Zf5hp19 (p0741 code) help - Bimmerfest - BMW Forums
Old 08-15-2019, 09:27 PM
Ianfl Ianfl is online now
Mein Auto:
So I just bought a 2002 bmw 530i with 161k miles sr trans. After driving 200ish miles (mostly on the highway) SES light came on. Stopped at autozone (p0741) and proceeded to drive 60+ miles with no shifting issues at all. (also rpm on highway is around 2500-2700) Then light came back on. If it was the torque converter wouldn’t the rpm be higher at highway speeds? No shifting problems so what do you think? I’m not sure on transmission service history but to my knowledge the fluid has never been flushed and no new filter. Could this be causing the code since it seems to be driving fine?
Sent from my iPhone using Bimmerfest mobile app
Old 08-15-2019, 09:31 PM
edjack edjack is offline
Mein Auto: '97 540i 6 speed
Define that code, and where are you located?
We don't memorize the codes.
Old 08-15-2019, 09:37 PM
Mein Auto:
P0741-Torque converter Clutch solenoid Circuit performance or stuck off
Mein Auto:
Located in Dayton Ohio.
Old 08-16-2019, 02:27 AM
Chedley Chedley is offline
Mein Auto: 2001 E39 540i
No, the transmission service -or lack of- should not cause the error you are having. Though, given the age of your car, it is a very good idea to do a full transmission service: replace the transmission filter, fluid and pan gasket, screws and plugs.
But how is your battery and alternator ?? I'd check and test it first. A weak or discharged battery/alternator is known to cause many sporadic errors on the ZF tranny.
<=E39=>
Old 08-16-2019, 07:33 AM
Mein Auto:
I went out and accessed the voltmeter on the dash and it was around 13v with nothing on. Turned high beams, wipers and rear defroster. 13.5v doesn’t seem to be alternator? Or am I missing something?
Old 08-16-2019, 03:39 PM
mattmar1's Avatar
mattmar1 mattmar1 is offline
Wingnut
Mein Auto: 1999 5281 5 sp msport
at idle or a higher rpm? the OBC voltage tends to run around .3vdc lower than actual. id say it looks ok.
99 528i 5sp sport
be alert...the world needs more lerts
