New gift - Bimmerfest - BMW Forums
Old 09-16-2019, 01:01 AM
Burning2nd's Avatar
Under the lift arms
Mein Auto: e39, e83, e60
New gift
front end,
struts and all the parts
all the control arms
complete tie rods
1,300$
the x3 is by far the most expensive bmw yet
think i did the whole e39 for 1400
and the e60 is cheap
Specializing In Breaking Things Professionally
15486372<-----
Old 09-16-2019, 04:13 AM
BMWaufKS BMWaufKS is offline
Mein Auto: 2008 X3
"New gift." For the car, or you?
If there's a significant other, new carpet in the house will be the real price ... :-)
Since 1/2016, restoring a
2008 BMW X3 M-Sport, N52, automatic ("#1")
Modifications:
All stock except dashcam
Since 3/2017, also restoring a
2008 BMW X3 base-model, N52, automatic ("#2")
Modifications:
Dashcam, cargo cover, cargo mat
Old 09-16-2019, 11:16 AM
kind16 kind16 is offline
Mein Auto: X3
Not quite understand what OP means.
2010 X3 28i Black, Engine N52B30 AT
(Millage Sep2019-112K km)
2015 Dodge Caravan, AT
(Millage Sep2019-30K km)
Old 09-16-2019, 11:37 AM
C-Bass C-Bass is offline
Mein Auto: 04 325i Touring/07 X3si
Originally Posted by Burning2nd View Post
front end,
complete tie rods
1,300$
I find the struts on the X3 very expensive compared to other medium/large vehicles I've owned before. Even the cheap stuff isn't all that cheap
Old 09-16-2019, 12:13 PM
Mein Auto: X3
e60 parts are very cheap? I should buy that car.
Old 09-16-2019, 01:47 PM
dukedkt442 dukedkt442 is online now
Location: Hudson Valley/LI, NY; Treasure Coast, FL; OBX, NC.
Mein Auto: X3, 442, S15, Silverado
If you want cheap you shouldn’t own a Euro car. Or a Ford.
Old 09-16-2019, 04:35 PM
Burning2nd's Avatar
Under the lift arms
its crazy thats 1300$ for just the front end.. and half of it is 2 struts..
266 a piece OWCH
yes last room in the house that has not had the carpet done yet
15486372<-----
Old 09-28-2019, 11:31 AM
Burning2nd's Avatar
Under the lift arms
easy job.. 3 hours.. all control arms and front struts, it was well over due, and really shot
i like that they left the articulating bolts behind.. so no alignment until i replace the tie rods
there is slotted upper strut holes 2
pretty easy
15486372<-----
Old 10-02-2019, 08:50 AM
really Ford?
In my experience they have been the cheapest cars I've owned to fix and run. I had a 2004 Focus and a 2002 Excursion
Old 10-02-2019, 09:28 AM
really Ford?
When maintained properly, yes Ford. My '04 F150 cost more in maintenance in 2 years than my X3 in 7. 4 hours for a proper plug job (needing to remove the PCM to gain access), $300 for a set of coils, $100 for plugs (every 60k). VAcuum IWEs that are horribly failure prone and cost $100, which can strip the bearing hub assemblies if not noticed for another $100 a piece. 3v and Ecoboost engines that need a full timing rebuild in as little as 30k miles to the tune of $1800 for the DIYer or $3500 at the dealer. Newer trucks require pulling the entire cab off the truck to address common issues. We've had a slew of expensive failures on the work trucks... our F450 has to have the cab pulled for the second time by only 45k miles because it swallowed an injector. Whenever I see a Ford pull up to my shop, the price goes up due to time involved. Motorcraft parts are outrageously overpriced, and those are the only parts worth using in a Ford.
Old 10-02-2019, 10:51 AM
Mein Auto: X3
pretty easy
I like to look at high mileage cars, one of your bimmer got 500K miles? I found the mileage in your garage.
Old 10-02-2019, 02:21 PM
Burning2nd's Avatar
Under the lift arms
I only do bmw here at the house, we have 3 (*i normally have 3)
i find that in comparison the e83 is more expensive then my others.. past and present: AND it is definitely "different" being assembled here in the states then the rest of the Germany made ones
i plan on bite'n off a e70 diesel sometime soon.
I just wanted to share some things.. 1300$ got me all 4 control arms, ball joints and complete struts (*tops and all new hardware) Fcp euro has a kit (*bs HDs)
if you dont touch the tie rods you dont need an alignment, the work is pretty easy
and yeah i sold the e30 a while back.. but it had liek 512k on it.. Im half way there with the 540, and the 550 is almost a quarter of the way
15486372<-----
Old 10-02-2019, 02:28 PM
Mein Auto: 2008 X3
FYI -- At least U.S. E83s were assembled in Austria.
Modifications:
Modifications:
Old 10-02-2019, 02:37 PM
Burning2nd's Avatar
Under the lift arms
stand corrected... then they just sucked at making the e83
15486372<-----
