335i questions - Bimmerfest - BMW Forums
Old 05-08-2017, 08:04 PM
bimmer765's Avatar
bimmer765 bimmer765 is offline
Mein Auto: 325i
335i questions
I've found a 2010 335i with 70K miles. Took it out for a test drive and it ran great, but the engine had a cylinder 1 misfire when we got back
after it was warmed up. Also the a/c was blowing hot air, is it common for the evaporators to leak on these? I have a bmw scanner from ecs tuning
and it only came up with two codes, one for the cylinder 1 misfire and another was a low power code for the instrument cluster. If it was low on freon
would there be a code for that?
Old 05-08-2017, 09:00 PM
josh783 josh783 is offline
Mein Auto: 335i
I just got my 335i back from bmw, had a misfire in cylinder 5. Was told could be injectors, plugs or fuel filter. Turned out to be stuffed camshaft, valves and lifters with a $7k bill.
Sent from my SM-G920I using Tapatalk
Old 05-08-2017, 09:28 PM
F10-N52 F10-N52 is offline
Banned
Mein Auto: 2011 528i RWD
Misfire most likely due to failing ignition coil cheap and easy fix. I had one fail on me at almost the same mileage.
Old 05-08-2017, 09:48 PM
CALWATERBOY DUE CALWATERBOY DUE is offline
Banned
Mein Auto: 09 E93 335i somewhat mod
Which scanner is it? [click me] and pay attention to the misfire diagnosis link.
Old 05-09-2017, 04:31 AM
fxrs1955 fxrs1955 is offline
Mein Auto: 2011 335is
Find an indy you can trust and have him check it out before you buy?
Old 05-09-2017, 05:08 AM
Zooks527's Avatar
Zooks527 Zooks527 is offline
Breaking in the Pony
Mein Auto: 19 Mustang GT / 05 Tacoma
It is not common. Sure, any car can have A/C issues, but I honestly can't recall the last time I saw someone with an A/C complaint on the E90 board.
Prior 44 years of cars: 1967 BelAir wagon / 1968 LeMans Tempest / 1970 Mustang Mach 1 / 1972 El Dorado / 1978 Corvette / 1981 Subaru GL wagon 4WD / 1983 s10 Blazer 4x4 / 1985 Bronco 4x4 / 1996 Bronco 4x4 / 2004 Passat 4motion / 2009 BMW 335i xDrive E92 / 2015 BMW M235xi xDrive F22
Old 05-09-2017, 06:10 AM
bimmer765's Avatar
Mein Auto: 325i
If its the evaporator leaking thats a huge job. The dealer I found it at are pretty much only bmw and mercedes. They said they would take care of it, but that might be just add freon and send it out.
Sent from my SM-G920R4 using Bimmerfest mobile app
Old 05-09-2017, 05:34 AM
07335's Avatar
07335 07335 is offline
Mein Auto: 2011 335is CAB w/DCT
Get a PPI. Misfires are commen and due to plugs and coils. Easy DIY and good deals on Amazon for bosch parts.
Old 05-09-2017, 09:37 AM
jat335i jat335i is offline
Mein Auto: 2010 335i
I bought my 2010 E92 335i new and haven't had any issues with misfiring or bad coils and neither have I had any A/C problems (or required recharging). Earlier this year (@ 81,000 miles), I had my trusted mechanic replace the spark plugs (preventive maintenance) as well as the VGC and OFHG (leaking due to normal age/wear). My ride has 85,000+ miles on the odo and all has been running fine since the first day I drove it home.
JT
2010 BMW 335i
Monaco Blue Metallic
Premium+Sport Package
Auto/STEPTRONIC
COBB Stage 2, K&N, BMW Performance Exhaust
2005 Mustang GT
Redfire Metallic
5-spd
Ford Racing silver Bullitt wheels
Ford Racing Axle-back GTAs
Diablosport Predator
K&N CAI
http://www.cardomain.com/ride/2046852
1997 Toyota Corolla
http://www.cardomain.com/ride/3237714
1983 Mercedes Benz 380SL Roadster
Old 05-09-2017, 09:47 AM
Porando Porando is offline
Mein Auto: 2011 335i, 2004 X5 4.4L
"Also the a/c was blowing hot air, is it common for the evaporators to leak on these?"
It appears that way.
Couple years ago when I was about to run out of manuf warranty, I went to dealer to have evaporator cleaned as it started to smell a bit from AC..
SA told me that they will do the test for the evap leak as they've already replaced several with leak... And couple hours later, he confirmed that indeed evap leaks and it will be replaced - and this would be 2 days job because the whole dashboard and center console have to be removed.. they have cooling agent leak detection device.
So i hope that replacements are more reliable.
Old 05-10-2017, 01:43 AM
Banned
For OP:
Old 05-11-2017, 01:14 PM
ramblinman ramblinman is offline
Mein Auto: 2008 335
I had an e46 that needed a new compressor at about 100k. That's not uncommon. I have a 2008 e92 with about 55k on it and the a/c works perfectly. I have never had a problem with an evaporator. But I've had a number of cars where the compressor failed, or a seal began to leak. If your car is blowing hot air, any good mechanic should be able to do a test of the refrigerant pressures. You may need to pay for an evacuate and recharge, with a dye injected, if your refrigerant is gone. The dye is used with a UV light to detect leaks, and a pressure test will tell if the compressor is working. Sometimes the compressor seizes up. If that happens, you would know because the drive belt will make a lot of noise and you may smell burning rubber from the belts moving across the pulley that won't move, if you try to keep the ac on.
Old 05-11-2017, 03:44 PM
TahoeSun TahoeSun is offline
Mein Auto: E93 335i & F25 35iMsport
Delphi coils are better than the Bosch ones IMO. Cheap and easy fix. Plugs are also on Amazon with the Delphi coils. I replaced both coils and plugs and my car runs like new again.
Walmart for the AC fluid. It's the same thing as air in the can that one would use to de-dust a computer keyboard. Buy the can with the pressure gauge so you can see the pressure you're putting into the system. I did mine when the AC was blowing less than cold. Fixed it easily.
And pay for a PPI from a local and trusted indy. $200 spent is always cheaper than $4000 in repairs. And buy a car from an owner who knows BMWs. Otherwise get a big discount for your troubles.
GL. These are great cars. I've owned 7 BMWs since 2001 (E46's, X5, X3, E93)
2001 330i Sport 5spman- Sold 48k miles
2003 X5 3.0i Sport 5spman- Sold 146k miles
2001 330ci Sport 5spman- totaled 140k (thanks, son)
2001 325i Sport 5spman- fixer Sold 164k miles
2008 335i Conv 6spman - Sold 112k miles
2005 330i ZHP 6spman- Sold as totaled 110k (thank, son)
2013 X3 35i Msport (bought Jan 2016)
2003 330ci Slicktop Sport 5spman w78k (bought Mar 2017)
2012 335is E93 DCT 34k (bought Jul 2017) 53k as of 20191211
2003 330ci Sport 5spman 32k on it (Oct 2018)
