Oil Leak - Bimmerfest - BMW Forums
Old 06-06-2020, 03:53 PM
mohamedrani mohamedrani is offline
Russian Bimmer
Mein Auto: 520i 1998
Oil Leak
Hello guys,
i noticed that there's dirty oil visible on the engine where i pointed in the photo and also in the far below the engine
i don't have white smoke or over heating problem ( the signs for blown cylinder head gasket)
and also, when the car is parked anywhere, i don't see any oil drops or spots underneath the car,
i had a problem almost 2 years ago with the heat and it went to the red zone couple of times , but it was because of the radiator so i overhauled the whole cooling system and since then it never went above the middle on the temp indicator
the mechanic said it's a blown cylinder head gasket , but as i said i don't have any symptoms , and the problem is i have a good mechanic but sometimes he's just guessing not 100% sure that's why i always use him as a handy man and just telling him what i want to change if i already know the problem and that works better with him ))
any ideas?
Current Garage
98 E39 520i
17 Wrangler Unlimited Sahara lifted
Old 06-06-2020, 04:54 PM
effduration effduration is online now
Mein Auto: '99 528i, '03 530i '06 X5
Looks like a Valve cover gasket leak, or possibly a leak in the vanos system, not a head gasket leak. If you haven't replaced the valve cover gasket, I would start there.
Old 06-06-2020, 04:57 PM
Russian Bimmer
I had that in mind also , just to make sure i understand, this is the valve cover gasket right?
Sent from my Redmi Note 8
Current Garage
98 E39 520i
Old 06-06-2020, 06:09 PM
yes
Old 06-06-2020, 06:12 PM
Russian Bimmer
yes
Thanks alot)
Current Garage
98 E39 520i
Old 06-06-2020, 07:11 PM
E39Hoon E39Hoon is online now
Mein Auto: 97 528i+00 540it+89 325i
looks like a valve cover gasket leak, or possibly a leak in the vanos system, not a head gasket leak. If you haven't replaced the valve cover gasket, i would start there.
+1
Old 06-07-2020, 03:05 AM
528iAut 528iAut is online now
Mein Auto: 1996 528i
I don't think I would worry about it but well....
Your car looks very very clean!
E39 528i Steptronic 1996, Comfort seats, Rear sunshade, Focal amplifier and front speakers, Oxford Green.
Old 06-07-2020, 10:51 AM
Russian Bimmer
Well, i drive the BMW less these days, the jeep is better due to the weather in Russia now,
But before parking it , i cleaned the engine bay and everything , but i noticed that the oil residue appeared as mentioned , so why not to fix that too))
Current Garage
98 E39 520i
Old 06-07-2020, 10:54 AM
Russian Bimmer
I'm even planning to paint the whole car, the old paint already faded and some scratches , it still has the original 98 paint and the previous owner didn't really take care of it at all
Current Garage
98 E39 520i
Old 06-07-2020, 01:54 PM
bmw blue's Avatar
bmw blue bmw blue is offline
Mein Auto: 2000 BMW 528i Steptronic
You are gonna need to replace all 15 of the valve cover cap nut rubber grommets, if you do not do this, your new valve cover will not seal correctly.
https://www.turnermotorsport.com/p-3...r-priced-each/
Beisan Vanos Repair, EMP Stewart Water Pump, Aluminum Water Pump Pulley, Behr Electric Fan, Sachs Fan clutch,
18pc Lemforder Suspension Kit w/Koni Sports+H&R Springs,
E46 Intake Boot W/AFE Dry Air Filter, Conforti Shark Injector,
Liqui Moly Leichtlauf High Tech 5W40 Motor Oil, Pentosin Full Synthetic Transmission Fluid and 75-90 Motul Full Synthetic Differential Oil.
Michelin Pilot Sports (summer), Continental DWS (winter).
190,500 miles and counting.
Old 06-07-2020, 07:41 PM
Russian Bimmer
Thanks for the tip , will buy them too,
Just another question, will i need to seal the cover with some kind of tempruter silicone or anything, or just cleaning the place of the old rubber seal and replacing with new one and that's it ?
Current Garage
98 E39 520i
Old 06-08-2020, 05:49 AM
Yes. The half circles in the back will need some high temp rtv and then a tiny dab on the front where the head meets up with the vanos.
Old 06-08-2020, 09:47 AM
crazy4trains's Avatar
crazy4trains crazy4trains is offline
Mein Auto: 2002 530i Sport
Review the Beisan website. There are some good DIY procedures that document everything that you need to do when replacing the VCG.
2002 530i
Old Yesterday, 03:05 AM
Russian Bimmer
i found this video on YouTube i guess it's a good reference
Current Garage
98 E39 520i
Old Yesterday, 04:48 AM
Be careful relying on Nathan's advice...He cuts a lot of corners and often gives less than excellent advice IMO...
A lot of the cars he works on seem to come back for the same problem ( head gaskets, etc.)
I think in the video you linked he insists you need to slather RTV over the entire mating surface otherwise the valve cover will leak. This is just not true. Use a good gasket (not the cheapest on ebay - buy new grommets and put a little RTV on half moons and where the head meets the vanos unit.
I watched another recent video on an AC Compressor replacement where Nathan didn't use a vacuum pump, released 134a to the atmosphere, and didn't bother to use AC gauges.
This is a better video - this is part 1, you can find part 2
Old Yesterday, 05:19 AM
Russian Bimmer
Thanks for the tip, will do))
Current Garage
98 E39 520i
Old Yesterday, 05:28 AM
Mr.Yuck Mr.Yuck is offline
Mein Auto: 99 540i
WOW that is clean. Not a head gasket, somebody really wanted to make some money I guess. As others said likely a valve cover gasket or a seal.
Old Yesterday, 06:19 AM
SamD SamD is online now
Learning Every Day
Mein Auto: 01 540i Sport 6-spd
I know you're working on an I6, but on the V8s, where the VANOS solenoids come through the front timing covers, the gasket(s) can leak there (mine are doing that now), so look for that too, a leak near the VANOS solenoid gasket...
'01 540i-6 Sport
...more fun with DSC off...
