Oil leak at front of engine! Help! - Bimmerfest - BMW Forums
Old 08-11-2019, 08:48 PM
BrokenBMWboi BrokenBMWboi is offline
Mein Auto:
I have a Oil leak on my 2000 528i. Just to the right of the cylinder head (from the front perspective). It's coming from a black tube that goes into the side of the cylinder head (see pictures).
ID:	860985   Click image for larger version
ID:	860987   Click image for larger version
Old 08-12-2019, 01:09 AM
Burning2nd's Avatar
Burning2nd Burning2nd is offline
Under the lift arms
Mein Auto: e39, e83, e60
cam sensor oring is leaking
m52 motor
right behind the vanos solenoid
Specializing In Breaking Things Professionally
15486372<-----
Old 08-12-2019, 06:52 AM
Mein Auto:
What cam sensor would that be? Intake or exhaust?
Old 08-12-2019, 08:26 AM
effduration effduration is offline
Mein Auto: '99 528i, '03 530i '06 X5
There are several possibilities in that specific area:
- I like Burning2 suggestion. It is the intake cam sensor that is located there.
- It also looks to me like the vanos oil line is weeping (very common) that is the black hose with pressure fittings of about 18 inches in length that is bolted to the vanos on top and the oil filter housing on bottom. Aftermarket vanos lines are cheap. Be sure to replace all 4 crush washers when you replace it.
If you want to find out for sure. clean the area with brake cleaner and watch it.
Also your CCV pipe (plastic pipe going into valve cover) looks a little tired - time to replace whole CCV system?
Old 08-12-2019, 10:11 AM
Mein Auto:
Okay thank you! Do you know if there are kits I can buy that are just replacement gaskets for the cam sensor? Or do I have to buy a new one?
Old 08-12-2019, 11:00 AM
bmw blue's Avatar
bmw blue bmw blue is offline
Mein Auto: 2000 BMW 528i Steptronic
With the simplest of Google searches, you will find this.
https://www.google.com/search?source...4dUDCAs&uact=5
Then write the part # down, CRP products are sold at the AutoZone near me at least, and they can order it for you.
I have gotten CRP o'rings from them when I needed and did not want to order it online or go to the dealership and pay 5 times what I needed to.
Beisan Vanos Repair, EMP Stewart Water Pump, Aluminum Water Pump Pulley, Behr Electric Fan, Sachs Fan clutch,
18pc Lemforder Suspension Kit w/Koni Sports+H&R Springs,
E46 Intake Boot W/AFE Dry Air Filter, Conforti Shark Injector,
Liqui Moly Leichtlauf High Tech 5W40 Motor Oil, Pentosin Full Synthetic Transmission Fluid and 75-90 Motul Full Synthetic Differential Oil.
Michelin Pilot Sports (summer), Continental DWS (winter).
190,500 miles and counting.
Old 08-12-2019, 11:15 AM
Ridin'Dirty's Avatar
Ridin'Dirty Ridin'Dirty is offline
'17 X1 - Rooster Cruisin'
Mein Auto: '93 "Beemer" R100r
I just took a shot (based on the limited info you provided about you car) at RealOEM to look at/for that O-ring for the cam sensor and came up with this (part#6):
https://www.realoem.com/bmw/enUS/sho...diagId=11_7521
If it is correct for your particular motor, it's available from this vendor:
https://www.fcpeuro.com/products/bmw...or-12141748398
If you can't fix it, you don't own it.
