Backup lights - Bimmerfest - BMW Forums
Old 08-15-2019, 12:21 AM
Edvinac Edvinac is offline
Mein Auto: BMW 523i e39 manual
Backup lights
Hey guys. Bmw e39 523i manual. Trying to diagnose why my back up lights dont want to turn on, on reverse. Just did a clutch job, thought the sensor might be the culprit, but after I shorted the connector to the sensor, still, no backup lights. The bulbs are good. They're just a weird design, because no wires going to the bulb socket. By the way, no code on the dash.
1. Any ideas?
2.Also, do the reverse lights work on second key position with reverse gear? Or should I continue testing while the car is running?
3. Maybe I should try bending out the contacts on the bulb socket?
4. How much voltage from LCM comes to the gearbox switch connector? I get about 1.5-2Volts.
Old 08-15-2019, 06:11 AM
JimLev JimLev is offline
https://www.bimmerforums.com/forum/s...-Backup-lights
Old 08-16-2019, 12:48 AM
Up
Old 08-16-2019, 10:35 AM
Solved. Went at it again with some testing and the connector at the gearbox today showed 0V on second key position(before it showed up as 2V, weirdly) and it was more clear this time. Turned out to be one broken wire to the connector near the flywheel.
