1562795751
Old 07-10-2019, 03:26 PM
BabyUnicornTaco BabyUnicornTaco is offline
Mein Auto: 2008 X5 4.8i E70 Sport
+1 on this. My guess would be heater control valve. There are a couple pretty easy ways to test. If the valve is getting stuck you could tap on the top of the HCV and see if it knocks loose and gives you cold air. This is how bad they get inside. Click image for larger version
ID:	857715Click image for larger version
2008 X5 E70 4.8i M-Sport
2008 550i RPI Exhaust, RPI Ram Air
Old 07-10-2019, 04:12 PM
320kplus's Avatar
Originally Posted by BabyUnicornTaco View Post
+1 on this. My guess would be heater control valve. There are a couple pretty easy ways to test. If the valve is getting stuck you could tap on the top of the HCV and see if it knocks loose and gives you cold air. This is how bad they get inside. Attachment 857715Attachment 857717
Uuuuuurgh. Thanks guys! Tough DIY? How long to swap out old for new? Part cost? Or... what should it run to have a shop do it? I think it just started. I just got this ride but didn't notice it before and the weather has been warm/hot/muggy...
Old 07-11-2019, 12:40 AM
deroy deroy is offline
Mein Auto: X5 e70 4.8
Yes DIY, esp on a straight 6. With the V8 it's really tight and fiddly. Hose clamps do a good job, but not perfect. Tuck some old towels in as backup.
As diagnosis of the valves; feel the two hoses leading to the firewall. In your case one should be hot.
I don't see how being low on refrigirant in the AC system would lead to your (strong) left/right contrast in temp output.
Old 07-11-2019, 04:16 AM
Nuclear engineer
It is an old wives’ tale. The tale is that only the evaporator nearest the expansion valve can carry load while the refrigerant charge is low. Be that as it may, and I have never seen a thermodynamic explanation, the BMW evaporator is folded so that the average cooling load is everywhere the same along the path from inlet to outlet.
Old 07-10-2019, 04:37 PM
This is the OE BMW replacement. You can go cheaper but the trend is that you get what you pay for. It's not a bad DIY. Good time to flush and replace all your coolant. FCPEuro will give you a lifetime warranty.
https://www.ecstuning.com/b-genuine-...e/64116910544/
Old 07-10-2019, 06:47 PM
1bad540's Avatar
1bad540 1bad540 is offline
Mein Auto: E65 750i Sport,C5 z51 e46
easy swap 15 min you can grab it and swap it out w some hose clamp pliers. Just had mine done but car was blowing cold on pass side and hot and cold at the same time on driver.
[SIGPIC]
e39 540i sprt, acs type 2's,acs pdls,clrs(sold)
e65 745i sprt,21's aib's acspdls, rf splr(sold)
e46 328i 18" 335spt whls(sold)
c5vette 6sp,z51,2"drp,19"ccw'sshrt shft,corsa exh,dd nav(sold)
e53 X5 3.0, pna rf,,20"4.6rims.(sold)
e65 750I aw, sprt. 21's,acs pdls,acs rfsplr,mtecs,8k hid(sold)
Srt10 VIPER, 19-20" forged,tune,corsa ex,intake.
w221 S550 amg,dia white,20"s63rims
e70 3.5 aw.mtec,20" 214 whls.
e46 M3vert,6spd,19"HRE,bbk,ext,intke
w222 S550 amg, dia white
Old 07-10-2019, 06:50 PM
Masoe Masoe is offline
Mein Auto: 2012 750Li/2008 X5 4.8
From my EXACT same experience...My Indy Evacuated the system ( I was low) and refilled the system with the proper amount of "refrigerant" and now both my sides blow COLD. They also put a dye in the system to see if there will be future leaks. They replaced the little pins (sorry dont know the name) in the filler valves as well. They said most people dont think to replace them and that's where the system can leak from. I would definitely try the Purge and Fill first...nominal cost and time. Good Luck!
2012 750Li, Carbon Black Metallic/Oyster&Black, M Sport (Current)
2008 X5 4.8 (Sport), Platinum Bronze Metallic/Tobacco&Black (Current)
2006 750i, Sapphire Black Metallic/Black
2002 745i, Sapphire Black Metallic/Beige
2002 530i (5 speed), Sapphire Black Metallic/Black
Old 07-10-2019, 08:05 PM
robnitro robnitro is offline
Mein Auto: x5 35d e70 2011
Schraeder valves, yeah can't change those until you evacuate system.
