F31 Tire question - Bimmerfest - BMW Forums
Old 05-18-2019, 09:37 AM
LAE LAE is offline
Mein Auto: 2016 F31 328d
F31 Tire question
Have a F31 328d with 225x45-18 run flats. Time for new rubber and do not like the lack of rim protection. Looking at 245x45-18 (0.6" larger OD) and 255x40-18 (same OD as OEM). Same tire all around. Has anyone tried either combination?
Not worried with rim width as Tire Rack & Discount tire mfgrs say the 245 or 255 will go on the 8" rim. (I have a S2000 AP1 with 225/245 on 6.5"/7.5" rims with good results.)
My biggest question will be steering feel with the 255s
Also, run flats - considering non-run flat and carrying a plug kit/w compressor and fix-a-flat can for an extreme case.
Old 05-18-2019, 12:58 PM
floydarogers's Avatar
Pedant and Curmudgeon
You should really buy 17" rims and put on 225/50R17. IMO, 18" with OEM size 225/45R18 is fine for rim protection. I've never bent either set of rims that we have that size mounted on.
Whether RFT or not, you should carry pump and plug.
Old 05-19-2019, 06:43 AM
LAE LAE is offline
I agree with the pump & plug, always a good idea.
Rim protection, I should have clarified, it is more for curb rash than a bent rim. The tires and rim are almost in the same plane making curb rash very possible.
Old 05-19-2019, 07:19 AM
edycol edycol is online now
Mein Auto: 328i xDrive 6MT
17. Do not go 255/45. Your speedometer will go wild. You will gain much more with 225/50 R17. Cheaper tire, less weight, it will be more dynamic than 245/55, which is pretty much SUV tire.
Sent from my iPhone using Tapatalk
Old 05-19-2019, 07:23 AM
LAE LAE is offline
Would not go 255/45 as the OD is off by a lot. The 255/40 is spot on with the OEM 225/45.
Old 05-19-2019, 08:13 AM
You will loose a lot on dynamic and mpg.
Similar Threads
Which type JayDizzle92 E36 (1991 - 1999) 19 07-19-2012 03:47 PM
Need Urgent Help. basirbilal E36 (1991 - 1999) 11 01-13-2012 12:08 PM
95 e36 instument problems TK2145 E36 (1991 - 1999) 13 12-12-2011 09:32 PM
what are your thoughts ? PortugueseE360 E36 (1991 - 1999) 32 03-07-2009 12:16 PM
installin amp on 323i ssj92 E36 (1991 - 1999) 53 02-13-2009 12:42 PM
