Issues adding coolant - Bimmerfest - BMW Forums
Old 03-25-2018, 07:54 PM
Zephyrhills180 Zephyrhills180 is offline
Mein Auto: '02 325i
2002 325i automatic. Just flushed the coolant for some work, and replaced the expansion tank along the way. Everything went swimmingly until I had to add coolant again. I added it as per instructions online, and everytime i crank the vehicle and run it, the 'low coolant' indicator comes on, coolant excessively leaks out the expansion tank cap, and after about 20 minutes the vehicle overheats and i have to shut it off
any suggestions? it doesnt seem to be leaking anywhere else
Old 03-25-2018, 08:11 PM
Mein Auto: '02 325i
The coolant light went off, but it just kept leaking coolant everywhere until it came back on, what the hell
Old 03-25-2018, 08:25 PM
Fast Bob's Avatar
Fast Bob Fast Bob is offline
Keeping it surreal
Did you bleed the system ? If yes, explain in detail exactly how you did it.
The road goes ever onward....
(R.I.P. Jever)
Old 03-25-2018, 08:50 PM
Mein Auto: '02 325i
Bob, I removed the bleeder screw from the engine block, undid all the hoses from the radiator & expansion tank, and unplugged the ATF heat exchange from the radiator, as well as unplugging all the electronic components, then took the expansion tank out, in that order. I then replaced the radiator support, which is why i did all this in the first place, then put the radiator back in, put all the hoses onto it, put the new expansion tank in and so on..
Old 03-25-2018, 09:17 PM
Fast Bob's Avatar
Keeping it surreal
But DID YOU BLEED THE SYSTEM (to get the air out) after the work was completed ?
THAT'S what I wanted explained....
(R.I.P. Jever)
Old 03-25-2018, 09:35 PM
Mein Auto: '02 325i
Bob, yes, somewhat. I first was going off of 50s Kid's radiator replacement video on youtube, which is pretty vague in the segment about adding coolant. So, I removed the cap and bleed screw. Poured in coolant 50/50 until i saw it flowing through the upper hose and the red float came up. I then put the cap and screw back on, cranked the vehicle, and coolant was coming out of the cap, so i removed the screw and coolant was gushing from the screwhole, as well as steam and pressurized air. i let it run until it was no longer doing this, then turned it off, let it cool, and topped the coolant off.
I then cranked the vehicle and took it for a test drive, and voila, coolant indicator comes on, and coolant is coming out of the cap. stop the car in my driveway and let it run for a bit to let it do its thing, and it overheats so i have to switch it off. keep topping it off and repeat this 2 or 3 times, and now the indicator wont be on, but coolant will come out the cap until it comes back on
Old 03-26-2018, 12:49 AM
marcozandrini marcozandrini is offline
Mein Auto: 2018 M240i
Did you buy a new ET cap?
Old 03-26-2018, 06:45 AM
Aaustins14's Avatar
Aaustins14 Aaustins14 is offline
Mein Auto: '02 325ci
100% need a new expansion tank cap. Thatíll get ya back up and going.
Just a rule of thumb to always replace the cap with the tank.
Old 03-26-2018, 07:03 PM
Mein Auto: '02 325i
Just placed an order for one
thx for the responses
Old 03-28-2018, 09:11 AM
Dave1027 Dave1027 is offline
Mein Auto: '06 IR 330ci zhp
Also use this bleed procedure. It can't go wrong. http://forum.e46fanatics.com/showthread.php?t=1124821
Old 03-28-2018, 01:48 PM
smolck's Avatar
smolck smolck is offline
ROLL TIDE!
Mein Auto: 2003 330ci (5 speed)
Bleeding an E46 is so simple, everyone makes it too complicated. You simply open the bleed screw on the expansion tank, turn the car key to accessory position, run heater to 90 and then add coolant slowly till it comes out the bleed screw hole. When it does, tighten the screw and put the cap in, you're done. Been doing it that way for 12 years, never had a single issue, and that's a LOT of e46s I've fixed.
Old 03-29-2018, 10:24 AM
Aaustins14's Avatar
Thank you Smolck.
I did it the exact same way.
Did it once. Never touched it again.
Donít over engineer a simple procedure.
coolant, coolant flush, expansion tank cap, expansion tank failure, radiator
