1970 2002 Need help with fuel line - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > Classic Bimmers
Classic Bimmers
Discussions pertaining to vintage and classic BMW models here...
Old 05-19-2019, 01:40 PM
Max Power! Max Power! is offline
Mein Auto: 1970 2002
I've taken over a restoration project on a 1970 B.M.W. 2002. The owner has installed a rubber fuel line that runs from the tank, through the rear package tray, and along the floor, on the INSIDE of the car. It goes out through the firewall, by the heater core, and then to the carburetor. This cant be correct! I've gotten little info from the dealer, and I've checked several websites/videos and found no info. I did find a few pics, but just of the end of a metal line, sticking out under the brake booster. Does anyone have any thoughts or pics of the factory fuel line under the car?
Name:	BMW 2002 fuel line b.jpg
Old 05-20-2019, 04:14 PM
M2Pilot M2Pilot is offline
Mein Auto: '16 M3,'98 M3, '76 M2
I believe what you have is correct. The line should be plastic,not rubber. Try Bluntech for replacement.
Old 05-22-2019, 09:29 AM
1970 2002 fuel line
Thanks I did find a coiled line that looked like a plastic line. i even found the grommets for the line that the dealer couldn't find!
2002, fuel hose, fuel line, metal fuel line, rubber fuel line
Similar Threads
Where do we find the list of all E39 transmission, airbag, abs & obd BMW error codes? arthurwood E39 (1997 - 2003) 21 12-08-2017 05:39 PM
BMW Fault Codes OBD,DTC igor2009 BMW Coding and Programming 0 02-12-2015 10:46 AM
Errors in INPA gmcclintock 7 Series - E65 / E66 (2002 - 2008) 11 02-08-2013 08:12 PM
Fuel filter compatibility question. Rick Lee E36 (1991 - 1999) 3 04-16-2007 08:48 AM
