Rookie's 2 years ownership cost for a E83 - Bimmerfest - BMW Forums
Old 09-14-2019, 08:40 PM
kind16 kind16 is offline
Mein Auto: X3
Bought the car in Jun. 2017 at 87K km
Jan. 2018
Final Drive Assembly
Sub Total 2,226.69 CAD
June. 2019 Indy.
Rear rotor 400+tax = 452
Cabin filter
Rear Pad 210+ tax = 227.3
Valve cover gasket 610.16 + tax = 689.48
Sub Total, 1140 CAD
June. 2019 DIY
Added Kiney grill color inserts to made it looking better
Sub Total, 20 CAD
Sept. 2019
6.2 Liter Engine oil + filter DIY = about 80 CAD
CASTROL EDGE 0W-40 BMWLL01
Sub Total, 80 CAD
Sept. 2019
Transfer case fluids flush DIY
TRANSFER CASE FLUID TF0870,1L
Sub Total, 40 CAD
TOTAL, 3400 CAD so far
TO DO items,
Change Transfer case fluids DIY
Change Rear diff oil DIY
Change front breaks pads and rotor DIY
Change 4 tires COSTCO
Change Rear Main Seal or oil pan gasket (Not head gasket, communication issue, my fault), but indy said let it leak for couple years...
Millage in km,
Jun2017-87K,
Jun2018-94K,
Nov2018-101K,
Jan2019-105K,
Sep2019-112K
2010 X3 28i Black, Engine N52B30 AT
(Millage Sep2019-112K km)
2015 Dodge Caravan, AT
(Millage Sep2019-30K km)
Old 09-14-2019, 09:29 PM
Autoputzer Autoputzer is offline
So, that's about $0.22/mile for maintenance and repairs. That's high, and would be psychologically painful. But, less so when you consider was deprecation on a new X3 would be.
Frau Putzer's 2018 X3 depreciated just about $10k in the first year and 10k miles, $0.992/mile. The second year should be down to about $0.50/mile.
Old 09-15-2019, 12:37 AM
dukedkt442 dukedkt442 is offline
Location: Hudson Valley/LI, NY; Treasure Coast, FL; OBX, NC.
Mein Auto: X3, 442, S15, Silverado
If your head gasket is leaking, your engine will die VERY soon. If you had to pay someone to do the work you did, you will NOT be doing a head gasket yourself.
Find a new mechanic, because he just told you to possibly destroy your engine.
Old 09-15-2019, 05:00 AM
Mein Auto: X3
The INDY said it will cost $4000 CAD for a head gasket replacement. How much for a used engine?
I will closely monitor the engine oil level, I checked the engine oil level every single week. Previously, it totally leaked 3 Liter of engine oil with head gasket leak and valve cover gasket for last 2 years. Now VCG was fixed and not leaked any more. Let me see how much oil will it leaks for one year with only head gasket leak. The INDY said it is very minor. Thanks.
Old 09-15-2019, 05:05 AM
Mein Auto: X3
Yes, much better than a new one. Plus the car purchasing cost, it is about 18300 CAD, I am happy about it, just try to make the cost less and less when me and E83 getting older and older. Thanks.
Old 09-15-2019, 07:40 AM
Do either you or your mechanic know what a head gasket does?
Old 09-15-2019, 08:31 AM
smaglik smaglik is offline
Mein Auto: 2007 X3, 2003 M5
I was thinking the exact same thing.
OP, these engines aren't known to have head gasket issues, unless overheated at some point. If the head gasket is leaking, it needs to be addressed ASAP, as some chemicals in engines are not meant to mix...
2003 M5
2002 M3
2007 X3 6MT
Old 09-15-2019, 08:32 AM
Maybe he meant the valve cover gasket.
Old 09-15-2019, 08:49 AM
Mein Auto: X3
No, I don't know. I will call the INDY.
Thank you for the help.
Old 09-15-2019, 08:51 AM
Mein Auto: X3
VCG has been replaced with the cost of about 690 CAD 3 months ago. I will call the INDY and let you guys know. Thanks.
Old 09-15-2019, 08:54 AM
Mein Auto: X3
Maybe it is not head gasket, I will call to confirm, but it should be still leaking somewhere. I just changed engine oil last week by myself, no mixed chemicals.
Old 09-15-2019, 09:52 AM
Iím betting the actual expensive leak is the oil pan gasket... a head gasketís primary purpose is to seal in the products of combustion and preserve compression. Preventing oil/coolant mixing goes along with that goal. Weíve replace dozens of head gaskets over the years, and I canít think of one that manifested itself with an external oil leak.
