E65 740i Misfire - Bimmerfest - BMW Forums
Old 06-11-2018, 06:41 PM
Blacky22 Blacky22 is offline
Mein Auto: 2007 BMW 740i sport
E65 740i Misfire
hi guys i have a misfire on multiple cylinders, it is usually possible to drive around it but hills will usually trigger it. the cylinders are not just confined to one bank.
i have tried new spark plugs, once removed there was no trace of oil on the plugs. i switched coils around and no change. one thing i have noticed is the severity of the misfire will change at certain fuel loads. once the misfire has occurred it will usually go away if the car is restarted. at its worst it will have the whole car rocking. has anyone experienced this in their 740i? and if so does anyone have a fix? any help would be greatly appreciated.
Old 06-11-2018, 06:56 PM
Dayfixer Dayfixer is offline
Mein Auto: 745li
Did you preform any work on the car or did the just random start doing this .?
Old 07-24-2018, 01:52 AM
bishopjeff1978 bishopjeff1978 is offline
CHAOS
Mein Auto: 2002 BMW 745I
Dude just fixed mine it took lots of trial and error but I have a 02 745i and turns out my crank case vent valves were toast u should start there and hey do your work on your car man the guy that assured prior said did u start just randomly fixing stuff or something to that effect yes that's how we learn our cars don't think you can't fix it cause u can boss
Old 07-24-2018, 01:08 PM
TxGr8White TxGr8White is offline
Sick Puppy Motorwerks
Mein Auto: BMW 850Ci
Just went through this on a friend's E65. Turns out the DME was damaged and that was causing random spark to the plugs. Have it scanned at either the dealership, or independent that has the proper equipment. Takes about 5 minutes to determine bad DME or not. Also note, this problem did not show any fault codes.
Mineral White Metallic 1993 850Ci
Alpine White III 2008 B7
740i, check engine light, misfire, multiple cylinders
