2007 BMW X3 2.D good buy? - Bimmerfest - BMW Forums
Old 09-08-2019, 12:05 PM
HellfireZA HellfireZA is offline
Mein Auto: Fiat Bravo 1.4Tjet Sport
My girlfriend is looking at a specific 2007 2.0D X3, the car seems to drive pretty well with no warning lights but there's a section on the lower center console which doesn't seem to work, none of the buttons light up or seem to respond.
Also if you start the car in reverse or put it in reverse as you start the car the rear PDC works, after that nothing, nor front or back work.
Old 09-08-2019, 12:26 PM
BimmurBrothor's Avatar
BimmurBrothor BimmurBrothor is offline
BeeemerBro
Mein Auto: X3 M54 150k
Here's a good conversation:
https://www.bimmerfest.com/forums/sh...php?p=12414318
More info...
Sent from my SM-G531H using Tapatalk
[FONT="Arial Black"]
Old 09-08-2019, 12:43 PM
Appreciate it thanks
Old 09-08-2019, 02:01 PM
Still can't find any info on that specific "panel", does someone know the actual name for that section?
Old 09-08-2019, 06:20 PM
CoolShirtDude CoolShirtDude is online now
Mein Auto: 2011 BMW X3 2.8i F25 N52
Take a look at realoem.com
Are your talking about the console switch panel?
If the diesels are like their gas counterparts, start with battery voltage and bad engine grounds. When battery voltage gets low, some items may get powered down.
Driveshaft may be another area to check, if you can look at the ujoints, if they are covered in rust, more inspection is needed.
2011 BMW X3 2.8i (F25) N52
2015 BMW 328i (F30) N20
Old 09-08-2019, 09:43 PM
BeeemerBro
Consider this...
Old 09-08-2019, 11:29 PM
I've highlighted it in the picture above.
Great thank you, I did think it may be battery related but seems unlikely the entire panel wouldn't respond
Old 09-09-2019, 04:12 AM
Q4's Avatar
Q4 Q4 is offline
Mein Auto: 2008 x3
Might just be a bad switch panel.
https://www.ebay.com/sch/i.html?_fro...temCondition=4
https://www.realoem.com/bmw/enUS/par...&q=61319131527
Tim
Cincinnati
Old 09-09-2019, 06:01 AM
jeepo23 jeepo23 is offline
Mein Auto: 2008 X3, 6 Speed
What do you mean, if you start in reverse you hear the PDC work, then nothing?
The way the system works. It's activated when going into reverse. Stays on if your in reverse or go into first gear as long as your below a certain speed at which after you reach maybe 20km/hr the system turns off.
What kind of dash is that? Is that a little nav screen? I like that steering wheel!
Old 09-09-2019, 06:10 AM
Q4's Avatar
Q4 Q4 is offline
Mein Auto: 2008 x3
The steering wheel is a standard sport package wheel.
I'm very curious about the radio as well. It looks like a stock brochure photo from a 2010 model.
Tim
Cincinnati
Old 09-09-2019, 06:56 AM
What I like about the wheel you can see the extra padding and its the newer style leather vs. what my 08 X3 has.
Old 09-09-2019, 09:50 AM
I mean I just used this pic to show the bottom panel, I'm sure for advertising reasons they've used a fully equipped model with M extras haha.
Old 09-09-2019, 10:55 AM
Q4's Avatar
Q4 Q4 is offline
Mein Auto: 2008 x3
It also has an alcantara armrest.
The headlight switch includes a rear foglight button, speedometer is in kilometers and the radio knobs have the metal trim rings so it must have been a European press photo for a 2010 model.
Tim
Cincinnati
