Correct & complete OEM aux Retrofit install - Page 16 - Bimmerfest - BMW Forums
Old 04-03-2018, 05:27 PM
oskino222 oskino222 is offline
Mein Auto: bmw e65 750i 2006
Still hoping someone can code my MMI
Sent from my SM-G955U using Bimmerfest mobile app
Old 04-03-2018, 05:34 PM
NYC760 NYC760 is offline
Mein Auto: Seeking 760li (e66)
What happened with Peter? I DMed you his phone number.
Old 04-05-2018, 04:17 PM
nyc760 big thanks to u bro i meet peter today drove 150 miles from pa to ny and his the best
Old 04-05-2018, 04:18 PM
he did a few more mods as well i found out that my cable doesn't work its the right cable but there must be a wire mixed up he tried it and never linked
Old 04-05-2018, 09:28 PM
Glad it worked out. My cable cable from Amazon and the plastic tab was set to fit into the wrong spot in the back of the CD unit, I tore off the plastic ridge with pliers and plugged it into the other correct socket abs it works fine. You also need to have the CD unit from mid-06 or later, mine was early 06, a very easy swap to fix, albeit a costly part.
Old 04-05-2018, 09:31 PM
Jeeze, auto spell correct did a number on my last reply, lol. Fyi, if you select the aux input from the mmi and DON'T see the aux-volume option on the right side of the display then your CD unit is the older pre mid 06 style and needs to be upgraded.
Old 09-24-2018, 10:40 AM
KEYTOTHEBEEMER KEYTOTHEBEEMER is offline
Mein Auto: 2004 745Li
Hey Paper question, I have a 04 745li can the parts come from a 07 or 08 750li/i or it have to come from a 745li/i in order to have the AUX option?
Old 10-27-2018, 06:49 PM
itsmeVeeraM itsmeVeeraM is offline
Mein Auto:
Thanks for the detailed video and instructions, @PAPER!
I followed everything that was mentioned on this page. Aux cable also installed into ASK unit as described (Pins 2,7&8),, and coded 'AUX' option is also showing up on my MMI. But, audio is not playing via AUX option (nothing is changing on screen, when I select 'AUX' option).
Please help me, if you ever faced this problem.
Thanks in advance.
Old 10-27-2018, 09:23 PM
When you select aux, do you have the option to adjust the aux volume in the mmi display? If not, your dash cd unit is too old - swap it for an 07/08 unit and it will work plug and play without any additional programming.
Old 10-27-2018, 10:38 PM
Mein Auto:
Thanks for the quick reply.
I don't see anything changing when I click the 'AUX' option. I think I might need to change my ASK Unit.
Can you/someone let me know, where can I buy a 07/08 ASK unit? I can't able to find one on Ebay.
Any information is much appreciated.
Thanks!
Old 10-28-2018, 12:06 AM
PAPER's Avatar
PAPER PAPER is offline
CRISP & CLEAN
Mein Auto: Ford Pinto
Thanks in advance.
If you followed everything on this page you're AUX would be working ...
what year & model is you car ???
Old 10-28-2018, 12:15 AM
Mein Auto:
2006 750i (E65). My ASK unit has a manufactured date on it 13-07-2005.
Old 10-28-2018, 04:37 AM
My ask unit was newer than yours in my '06 and I had exactly the situation you described, bought an 07 (or 08?) unit from ebay and it worked perfectly. As soon as it was installed there was an mmi option for aux volume in the aux panel.
Old 10-31-2018, 06:25 PM
Mein Auto:
I swapped my Radio Unit to a 08 one, and the AUX is working perfectly now.
Thanks for the help, @NYC760 & @PAPER
Old 10-31-2018, 09:15 PM
PAPER's Avatar
CRISP & CLEAN
I have another question regarding Android Monitor installation. Please help me, if anyone installed AVIN 8.8'' Android Monitor on 2006 E65. I got everything working except the sound from android monitor, but my Aux is working fine if I'm in old MMI screen. ptical Fibre Cables are also swapped from original main harness to the android power harness.
I know this is a different thread, but appreciate if I can be guided to a right thread.
Thanks!
YOU will probably get more help if you ask your question in the Avin 8.8 topic
Old 11-01-2018, 08:18 AM
Mein Auto:
@PAPER & @NYC760, I have just found that even though my AUX is working fine after new 08 ASK swap, FM and AM are not working with this. They are working fine if I go back to my original ASK unit, but AUX is not working with original one.
Did I miss anything? Or should I still need to code something after swapping to new ASK unit?
Old 08-17-2019, 09:21 PM
745D 745D is offline
Mein Auto: 745Li
Question, I have a 2006 750Li. I coded the MMI and the ASK unit for aux but didnít get the volume control on the MMI when selecting aux. so I upgraded the ASK unit to a new model and the aux works but it only plays the highs, no bass. Could the problem be with the MMI being that I didnít change it to a newer year as well? Or is it something else?
Old 08-17-2019, 11:40 PM
Likely cause is a bad connection somewhere in the audio plugs, initially try swapping the audio cable that you're using from the aux, try playing from a different source device, don't use Bluetooth anything as a test device. Also, check that your bass and subwoofer settings are actually on max when in aux mode input.
Old 08-18-2019, 08:11 PM
Mein Auto: 745Li
I tried everything you've mentioned. No change. When the music plays it has plenty of highs and mids, but no bass. Bass is there but it's like it's struggling to get out.
Can you or anyone tell me what modules need to be coded and what changes are to be made in the coding?
Update: after some experimentation I found that there is an EQ on the iPhone 7 that needs to be changed to bass booster within the music app that gave me more bass. Still not 100% in my book but it's better than what it was.
Would still like to know what modules need to be coded and what coding should be done to them.
Old 08-19-2019, 10:49 AM
PIFOUBMW PIFOUBMW is offline
Mein Auto: E65 745I 01/2004
It seems that some AUX cable to connect at the rear of the ASK has resistor/capacitor and some other none of that. then some cable can filter some sound.
Old 08-19-2019, 11:12 AM
Mein Auto: 745Li
Where would the resistor be located?
Old 08-20-2019, 06:14 PM
Mein Auto: 745Li
Has anyone cut the resistor out of the aux cable? What happens? Does it still work?
Update: cut the resistor out and everything works as it should. Bass is now there. Want to thank PIFOBMW for mentioning the resistor in the cable.
Old 09-01-2019, 05:35 AM
irish745 irish745 is offline
Mein Auto: E66 760Li individual
Can anyone with a car with factory aux list their fa order please .i want to see if their is a fa option or service code for aux .as i prefer to code the fa order and default code whole car everytime i change or add features to my cars and im sick of having to recode certain cosing due to not be original but if i can add to fa order in the future it would speed things up
Sent from my SM-G390F using Tapatalk
Old 09-01-2019, 09:14 PM
PAPER's Avatar
CRISP & CLEAN
Add this to your FA/VO
+NAUX
Old 09-01-2019, 11:53 PM
Yeah thanks paper ive tried that along with +ipod and both say invalid for fa order .id say its because this is on a 2003 car .but if i fake change the build date and fa order and dont write it .it works then .but if i write it permanently to my facelift cars it works fine .thanks for the reply
