What mod would you do next? N54 335i - Bimmerfest - BMW Forums
Old 09-15-2019, 09:24 PM
TypeGrrr TypeGrrr is offline
Mein Auto: BMW
I would like to start adding power...
If you had a fully maintained n54 with charge pipe, k+n filter, jb4. What mod would you do next? You may state more than one modification however I can only choose one.
Current peak boost: 16psi
Old 09-16-2019, 12:55 AM
CALWATERBOY TRE's Avatar
CALWATERBOY TRE CALWATERBOY TRE is offline
Mein Auto: E93 335i, somewhat mod
By 'charge pipe' do you mean metal charge pipe?
I'd....deep six the K&N filter
I'd....look into MHD to stack w/JB4
I'd....deep six runflats for top drawer Michelins
I'd....mod your suspension for linearity & so it can go around a corner
I'd....get a Limited Slip Differential
I'd....be very careful about more power until you understand the risks
Um....what model year is this?
Old 09-16-2019, 10:46 AM
El Goodo's Avatar
El Goodo El Goodo is offline
Mein Auto: 2009 M3 Sedan, Auto
IC Upgrade
2009 M3 Sedan, Auto, Silverstone II Metallic, Stock
2007 335i Coupe, Auto, Monaco Blue Metallic - ARM Motorsports Intercooler and catless downpipes, Cobb charge pipe, Forge diverter valves, Dinan springs, MHD Stage 2+, 19psi
Old 09-16-2019, 11:17 AM
Yukoner Yukoner is offline
bimmerfest Supporting Member
Mein Auto: 2011 328i x-drive
When you say "K&N filter", do you mean a done-cone intake ? Or do you mean you're using the stock airbox with a drop-in K&N air filter ? If it's the latter, then I'd suggest an actual, complete intake replacement.
Otherwise,
- Catless downpipes
- Upgraded FMIC (intercooler)
- MHD or COBB tune
Not even sure if -40 degrees is cold anymore ?
