transfer case actuator calibration? - Bimmerfest - BMW Forums
Old 07-19-2015, 09:19 PM
wowturtleswow wowturtleswow is offline
Mein Auto: x3
hi all
I've replaced the oem gear with the odometer gears gear about a year ago but shortly after all 3 lights came back. took it to an indy shop and said that whenever you mess with the actuator, you have to have it calibrated with bmw scan tools; I could still drive it, but it'll be full time rwd.
NOW, (couple months later) I'm in limp mode getting codes 5463, 55c4, 5f3a, and 5462. upon doing research, it leads back to the actuator and I've decided to just replace the whole unit. From what I've been reading, I should be okay with just removing and replacing, and no one talks about calibrating it.
Can someone confirm or give insight to this? I've done this before and would hate to pay someone else to do it unless I have to because of the calibration.
thanks in advance
Old 07-20-2015, 05:13 AM
swampX3 swampX3 is offline
Mein Auto: bmw++many
codes/t cas actuator prices/calibration
this diy actually gives you the codes
you can get the actuator for around 500 bucks now .....two sources came up in the last few weeks .....ecs and cobra
you can live without a recalibration but we would recommend getting it done ........it's tough to pay 100 plus for a 5 minute job but the electronics guys have us cornered......the calibration covers very basic oil condition and an input to an algorithm that effects the pre setting of the actuator at each startup and thus the reaction speed of electronic 4 wheel drive......so ......the question in your mind may be ......why have the 4 wheel drive system if it's not in top shape ?????
https://wiki.bentleypublishers.com/p...geId=128385035
Old 07-20-2015, 05:24 AM
post 22....transfer case actuator cost
kinda shows that at last they can't keep up a 100% mark up on the complete actuators
another point I make is that many of the diy's state to be careful not to disturb the actual actuator motor /windings etc .....this is very short sighted .....the least any diy'er needs to do is check the brushes and do some very basic cleanup/tests I posted in the fest thread.....a dc motor inspection/cleanup and basic test is very very simple and can save headaches later.....a new resistor is also low cost....~20bucks
I thought you might be interested in reading this web page:
https://www.bimmerfest.com/forums/sho...errerid=343410
https://www.google.com/url?sa=t&rct=...98197061,d.cGU
Old 07-20-2015, 05:39 AM
transfer case actuator motor visual
check post 19 .....another dc motor visual .....this time a starter motor for an example of how the brushes can ruin a motor/need of inspection/cleanup etc
did you check your motor when you replaced the gear ????.....these little guys do lots of work
https://www.bimmerfest.com/forums/sho...d.php?t=851778
Old 07-20-2015, 08:50 AM
timgray timgray is offline
Freshly Addicted
Mein Auto: 2007 X3, 2013 X1, 1999 Z3
DO you have any other local small German auto repair shops? many have the tools needed to reset the Transfer case adaptation and do it for a reasonable fee unlike the dealership or this place you are currently going to. Also the reset is only for clutch pack wear after a fluid change.
Old 07-20-2015, 09:22 AM
Mein Auto: 2004 X3 2.5i
Originally Posted by wowturtleswow View Post
....... an indy shop and said that whenever you mess with the actuator, you have to have it calibrated with bmw scan tools
...... I've decided to just replace the whole unit. From what I've been reading, I should be okay with just removing and replacing, and no one talks about calibrating it.
I don't believe that indy shop is correct. But may depend on what they mean by 'mess with the actuator'.
Any mechanical intervention on the actuator, such as replacing the gear, does not require coding. Doesn't make sense saying it would.
If you did something electrical that affected how the actuator uses the classification resistor in the transfer case, then I could see that re-calibration would be needed.
Replacing the actuator with a new one would requires coding so that it can be matched with the existing resistor.
Replacing the actuator with a used or reconditioned one might work without coding with a bit of luck, but I would think a re-calibration ensures that it operates the clutch pack in the transfer case optimally.
Replacing just the classification resistor surely requires coding too.
The discussion really gets back to the question of why the actuator gear wears for some owners and not for others.
It seems likely that it is a symptom for something else that has gone wrong within the transfer case and/or actuator assembly.
