Surging/jerking upon acceleration / gear changes - Page 4 - Bimmerfest - BMW Forums
Old 07-29-2018, 08:33 AM
BMWaufKS BMWaufKS is offline
Mein Auto: 2008 X3
Just tried a number of coil swaps, including using three old coils in bank #2 (ran worse; might be a bad coil in that lot). Currently have the bank #1 and #2 coils (three each) swapped; no change in idle quality from yesterday or immediate change in the short-term mg/s fuel injections. Ground straps through the N52 valve covers are installed fine, and test as conducting.
Since 1/2016, restoring a
2008 BMW X3 M-Sport, N52, automatic ("#1")
Modifications:
All stock except dashcam
Since 3/2017, also restoring a
2008 BMW X3 base-model, N52, automatic ("#2")
Modifications:
Dashcam, cargo cover, cargo mat
Old 07-29-2018, 11:50 AM
abscate abscate is offline
Mein Auto: 2006 BMW X3... VOLVO... V
smoke test....smoke test....smoke test
...drum beat...
Old 07-29-2018, 12:38 PM
BimmurBrothor's Avatar
BimmurBrothor BimmurBrothor is offline
BeeemerBro
Mein Auto: X3 M54 150k
New position sensors?
Sent from my SM-J727T using Bimmerfest mobile app
[FONT="Arial Black"]
Old 07-29-2018, 01:59 PM
Mein Auto: 2008 X3
...drum beat...
Done a few times already ...
Modifications:
Modifications:
Old 07-29-2018, 02:00 PM
Mein Auto: 2008 X3
Which one(s) would most likely give these symptoms?
I did just swap out the MAF sender (aftermarket one) -- no change.
Modifications:
Modifications:
Old 07-30-2018, 05:16 AM
BeeemerBro
Sound Familiar? ??
https://www.bimmerfest.com/forums/sh....php?t=1282604
Sent from my SM-G386T using Bimmerfest mobile app
Old 07-30-2018, 08:37 AM
Mein Auto: 2008 X3
Not exactly, but interesting.
Mentioned is a separate air temperature sensor -- I'm not finding such on our X3's N52, except for the cabin's (where's that installed)? Maybe our MAF includes that function (and already replaced). I am seeing a differential pressure sender on the intake manifold (via RealOEM).
What's the symptoms of a failing DISA on these N52s? I know they are a big problem on the M54s.
Modifications:
Modifications:
Old 07-30-2018, 08:57 AM
swampX3 swampX3 is offline
Mein Auto: bmw++many
I'm not finding such, except for the cabin's
>the evap/internal is often located just behind the radio etc ....the radio / IHKA/HVAC stuff can be popped out easily ....or you can "see" the sensor output realtime in INPA or ista+
>the external temp sensor troublemaker that gets roughed up is shown below....repair kits are available ....BUT ....you can also "see if its ranging OK with INPA or ista+ etc
Old 07-30-2018, 08:59 AM
MAF ...what make
>you swapped the MAF for an aftermarket unit .....these can often be duds ....check the make and ensure its an OEM supplier like bosch/siemens etc
Old 07-30-2018, 09:03 AM
you probably have 2 DISAS
>as well as the outside of the intake disa there is a smaller disa tucked under the intake ....you can easily check their actuation with ista+
>the fail symptoms can be all over the place.....but ....we've found low power to be a regular thing....and ....the guts on the later 52 engined disas are more robust that the 54 engines
Old 07-30-2018, 09:20 AM
"seeing" your temp sensors
>some good views/tips of looking at your sensor outputs in realtime with INPA etc.....saves loads of guessing
>you can also graph the outputs with other easily available software/plus freeze frame when problems/anomalies arise
>VERIFYING SENSORS etc
Name:	Screen Shot 2018-05-29 at 5.34.59 PM.jpg
ID:	810170   Click image for larger version
Name:	INPA EVAP TEMP.jpg
BeeemerBro
Investigated some time ago....see...https://www.bimmerfest.com/forums/sh....php?t=1269554
Old 07-30-2018, 09:30 AM
the 2 disa intake manifold
>generic 06-10 ish x3 intake showing both disas...parts 2 and 3
https://www.realoem.com/bmw/enUS/sho...diagId=11_3756
Name:	Screen Shot 2018-07-30 at 11.28.22 AM.jpg
Old 07-31-2018, 06:03 AM
BeeemerBro
Several months ago i installed an aftermarket maf ($20) on the 05...instantly after turning on the ignition the X3 rejected it with a code and rough idialing...without hesitation I installed the OEM ...will not do that again.
05 X3 181k
04 X3 162k
Old 08-09-2018, 05:15 AM
BeeemerBro
Possibly Helpful...
m.carcomplaints. com
A lot here...Research your model or future model see what are known flaws, tendencies and corrections all at one site.
Do your research.
05 X3 181k
04 X3 162k
Old 08-10-2018, 12:02 AM
BeeemerBro
Originally Posted by BMWaufKS View Post
Thanks. Car is sitting; too many other projects right now.
no more from me friend
Old 08-22-2018, 03:26 PM
Mein Auto: 2008 X3
Unhappy The plot thickens (even more ...)