Old 07-10-2019, 08:20 PM
lol...yup, those are the valves. Thanks
Old 07-11-2019, 06:41 AM
Zulu95's Avatar
Zulu95 Zulu95 is offline
Mein Auto: 2001 X5 3.0L
+1 E53: Cold/warm problem cured by evac/recharge. I did a temp fix with a wallyworld rattle can quick charge until I could get it into the shop for a complete check out. That was about 5 years ago still blowing cold. Old wives tale or not a recharge fixed the problem.
Sent via Telegraph wires using my Morse Key.
2001 X5 3.0L SOLD
2013 X5 xDrive35i
Old 07-11-2019, 06:54 AM
Nuclear engineer
Originally Posted by Zulu95 View Post
+1 E53: Cold/warm problem cured by evac/recharge. I did a temp fix with a wallyworld rattle can quick charge until I could get it into the shop for a complete check out. That was about 5 years ago still blowing cold. Old wives tale or not a recharge fixed the problem. [/COLOR]
NO. No, the problem went away after the "recharge" not necessarily because of it. Post hoc ergo propter hoc is the weakest logic, just better than the arrow of time.
Old 07-11-2019, 01:30 PM
OP...There has been a lot of discussion on this topic in the past (google it) and there are a LOT of people that have had this problem fixed by a purge and fill. I don't know the reason or have data on how it fixed my issue, and frankly I don't care because the issue was fixed and has been for years now. Try it and report back.
FWIW, this brings back one of the issues I had with the fuel pump relay causing my vehicle not to start when temps went below 32 degrees F. I had people saying they couldn't understand why it would fail and cause the vehicle not to start at a certain temperature, BUT it did! $18 dollars later (part replaced at dealer during warranty work) and I have NOT been stranded in the cold every since (others have benefited from this as well). I don't know why it worked, but it did.
Old 07-14-2019, 07:46 PM
vinsonr vinsonr is offline
Mein Auto: e90 M3 VT2-625, e90 335i
OP,
Push this button: and dial the vent back to cool. It took me waaay longer than I care to admit to realize why I had warm air coming out of my driver's side....
Pic didn't show but it's the 'manual mode' button with 3 air vent arrows and a person sitting down.
http://www.bavarianmw.com/images/boo...6/index.80.gif
Old 07-14-2019, 08:05 PM
320kplus's Avatar
Originally Posted by vinsonr View Post
OP,
Bingo! Passenger side was set to warmer. Now it's fixed. I'm still going to have the cold air temp checked and see where I'm at.
All the best guys!
Old 07-15-2019, 06:41 PM
Pete_NZ Pete_NZ is offline
Mein Auto: E61 530D E91 330d E46 328
Hahaa Love it when a fix performed in actual, live reality shows all the theorising and rationale based analysis and grandstanding arguments and "superior" assertions as worth the 2cents they are.
Old 07-16-2019, 05:48 AM
Nuclear engineer
Evaporator inlet and outlet are on the same side.
One may see in the cartoon cutaway of green piece 5 the inlet and outlet ports and the fold at the bottom of the image.
ID:	858265   Click image for larger version
Old 07-16-2019, 05:52 AM
1bad540's Avatar
some of us dont care to argue, especially when weve had over 20 bmws and your on your 1st!! lol
[SIGPIC]
Old 07-16-2019, 07:35 AM
ard ard is offline
Resident Curmudgeon
Again...
https://www.bimmerfest.com/forums/sh...re#post9821452
At the end of the day, hundreds of people have seen this behaviour w low Freon. My comments on differential diagnosis stand....
Alignment here: The Definitive Alignment Thread
OE is Original Equipment aka 'BMW Original Parts' aka 'What you buy at the BMW dealer with a BMW label'
OEM is Original Equipment Manufacturer... EITHER the company that made the OE part or.... A part this is identical to the OE part, but is sold by the OEM under their own label
OEM is not what BMW sells
http://www.bimmerzone.com/category/T...ricks_OEM.html
https://www.turnermotorsport.com/t-OEvsOEM
Old 07-16-2019, 07:47 AM
320kplus's Avatar
Originally Posted by ard View Post
Again...
Guys! Thank you all for your insight! No doubt we've all Learned something from just this one thread. This is exactly what these forms are for and about. ROCK ON!
Old 07-16-2019, 08:31 AM
ard ard is offline
Resident Curmudgeon
"we"? no.
But yes, rock on!
Old 07-16-2019, 09:04 AM
320kplus's Avatar
"we"? no.
But yes, rock on!
ROTFLMAO! Alrighty then!