Replacing just the gear might just buy you time. (As would rotating the old gear - but that may buy you even less time.)
It also appears that the type and quantity of lubricant around the new gear could be critical.
If your actuator gear wore out because the transfer case clutch packs had been operating inefficiently for some time, then a re-calibration was needed whether a new gear was installed or not.
All depends on what error codes were existing or pending at the time the gear was replaced.
As the actuator is relatively simple, I wonder what else can go wrong with it other than worn brushes in the motor, failed windings, wear in other parts of the worm drive, electrical contacts, etc.?
Old 07-31-2016, 06:34 PM
rbelton rbelton is offline
Banned
Mein Auto: E39
For those searching, here's the DIY guide for the transfer case gear replacement:
Old 10-23-2016, 04:37 PM
cncmastr cncmastr is offline
Send a message via AIM to cncmastr
Mein Auto: E46, E30, E53 and E39
To compliment that actuator motor gear repair, I just finished uploading a new video to showcase how to drain and flush the transfercase (transfer case) for a 2005 E53 X5. At the end, I even show how to use GT1 / DIS to perform the adaptions reset.
E46 - ZCP | E30 - 318is | E53 - 4.8is
DIY Video Channel - http://www.youtube.com/user/BluePurpleRedGuides
Old 04-09-2020, 08:00 PM
alsd alsd is offline
Mein Auto: BMW
Reviving this
So Iím now desperate.
My problems are that I have a bucking and jerking transmission on acceleration particularly up hills. Itís so bad that you can hear the rear diff ďslappingĒ if you know what I mean. Bloody terrible.
Eventually I got the three lights followed by the clicking sound in the transfer case actuator.
Iíve gone to the fix in the DIY actuator gear replacement thread.
Iíve replaced the gear, thrice.... (first time I rotated the gear, not quite 180 deg I think), first time The jerking was gone, good as new however after a bit of oomph on the gas, the triad of lights reappeared and I had the error again. Not a real problem to me as the jerking was still gone and she was driving as good as new.
So, second time i replaced the gear with one I bought off eBay. Take it for a test drive and the jerking is back.... no errors. Iím wondering if the gear was not made correctly to spec and so I decide to put the old gear in, correctly rotated away from the chewed side this time....
Test drive, jerking returned, no error....
Iím at my wits end here but here are my theories and Iím hoping you much smarter folk than I might be able to help:
07 3.0d m57TU2
1. The problem is in the gearbox or torque converter. Thinking about a possible fluid change and service by a tram is Sion shop but I donít think this will help. They will do the Mechatronic sleeve while they are there and thatís the only bit I reckon could really help.
2. The problem is the transfer case itself. I would try a fluid change and adaptations reset. Fingers crossed that helps.
3. I have constant error codes on my glow plus, they are:
004212-004262 inclusive (so 6 errors for 6 plugs. I have read elsewhere that these codes usually refer to the heater that preheats the diesel and is mainly useful for colder weather. I live in Australia, no problems with cold WX. But should these codes mean my plugs are faulty or I have a problem with my system, then maybe Iím getting a misfire as a result, giving the jerky feel Iím getting through the transmission.... it would have to be a REALLY bad miss to get this level of jerk.
4. Maybe the front diff is the problem as when the gear was replaced the first time and resulted in the errors but still drove ok, it was only driving rear wheel drive. Now that Iíve replaced the gear, itís reverting to all wheel drive and maybe the front diff is causing the problems.
ANY OTHER IDEAS OR COMMENTS ON MY THEORIES WOULD BE GREATLY APPRECIATED GUYS! I need help big time!
Thanks in advance you legends!
Old 04-10-2020, 01:22 AM
BimmurBrothor's Avatar
BimmurBrothor BimmurBrothor is online now
BeeemerBro
Mein Auto: X3 M54 150k
Are you running with staggered tires?
What's the age of the tires and battery?
What's the inflation?
Are all 4 tires the same brand or are they mixed?
Have you changed the tc fluid?
What codes did you say the scanner is reading?
Sent from my 9029W using Tapatalk
[FONT="Arial Black"]
Old 04-10-2020, 04:21 AM
BMWaufKS BMWaufKS is offline
Mein Auto: 2008 X3
All wheel speed sendors, and their reluctor rings on the hubs cleaned and checked?
