200 E39 plethora of symptoms, unsure what to do - Bimmerfest - BMW Forums
Old 11-16-2017, 07:41 AM
pingti3 pingti3 is offline
Mein Auto: 1997 528i
Hello, I feel like I have enough random symptoms, that i need to start a new thread.
2000 BMW 528i 94000 miles owned for 8 years. Recently replaced secondary air pump--sounded like a jet, secondary air pump valve--bad advice, and one of the o2 sensors--up top near front of engine, and valve cover for oil leak.
Symptoms:
At cold starts--but not every time, I get a rough idle and a check engine light. may smooth out, may not--after thirty or so minutes, almost always smooths out.
Demonic wailings or bad alternator bearing sound--comes and goes cannot pinpoint any specific causes. Has done this about five or six times over the last few weeks. It makes no sense to me. Checked power steering fluid btw thought might be power steering pump. seems to do it more with the rough idle
o2 sensor codes have popped up. Rough idle codes saying cylinders 1 and 3 misfire
those are gone now as far as I know
codes p1189,p1188. p1622 popped up on scanner, but no check engine light on currently
Took it to a mechanic, did vacuum leak test and he said "somewhere around the intake manifold" and stated I would replace the intake manifold gasket, the tube that goes to the top of the intake manifold, and the THERMOSTAT????? I think he means the temperature control sensor.
Think this is it.
Do i replace the intake manifold gasket, even though he does not sound definite? Did not hear screeching? Or, Ideasssssss?????????
Old 11-16-2017, 08:09 AM
BrothaMansWhls BrothaMansWhls is offline
Mein Auto: 2000 528i
Symptoms:
Think this is it.
Wowza! Got alot going on. Have you pulled any vids of the issues? Youtube is a great resource for e39 issues. Also have you cleared the codes?
Sent from my LGLS755 using Bimmerfest mobile app
Old 11-16-2017, 09:08 AM
Thanks, yes, i have checked youtube. One problem can be solved by a video, but the combination of the symptoms makes it complicated. Just don't want to part chase. Seems like a vacuum leak by reading posts, but a leak does not seem to account for all the symptoms and the way the symptoms are are sporadic.
Old 11-16-2017, 09:13 AM
Also, one more symptom. After sitting overnight, starts pretty okay--sometimes rough--it has a about a 20 second gap where runs fine, then the engine surt of surges with a brief bit of acceleration. Then it drops off, and after 20 seconds sort of accelerates again--adds fuel I am thinking. Subtle, but it will "lurch" a bit if brake is not fully depressed. .....
check engine light, codes, engine noise, misfire, vacuum leak
