transfer case actuator calibration? - Page 2 - Bimmerfest - BMW Forums
Old 04-10-2020, 05:39 PM
rav31 rav31 is offline
Mein Auto: 2001 540i/6 Tisilver/gray
Originally Posted by alsd View Post
Ok great so, now Iím just thoroughly confused.
What Tyre sizes would you guys say is the correct combination then?
Sent from my iPhone using Bimmerfest
Go to a site like Tire rack or Discount tire & put in your car information & see what tire sizes they recommend. They are pretty good at it. Also, the owners manual will show what sizes, even offsets that are recommended for your X3
BMW CCA #132981 Tarheel Chapter,
Old 04-10-2020, 05:52 PM
dukedkt442's Avatar
dukedkt442 dukedkt442 is online now
Anti-Hack
Location: Hudson Valley/LI, NY; Treasure Coast, FL; OBX, NC.
Mein Auto: 2008 BMW X3
Use the size and BRAND indicated on the door jamb and ownerís manual. Hope that irreparable damage hasnít been done.
The "need to have my head examined " E21 build thread
2008 BMW E83 1981 BMW 320i
2016 Chevy Silverado 2011 VW Jetta
1984 GMC S-15 1986 Oldsmobile 442
Another half dozen '60s tractors
Old 04-10-2020, 06:44 PM
alsd alsd is offline
Mein Auto: BMW
Here is my Tyre placard in the door jamb. According to that my Tyre size combination is correct at 235/50/18 front and 255/45/18 rear so if thatís not correct then I donít know what to do!!
As for brand, well Iíve already forked out for the rears so Iíll have to go the same brand on the rear which is now organised and will be fitted.
Now that I think about it and after all of your inputs it makes sense. With differing Tyre diameters, the system thinks itís constantly slipping just a fraction and hence why the problem is so bad on hills.
Thanks guys and duke, fingers crossed I havenít cooked it!
Old 04-10-2020, 06:45 PM
jeepo23 jeepo23 is offline
Mein Auto: 2008 X3, 6 Speed
And if I shouldnít stagger my tyres, what am I supposed to put on? The OEM says that my tyres should be exactly was there are now so Iím confused.
I donít recall the X3 coming with staggered tires from factory. Where do you read or see this?
Sent from my iPhone using Tapatalk
Old 04-10-2020, 07:00 PM
Mein Auto: BMW
Gday Jeepo,
Well that picture is from my door, so thatís the first place.
Second, itís an m-sport package so sheís got m-Doppel spoke rims etc.
Iím guessing that most of you guys are in the states, Iím Australia so we probably got different models and specs to you guys hence the staggering stuff.
Old 04-10-2020, 07:08 PM
dukedkt442's Avatar
Anti-Hack
As mentioned, the placard only applies to a specific set of tires from a specific manufacturer or 2. If the brands and wear differ, you may as well have different sized tires on it. Your ďthinking on itĒ is exactly correct. Tires MUST be equal size and wear within 1%. Do that and your problems should go away, assuming you havenít caused irreparable damage to the transfer case.
Old 04-10-2020, 07:39 PM
BMWaufKS BMWaufKS is offline
Mein Auto: 2008 X3
My M-Sport came with OEM staggered tire and wheel sizes too.
Since 1/2016, restoring a
2008 BMW X3 M-Sport, N52, automatic ("#1")
Modifications:
All stock except dashcam
Since 3/2017, also restoring a
2008 BMW X3 base-model, N52, automatic ("#2")
Modifications:
Dashcam, cargo cover, cargo mat
Parts for sale: https://www.bimmerfest.com/forums/sh....php?t=1382187
Old 04-10-2020, 08:16 PM
Mein Auto: BMW
Yep fingers crossed!
Old 04-10-2020, 08:17 PM
Mein Auto: BMW
Are you in the US too?
Old 04-11-2020, 03:45 AM
BimmurBrothor's Avatar
BimmurBrothor BimmurBrothor is offline
BeeemerBro
Mein Auto: X3 M54 150k
I had an informative chart listing tire (acceptable) sizes for the X3 down to the country...I've lost and changed phones so many times since I last consulted.
Ah! Here it is...hope this helps:
BMW X3 2005 - Wheel & Tire Sizes, PCD, Offset and Rims specs - Wheel-Size.com
https://www.wheel-size.com/size/bmw/...m-30i-usdm-225
Sent from my SM-J727T using Tapatalk
[FONT="Arial Black"]
Old 04-11-2020, 05:12 AM
Mein Auto: BMW
Ah bugger!
Well I canít go wrong if I follow the tyre placard.
Iím just surprised at how changing tyres on the rear but not the front has had such a detrimental effect.
I really hope that having fresh rubber all round helps this.
Old 04-11-2020, 02:16 PM
dukedkt442's Avatar
Anti-Hack
Ah bugger!
It probably makes more sense the issue occurs with the rears because thatís where 70% of the torque is going. Iím surmising here, but if the vehicle ďthinksĒ thereís slippage at the front, itíll shift torque to the rear, lessening any binding. With it ďthinkingĒ the rears are slipping, itís transferring more torque to the front axle that doesnít need it, and you feel the binding as the two axles fight each other. One thing is definitely certain, catastrophic damage will occur somewhere because of it, most like the TC clutches first. As soon as you get a proper set of spec spec tires on the thing, youíll need to change the T case fluid ASAP because the more you drive it, the more the fluid turns to sandpaper. Use only the BMW fluid or a fluid meeting its specs (I have Shell S tec in mine which I believe is the OE supplier and itís been fine).
Sent from space
Old 04-14-2020, 02:57 AM
Mein Auto: BMW
So I had the front tyres installed today. Same brand (no not the BMW recommended brands, just bought a house and am literally too poor to afford that level of investment right now!) and all according to spec.
Whilst itís not as bad. The problem remains.
Iím going to change the TC oil and then get the adaptations reset but after that Iím outta ideas.
Ready to set the fu$king thing on fire now.
Old 04-14-2020, 03:59 AM
Mein Auto: 2008 X3
Have you reset the SAS? And checked/cleaned the wheel speed senders and their reluctor rings?
Modifications:
Modifications:
Old 04-14-2020, 04:10 AM
Mein Auto: BMW
I have not!
Iíll give it a try. I got so caught up in this tyre business that I forgot all about your recommendation!
Will give it a go and see how we go with that.
Old 04-15-2020, 01:31 AM
Mein Auto: BMW
I have not!
SAS reset, no luck.
Havenít been able to check the reluctors yet.
Old 04-21-2020, 11:16 PM
Mein Auto: BMW
So just to update.
Today I changed the TC oil. The stuff that came out was black and I swear there were particles in it.
In went the new stuff.
After the first quick drive, I donít want to jinx myself but it appears to be way better.
I think I still have firing issues in the engine so will be investigating that further but for now, I believe my jerking is 90% gone.
Thanks to all for the advice, was great to have it..... something tells me Iím not out of the woods yet though.