And the SAS reset by turning the steering wheel lock-to-lock a couple of times?
Since 1/2016, restoring a
2008 BMW X3 M-Sport, N52, automatic ("#1")
Modifications:
All stock except dashcam
Since 3/2017, also restoring a
2008 BMW X3 base-model, N52, automatic ("#2")
Modifications:
Dashcam, cargo cover, cargo mat
Parts for sale: https://www.bimmerfest.com/forums/sh....php?t=1382187
Old 04-10-2020, 05:39 AM
Mein Auto: BMW
Staggered tyres - yep.
255/45/18 rear
245/45/18 front
Rears new as of a few weeks ago. The jerking got much worse after the new tyres were put on. Maybe I go and get the fronts done too.
Battery? Not sure how old. Iíve had the car a year, after checking the codes using a scan tool I decided the battery was good.
Will check Tyre pressures.
Mixed brand between front and rear tyres
Have not changed the TC fluid yet
Well the scanner isnít reading any codes anymore after the new gear has been installed.
Old 04-10-2020, 05:40 AM
Mein Auto: BMW
This stuff I have not checked at all. I will do tomorrow!
Whatís the sas? (Steering angle sensor?)
Old 04-10-2020, 08:26 AM
jeepo23 jeepo23 is offline
Mein Auto: 2008 X3, 6 Speed
255/45/18 rear
245/45/18 front
There is your problem.
Sent from my iPhone using Tapatalk
Old 04-10-2020, 04:53 PM
Mein Auto: BMW
Right so even though the profile 45/r18 is the same (therefore the rolling length of the Tyre is the same) the width will cause problems?
Old 04-10-2020, 04:54 PM
Mein Auto: BMW
How does that work? Like, Iím trying to figure out the logic of that.
Not doubting what youíre saying just genuinely curious.
Old 04-10-2020, 05:14 PM
Mein Auto: BMW
And if I shouldnít stagger my tyres, what am I supposed to put on? The OEM says that my tyres should be exactly was there are now so Iím confused.
Old 04-10-2020, 05:19 PM
dukedkt442's Avatar
dukedkt442 dukedkt442 is online now
Anti-Hack
Location: Hudson Valley/LI, NY; Treasure Coast, FL; OBX, NC.
Mein Auto: 2008 BMW X3
Different brand tires have different overall diameters regardless of stamped tire size. Staggereds are especially difficult because only a few select brands have different stamped sizes that measure to the same OD within 1%. That the issue exacerbated with the new tires is pretty good evidence that tires are the issue. Even a single worn tire among 3 new tires is enough to wreak havoc on the X drive in these vehicles.
The "need to have my head examined " E21 build thread
2008 BMW E83 1981 BMW 320i
2016 Chevy Silverado 2011 VW Jetta
1984 GMC S-15 1986 Oldsmobile 442
Another half dozen '60s tractors
Old 04-10-2020, 05:20 PM
Mein Auto: BMW
Yep sounds fair enough. Damn.
dukedkt442's Avatar
Anti-Hack
In your tire description, both front and rear tires have extremely different overall diameters. You do not have a proper or accepted staggered setup.
Old 04-10-2020, 05:25 PM
Mein Auto: BMW
Sorry, the fronts are 235/50/18ís
Mein Auto: BMW
Rears are 255/45/18
Old 04-10-2020, 05:27 PM
rav31 rav31 is offline
Mein Auto: 2001 540i/6 Tisilver/gray
@alsd.... that dia of 255/45/18 rear is 26.7" dia
245/45/18 front is 27" dia
This is probably your problem
Also, check the tire pressures. Different pressures will produce different dia's. The Xdrive cars like the same dia front & rear.
BMW CCA #132981 Tarheel Chapter,
Old 04-10-2020, 05:29 PM
dukedkt442's Avatar
Anti-Hack
Still have a 5.5mm difference in nominal diameter. Thereís your issue.
Old 04-10-2020, 05:36 PM
Mein Auto: BMW
Ok great so, now Iím just thoroughly confused.
What Tyre sizes would you guys say is the correct combination then?
