Exhaust Valve Rattle - Bimmerfest - BMW Forums
Old 03-11-2020, 11:38 AM
kylime kylime is offline
Mein Auto: E21 E30 E46 E84
Exhaust valve rattles when engine on. Has anyone encounter this issue?
Old 03-16-2020, 08:42 AM
JimH46 JimH46 is offline
Mein Auto: 2014 X1 xDrive28i
Are you sure it's not the valve chain? I would have it checked out ASAP as this could result in complete engine failure.
Old 04-07-2020, 02:08 PM
wvadam wvadam is offline
Mein Auto: X1 2.0L xdrive
Are you talking about the valve on the muffler itself? I noticed mine rattles every time I start the car but not after that. Still annoying and I would like to fix a well.
2012 X1 28ix owned since 2017
repairs done to date: ZF8 fluid and filter/pan, transfer case fluid, oil level sensor, alternator clutch stuck on, front brakes, front control arm hydraulic bushings, rear lower ball-joint.
Old 04-09-2020, 09:13 AM
Yukoner Yukoner is offline
Mein Auto: 2011 328i x-drive
I have the same rattle when the X1 starts up. In order to fix it, you need to replace the muffler. $1,200.00 dealer part. I have yet to find one available anywhere outside the dealer. I was told by the dealer that it's completely "cosmetic", it has no impact on engine operation or anything like that.
I'm not a cheap-o when it comes to maintenance, not by any means (search my previous posts if you don't believe me). But..... yeah...... I'm not replacing this anytime soon.
Not even sure if -40 degrees is cold anymore ?
Old 04-10-2020, 01:46 PM
BMWBig6 BMWBig6 is offline
Mein Auto: BMW X1 sDrive28i M Sport
I wanna say our X1 has done this since day 1, when we picked it up brand new. I'd hate to spend $1,200 + labor only to learn it makes the same rattle on startup.
2015 BMW X1 sDrive28i M Sport / 2015 Porsche Boxster GTS / 2019 Mercedes-Benz E450 4Matic Wagon
Favorite Former Rides: 11 Ford F-150 Limited | 09 Audi A4 S-Line Avant | 08 Audi TT S-Line / 03 Ford SVT Lightning / 01 Ford SVT Lightning / 93 BMW 740iL / 90 BMW 535iM / 86 Porsche 944 Turbo / 83 Porsche 944
Old 04-10-2020, 02:14 PM
I am really wondering if it is something we can just delete, disable, remove, or just lock open. How much does it really do? I wouldn't even have known about it if I didn't look into the muffler itself. It sounds like it might be a bit of BMW over-engineering or satisfying some marketing trickery that really doesn't affect me.
Old 05-16-2020, 02:52 PM
yes. the valve on the muffler.