Had only a little bit of time to work on it, and got unexpected results.
Started and ran well (sitting in the driveway). I retook the F/A trims:
700 RPM Bank 1 Bank 2
Short-term 0.23 0.17 mg/s
Long-term -15.13% +292.72%
2500 RPM
Short-term 0.06 0.04
Long-term same as above
Then one last try on the coils: I swapped the rear three with the front three, expecting no change. Wrong! Varying idle, some misfires, and the 29E1 and 29E0 "mix control" errors within the first minute. Cleared those and restarted, codes did not return, the idle cleared up, but then got poor again. Trims were now:
Short-term 0.76 0.64 mg/s
2500 RPM
Out of time now, but the next thing I'll try is swapping three coils from X3 #2 to see the effect.
Modifications:
Modifications:
Old 08-24-2018, 11:16 PM
BeeemerBro
I'm now I think experiencing a small kick (knew i should have stayed away from this thread) ***128514;at 10 to 15 miles per hour just as I'm taking off from the line and then normal smooth. I'm first thinking low trans fluid...just before noticing this...the trans oil cooler popped off...I went into emergency mode to correct it. Never the less I have a suspension that it might be the center bearing....no lights or codes...could this be a slight misfire?
05 X3 181k
04 X3 162k
Old 08-25-2018, 02:29 AM
2500 RPM
2500 RPM
Find your vacuum leak!
How bout the intake snorkel? Has that been replaced?
Old 08-25-2018, 04:31 AM
Mein Auto: 2008 X3
Smoke test done three times, with other small leaks found/repaired. No leaks from this N52's boot (much more of a problem on M54s I see), and it seems that would add excess air to both banks, not just one. Before the latest weirdness of the coils' swap, I was thinking a bad fuel injector so headed that way.
Modifications:
Modifications:
Old 08-25-2018, 07:57 AM
Mein Auto: 2008 X3
Just pulled and inspected the intake boot (just after the MAF sender). It's fine.
Getting it off then later back on the lower nipple is a little challenging, while not putting pressure on the flex part of the boot.
P.S. Took it for a ~4 mile drive, and it did well. It has been a long time. After returning, the long term trims were +14% and +84%. Idle got ugly, though, after a restart, but no error codes. Will hopefully drive it more this upcoming week to see what happens.
Modifications:
Modifications:
Old 08-27-2018, 02:22 PM
Mein Auto: 2008 X3
Well ... did OK this morning (maybe 80F, no A/C), but on the way home (~5 miles, 95F, A/C on) it stalled at the last stop (first time ever). Restarted easily.
Reading about INPA, and will likely order a cable soon.
Modifications:
Modifications:
Old 08-27-2018, 02:52 PM
put the scan master on your read list too
>yes get INPA and ISTA+ and build your ability.....BUT.....put the scan master on your read list too.....with it you can graph/track/freeze frame that you cannot easily do with the other stuff ....a must have investment
>a good fiftees kid video on the scan master to track O2 sensors/cat converter performance etc
O2 SENSORS/SOFTWARE/ CAT PERFORMANCE/FIFTEES KID/AUG 2018
Old 09-15-2018, 11:20 AM
Mein Auto: 2008 X3
Exclamation Finally!
Got INPA installed and running; what a PITA.
Shows no current errors in the engine (N52, MSV80).
History gives 10 codes total, with the first three repeated. I don't know how many are ancient and maybe previously fixed??? The words for each error, on the right, are from various webpages and not specifically the N52/E83, so I don't know if they are correct. But if so, any of the below make sense for my symptoms?
11529 0x2D09 Throttle valve
11513 0x2CF9 TV potentiometer 1
11515 0x2CFB TV adaptation value
10721 0x29E1 Bank 1 charge air cooler temperature sensor circuit high
10720 0x29E0 Bank 1 charge air cooler temperature sensor circuit low
I'll take and post pics of the active O2/trim/etc. bar-charts/screens in the near future; out of time today.
Modifications:
Modifications:
Old 09-16-2018, 09:37 AM
Mein Auto: 2008 X3
Thanks -- that was helpful, and from that video and the following I deduce that the O2 sensors and the cats are fine, at least for now ...
From the last of the above INPA screens, while at 2000 or so RPM, the upstream O2 sensors were a bit jumpy and around 2.1 volts, while the downstream sensors were around 0.06 volts and quite stable.
Took it for a ~4 mile test drive, and it stalled once at a stop. Also generated a bunch of error codes including rough running of cylinders 4, 5, and 6. Also the 10720 and 10721 errors (fuel mixture control on banks 1 and 2).
From various websites with others trying to solve similar 10720 or 10721 problems, they say, generally: vacuum leak, O2 sensors, or fuel injector(s).
Because I hopefully addressed the first two, that leaves the injector(s). I'm going to guess that one in 4, 5, or 6 cylinder is dumping fuel. What say you?
Modifications:
Modifications:
