What did you do to your E83 X3 today? - Page 2 - Bimmerfest - BMW Forums
Old 06-04-2018, 07:56 PM
abscate abscate is offline
Mein Auto: 2006 BMW X3... VOLVO... V
Originally Posted by dukedkt442 View Post
Donít worry about it.
About 5 years ago everyone started fearmongering tire life and rot. Funny, since rubber quality is the best it has ever been
Old 06-05-2018, 02:04 PM
kind16 kind16 is offline
Mein Auto: X3
Originally Posted by BimmurBrothor View Post
The sunroof of the 04 is not closing properly. Investigation shows @ the driver side second glass (smaller) the lever does not slide down so the smaller pane doesn't close...i have to push it with screw driver to the end...lever is rusty unlike @ the passenger side...now ill research for the solution.
05 X3 181k
Unplug the sunroof and never use it again. Free fix.
Sent from my SM-G955U1 using Bimmerfest mobile app
2010 X3 28i Black, Engine N52B30 AT
(Millage Sep2019-112K km)
2015 Dodge Caravan, AT
(Millage Sep2019-30K km)
Old 06-05-2018, 02:05 PM
Mein Auto: X3
05 X3 181k
Unplug the sunroof fuse and never use it again. Free fix.
Old 06-05-2018, 02:06 PM
Mein Auto: X3
Thank you, will use the three years more.
Old 06-05-2018, 03:24 PM
BimmurBrothor's Avatar
BimmurBrothor BimmurBrothor is offline
BeeemerBro
Mein Auto: X3 M54 150k
yeah...ive heard that before...it would bother me that it's not functioning, especially knowing it is capable of functioning properly.
Sent from my SM-J727T using Bimmerfest mobile app
[FONT="Arial Black"]
Old 06-07-2018, 03:23 AM
BeeemerBro
just replaced the turn signal stalk the newer one has more clearer letters and symbols..tip...i covered the labels on both stalks with clear/transparent gorilla tape. *Warning! The tape is strong...The letter's paint is old and weak. So you must be accurate when laying the tape the first time...laying the tape down and picking it back up to replace second time probably will strip the lettering from the stalk's surface.
Old 06-07-2018, 06:01 AM
dukedkt442 dukedkt442 is online now
Location: Hudson Valley/LI, NY; Treasure Coast, FL; OBX, NC.
Mein Auto: X3, 442, S15, Silverado
Took several days, but finally successfully downloaded ISTA-D, configured settings so that my laptop (whose battery is shot and required an extension chord) so that it and the car could communicate, and reset transfer case and engine adaptations. The slight but annoying off-idle hiccup that's been with the car since 2012 has (::knocks on wood: gone away as a result. Also topped off and bled cooling system, as my lower pressure cap allows for increased evaporative loss.
I spoke too soon; new expansion tank and all associated parts currently on order.
Old 06-07-2018, 07:56 AM
DangermouseX3 DangermouseX3 is offline
Mein Auto: 2007 X3, 2008 X3
Got my emissions done yesterday despite having 6 warning lights illuminated on the dash , a personal record
4 for TC gear, 1 for pass seatbelt and 1 for low fuel (which is a bit of a cheat).
07 X3 3.0Si - AT - Black with tan leatherette interior - 141k miles
08 X3 3.0Si - AT - Black with black leather interior - 121k miles
Old 06-07-2018, 11:24 AM
BeeemerBro
I've got to do this...ill look you up then got the cord but nothing else.
Old 06-08-2018, 08:27 PM
tsuintx tsuintx is offline
Mein Auto: 06 325i and 99 R1100RT
Just your run-of-the-mill oil and filter change today. Drained the gasp non-LL01 rated 0W-50 Mobil 1 out and put the the same stuff in. Five quart jug is $22.88 at WalMart plus they also have a $10 rebate going on now that the earlier $12 rebate ended at the end of May.
Also needs a brake job soon (wear indicatorís been on for a while now), but didnít have the time to do it today since my daughter had to head back home. Maybe next time, when ever thatís going to be...
Tried resetting the oil service mileage with my Creator C310+, but to no avail. From what Iíve read, it should be able to do that, but it just keeps giving communication error, which doesnít make sense since I did check bunch of the modules for codes and cleared SES thatís on due to P0171 and 174. Really need to do something about those soon, too, since it needs inspection in August and changing the intake boots a few months ago didnít help.
No other codes in any of the modules. Well... Other than some weird one that appeared five times and just said ďno descriptionĒ.
06 325i
99 BMW R1100RT
Official mechanic of my daughter's 06 X3 (Chronicled here.)
Plus a bunch of others...
Old 06-08-2018, 08:41 PM
jdeday's Avatar
jdeday jdeday is offline
Send a message via AIM to jdeday
Mein Auto: 2005 BMW X3 3.0
I replaced the vacuum hose that connects to the exhaust butterfly valve to the control valve located in the left rear trunk compartment. Not that difficult of a job, you have to slide back the left side of the rear bumper to the gain access to where the hose enters the vehicle.
