BMW E65 730D - lack of power on launch - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > The Best of Bimmerfest! > BMW Diesel Owners & Enthusiasts
Old 06-20-2020, 12:50 AM
Nick1992 Nick1992 is offline
Mein Auto:
Hi guys and excuse me for having a problem question as my first post here!
My E65 2002 diesel has an issue with accelerating on launch. There are no problems when I am already driving like 20km/h and pushing accelerator down to the end - the turbo starts over 2000 rpm and the car accelerates very well.
But when I am just going to start the drive from 0 km/h and pushing accelerator, it wont go over 1000 rpm until the car is not in move - drives several meters and achieves like 10-20 km/h speed.
The same applies when trying to launch the car. E.g. I have my left foot on brake and pushin accelerator with my right foot - the RPM will not go over 1000.
Guyz, any ideas? What can be the issue here? Has anyone had this problem?
Thank you all for ya answer!
Old 06-20-2020, 06:09 PM
smokeyyy smokeyyy is offline
Mein Auto: bmw 14 535d, 12 528i
Any codes?
Old 06-20-2020, 11:59 PM
Mein Auto:
smokey, no codes, no check engine light, no MAF issue. I am thinking of injectors, may it be realistic?
Old 06-28-2020, 07:30 PM
do you have a reader that could read BMW codes?
Old 06-29-2020, 04:06 AM
Doug Huffman's Avatar
Nuclear engineer
No, not likely injectors.
When you hear hoofbeats think horses, not Equus quagga just because it sounds high-tech and mysterious.
I believe that Launch Control is an option not often implemented in diesel. Brake pedal defeat of throttle pedal is usual.
No mention of Launch Control here
https://www.newtis.info/tisv2/a/en/e...earch?q=launch
Old 06-29-2020, 10:02 PM
ard ard is offline
Resident Curmudgeon
Has it always been like this for the last X years or something that has developed?
OEM is not what BMW sells
Old 06-30-2020, 01:04 PM
Mein Auto:
Thank you all for your answers!
No, it has developed. Like 2 months ago it had no such problem. I've identified it when I was trying to drive over a small barrier - the front wheel was touching a barrier like 20cm height and I could not overcome since rpm was not moving over 1000 and the car had not enough power. I had to go back like half a meter and try again with innertion.
