Chirp Noise - Bimmerfest - BMW Forums
Old 09-15-2019, 03:09 PM
Thechamp09 Thechamp09 is offline
Mein Auto:
Chirp Noise
Hello my fellow Bimmer folks. So I been having this annoying chirp noise coming from my driver side area on my 2005 BMW x3. I originally thought it was the belts and pulleys. Changed those out and the noise is still there. Thought it could be my brakes but I checked them and they look good. I have a video of the noise but I don't know how to post it.
Old 09-15-2019, 03:13 PM
BMWaufKS BMWaufKS is offline
Mein Auto: 2008 X3
The front driveshaft is just under the US-driver's side. Check its condition.
But could be a lot of other things -- we need a better description, and an audio recording might help a lot too.
Since 1/2016, restoring a
2008 BMW X3 M-Sport, N52, automatic ("#1")
Modifications:
All stock except dashcam
Since 3/2017, also restoring a
2008 BMW X3 base-model, N52, automatic ("#2")
Modifications:
Dashcam, cargo cover, cargo mat
Old 09-15-2019, 03:45 PM
Mein Auto:
Here's the video of the noise.
Old 09-15-2019, 05:10 PM
dukedkt442 dukedkt442 is offline
Location: Hudson Valley/LI, NY; Treasure Coast, FL; OBX, NC.
Mein Auto: X3, 442, S15, Silverado
Check the bolts holding the PS pump on; the ones on my E46 had backed out resulting in a chirping noise.
Old 09-15-2019, 06:14 PM
Mein Auto:
Ok I'll check those out.
Old 09-16-2019, 03:05 AM
abscate abscate is offline
Mein Auto: 2006 BMW X3... VOLVO... V
Noise at idle with vehicular stopped?
Noise when rolling?
Think about how you can isolate engine from other car noise and feed those test results back.
The PS pump on ours chirped at 120k until I did three series of ATF drain and fills
Old 09-16-2019, 04:49 AM
Mein Auto:
Noise happens when rolling. When I accelerate from a stop it'll chirp. After certain speeds the chirp goes away. I'm trying to upload the video but I'm having trouble.
Old 09-16-2019, 05:09 AM
Mein Auto:
Old 09-16-2019, 05:35 AM
Mein Auto: 2008 X3
Sounds normal, but may be overwhelmed by the wind noise, indicator, etc. A chipmunk sound at the very end?
Modifications:
Modifications:
Old 09-16-2019, 05:37 AM
Mein Auto: 2008 X3
But look for something dragging, or rubbing the driveshafts or halfshafts like a wiring harness.
Modifications:
Modifications:
Old 09-16-2019, 06:20 AM
BimmurBrothor's Avatar
BimmurBrothor BimmurBrothor is offline
BeeemerBro
Mein Auto: X3 M54 150k
Too much wind noise
Sent from my SM-G531H using Tapatalk
[FONT="Arial Black"]
Old 09-16-2019, 06:23 AM
HDTF614 HDTF614 is offline
Mein Auto: Camaro SS
I bet it is your driveshaft carrier bearing. Mine did the exact same thing. It will likely get louder as the temperature drops.
Old 09-16-2019, 07:11 AM
Mein Auto:
I will try to get a better video but yes it does sound like a chipmunk hahaha. Also the noise does seem more noticeable in the early mornings when it's a bit colder.
Old 09-16-2019, 08:02 AM
Mein Auto:
Is the drive shaft carrier bearing a separate part from the actual drive shaft?
Old 09-16-2019, 09:34 AM
Yes it is. You have to remove the driveshaft to replace it. Itís a common problem. Lots of diy write ups on how to do it.
Old 09-16-2019, 09:50 AM
Mein Auto: 2008 X3
Remember to mark, well, the DS's two parts' alignment before disassembling!
Modifications:
Modifications:
Old 09-17-2019, 08:46 PM
satyaban satyaban is offline
Mein Auto: 2008 328xi
This is just a shot in the dark but could a PCV do that? I have heard them make noises before of a high pitch.