If you have oil in your coolant, well... itís time to rip the thing apart... And not overheat it in the future.
Old 09-15-2019, 07:19 PM
Mein Auto: X3
My INDY replied my email. It is not head gasket leaking. He said it is main seal, between engine and drive shaft? I don't know what that it is.
Very minor, can held for couple years first. I will monitor the engine oil level see if I need to refill it in future. Thanks.
Old 09-16-2019, 01:03 AM
Burning2nd's Avatar
Burning2nd Burning2nd is offline
Under the lift arms
Mein Auto: e39, e83, e60
oh god... get rid of the thing
dont go back to that person
Specializing In Breaking Things Professionally
15486372<-----
Old 09-16-2019, 03:02 AM
abscate abscate is offline
Mein Auto: 2006 BMW X3... VOLVO... V
22 cpm is decent for paid work with some refurbishing expense on a new to you car.
A rear main engine seal is a good one To learn about and practice to do yourself. It's stupid work worth $10 an hour, not$100.
Old 09-16-2019, 05:08 AM
One that requires pulling the oil pan and transmission on these it seems.
If it is leaking, the pan most likely is too.
Old 09-16-2019, 09:43 AM
Attacking Mid's Avatar
Attacking Mid Attacking Mid is offline
Mein Auto: 04 X5 3.0i, 08 X3 3.0si
Shouldn't have to pull oil pan to do the rm seal. I suspected my rm seal was leaking prior to doing my oil pan gasket. It wasn't. The way these oil pan gaskets fail, you can end up with oil all over the place, but especially the rear corner of the oil pan where it looks like it might be running down from the rm seal. My bet is you've got an oil pan gasket failure that is fooling your indy (not that he's a fool - oil leaks can be very deceiving). The oil pan gasket on the N52 is simply not robust enough to last for a long time. It uses a very thin rubber that hardens over time becoming incapable of sealing.
AM.
Old 09-16-2019, 10:22 AM
Mein Auto: X3
Thank you guys so much for the help. Now I knew 2 more probably leaks, REAR MAIN SEAL or OIL PAN GASKET
I will do some oil cleaning this weekend using brake cleaner. Then check where the oils comes from. After VCG was fixed, not much oil leak noticed ...
Old 09-16-2019, 10:33 AM
Mein Auto: X3
$10 an hour? In my dream...
By the way, what is 22 cpm?
Old 09-16-2019, 10:45 AM
Mein Auto: X3
AM.
Found your post about 2 years ago back in 2017.
Really hopeful
Mine is also leaking from either/both the rear main or oil pan. Both are major jobs to fix, so I begrudgingly live with the drips on the garage floor. Some have had luck in replacing or re-torquing the oil pan bolts, but that didn't help mine. There are threads discussing the job of replacing the oil pan gasket if you search. Replacing the rear main will mean removing the transmission (or engine). Either job is probably an all day or all weekend affair for the DIY'er.
AM.
Old 09-16-2019, 10:55 AM
Mein Auto: X3
See this reply from other post, pretty much the same opinion as my INDY.
https://www.bimmerfest.com/forums/sh....php?t=1183385
Originally Posted by Sammy49 View Post
I made the same discovery on mu 2007 X3 si and took it in to an indy I trust. They re torqued the oil lan slightly. He said the job is so big and the leak so minor it's best to leave it alone for now. I have 115K. This was two months agoand the car hasn't really needed any oil so I think he was dead on.
Sent from my iPhone X using Bimmerfest mobile app
Old 09-16-2019, 11:52 AM
C-Bass C-Bass is offline
Mein Auto: 04 325i Touring/07 X3si
Just to give you an idea, a used engine will cost about $1200-1500 CAD depending on how many km it has.
There is a place in Milton that you can get it from. The owner is a super good dude and huge BMW enthusiast
Old 09-16-2019, 12:03 PM
Mein Auto: X3
Wow, Thats a really good price for an used engine. Can you ping me the owner in Milton? Thanks. I am not using it now but just keep it for future.
Old 09-16-2019, 01:50 PM
AM.
You may be right on the pan, front seal doesnít require it, but definitely need to pull the trans.
Sent from my iPhone using Bimmerfest mobile app
Old 09-16-2019, 06:42 PM
Mein Auto: X3
Pull or Swing an engine or transmission is out of my ability for now, maybe my indy is not able to do it neither.