2018 X3 M40i Pythonic Metallic, Vernasca Black with Blue Stitching, Premium Package, Executive Package
2005 X3 3.0, Mystic Blue Metallic, Sand Beige Leather Interior, Birch Grain Light Wood Trim, Steptronic Transmission, Premium Package, Heated Seats, Privacy Glass, Satellite Radio Prep, Xenon Adaptive Headlights, Heated Steering Wheel, Premium Sound, Power Folding Mirrors and Navigation Retrofit
Old 06-10-2018, 08:26 AM
BeeemerBro
tail gate trunk release today on the 04.
I have to click the fob trunk release button sometimes up to five times or I have to time the click and my lifting almost instantly to get the trunk open.
well I look to put an end to that annoying functioning. in my research this can be a common issue for the x3. however, the 05 never gave me that problem. I have noticed on the 04 someone has lifted the rear hatch trim panel (that is not the location of the fix) but the rear latch floor panel is (Pelican Parts has a good repair writeup)
Pelican Technical Article - BMW-X3 - Tail Gate Latch Replacement
https://www.pelicanparts.com/techart...eplacement.htm
release switch has arrived yesterday
Look at this on eBay
https://rover.ebay.com/rover/0/0/0?m...2F152978857758
and today the 04 goes into minor surgery.
Old 06-10-2018, 03:00 PM
BeeemerBro
Minor surgery complete success.
05 X3 181k
Old 06-10-2018, 04:05 PM
jeepo23 jeepo23 is offline
Mein Auto: 2008 X3, 6 Speed
Finally replaced that squeaking drivers door strap. No matter what lube, grease or what I tried I couldn't silence it. Ended up finding a new strap on eBay for approx $30 so I replaced that today and now the door is nice and silent. Tried to examine the old one to see where it could be making the noise couldn't determine it. And the thing was covered with grease, fluid film, silicone you name it.
Then I washed the engine bay. Of course the before picture was just as I started..
ID:	800544   Click image for larger version
ID:	800546   Click image for larger version
Old 06-10-2018, 05:45 PM
Where in ISTA are the engine adaptations reset? Is this also achieved with a battery disconnect/reconnedt?
Old 06-11-2018, 06:06 AM
Under the power train menu somewhere. Iím no where near fluid enough in the program to walk you through it, just gotta explore. And no, battery disconnect wonít do it. Same with transfer case and transmission adaptation. Gotta erase them then let the car go to sleep before starting.
Old 06-13-2018, 03:16 AM
BeeemerBro
Removing the compressor today off of the 05 and making an order off of flee bay...another shot in the dark
05 X3 181k
Old 06-13-2018, 03:30 AM
eBay for a compressor? I would take harvesting from a junkyard so I can check for AC pressure to make sure it's dry.
Old 06-13-2018, 10:59 PM
BeeemerBro
Completed the oil change 0w 40 Mobil 1 05 is humming right along with it...I'll keep my eye on it...last time I used it was back in 2015...I also called Mobil 1...Rep was nice...said the bmw was taken off the label in that same year. he was not aware of a formula change. many details were up in the air...but the way our conversation went was that Mobil has made a submission for approval but bmw *1 is refusing to give approval or *2 is waiting for approvals to expire so they can touted one brand...who knows? But the Rep was dumbfounded just like us all...did you know BMW gets a cut of the price for just having its name on the label? And if you notice the price has declined for the 0w40 with out the bmw name listed on the front label. (Doing us a favour maybe) It's like...example: when you buy name brand and generic, not knowing, the name brand also produces the generic product...ford -Jaguar...I know,,, bad example, but you get the idea....
Sent from my SM-G386T using Bimmerfest mobile app
Old 06-16-2018, 05:28 PM
Solved a triad of death light issue (ABS, BRAKE, 4X4) with a 29 cent washer
Old 06-16-2018, 07:38 PM
Not1Clue's Avatar
Not1Clue Not1Clue is offline
Bluebirds fan in USA
Mein Auto: '05 X3 & '03 530i
Tried a cheap headlight restore. This stuff is $8/bottle. Seems to make a difference. Cheaper than buying new headlights and easier than those other kits where you're sanding, buffing, polishing, etc.
ID:	801834   Click image for larger version
ID:	801836   Click image for larger version
Old 06-16-2018, 07:40 PM
Not1Clue's Avatar
Not that I have this issue, but inquiring minds want to know......what and how....
Old 06-17-2018, 03:48 AM
See thread triad of death started by me...touch user name and then ď find all threads started by abscateĒ
After coffee Iíll stick link in my post
Old 06-17-2018, 03:55 AM
I mostly got the X buttoned up yesterday after replacing the tank and every hose (at least the ones I ordered :Banghead: ), but the store was out of distilled water. Had to take the Redneck Taxi on my 400 mile work commute, enjoying its commanding view of the road and its 15 mpg.
Old 06-17-2018, 05:59 AM
Cheaper, for sure, but letís see how long it lasts.
06 325i
99 BMW R1100RT
