Whistling noise from wind at ~40 MPH? - Bimmerfest - BMW Forums
Old 02-10-2020, 07:17 AM
Nerdboss Nerdboss is offline
Mein Auto: 2015 X3 35i
I have a very annoying noise in my F10 when driving around 40 MPH in town. I thought maybe it was just the cold dense air, but now I'm not sure. It sounds like it's coming from the windshield area but I'm not sure. Has anyone else experienced this issue with their f10? Any known areas for wind noise on this model?
2016 535i | M Sport | Cold Weather Package | Driver Assistance Package | Premium Package | Driver Assistance Plus Package | Multi-Contour Seats | Dynamic Handling Package | Harmon Kardon Audio | Carbon Black Metallic | Ivory White Nappa
2005 530i | Jet Black | Sport Package | Heads up display | Adaptive Xenon | Navigation | Rear Sunshade
Old 02-10-2020, 09:57 AM
ezaircon4jc's Avatar
ezaircon4jc ezaircon4jc is offline
Mein Auto: 2014 535i M Sport
The usual suspects are wipers (no kidding), mirrors, slightly open window or moonroof and failing windshield seal.
Mike
2014 535i M Sport, Carbon Black/Black (mine)
2012 535i, Dark Graphite II/Oyster (wife's)
Joshua 24:15; Phil 4:13
https://www.newtis.info/tisv2/a/en/f10-535i-lim/
Old 02-10-2020, 11:03 AM
It may have started after I adjusted the wiper position. The drivers side wiper was down quite a ways so when it wiped, it was very far from the edge.
Is a failing windshield seal common on the F10?
Old 02-10-2020, 12:21 PM
I wouldn't say so. It is usually caused by a poor windshield install. I've had it happen, but it usually manifests itself pretty quickly.
My guess is the wiper arm. They will whistle like a train!
Mike
Old 02-10-2020, 05:13 PM
Hmm, I need to see if I can find out the normal wiper position for the F10. Not sure at what position it's supposed to be mounted.
Old 02-11-2020, 07:27 AM
bmrboy2008's Avatar
bmrboy2008 bmrboy2008 is offline
Nerdboss - I have been experiencing the same whistle that seems to be coming from the front dash when I reach 40 mph for months now. The dealer nor my indy can identify the cause. Keep us posted when you find the solution.
Thanks.
2014 535i M-Sport, Jet Black, Black Dakota Leather, Premium Package, Lighting Package, Multi-Contour Seats, M-Sport Suspension, Navigation, Harmon Kardon Stereo, 3M Tint
2008 528i Sport - Retired
2008 535i Sport - BMW Buy Back
2004 525i Sport - RIP
Old 02-13-2020, 11:51 AM
Thanks.
I'm also still trying to find the cause. =(
If I find the solution I'll post it.
Old 02-13-2020, 12:07 PM
nedmon nedmon is offline
Mein Auto: 2015 535, 2016 X3
Close drivers door and then seal between door and frame with masking tape.
Get in via the passenger's door and drive around. If the whistle is gone, it's door related.
If the noise is still there, remove the wiper assembly and repeat.
Next up is the windshield seal. More masking tape
Ned,
2016 X3
15 535i x Drive
Old 02-13-2020, 01:03 PM
Think 3m painters tape would work?
If it's one of the seals, do you think it would be covered under warranty? I have one month left of the factory bumper to bumper.
Old 02-13-2020, 03:37 PM
I masked everything off and no go. I think itís coming from the sunroof, perhaps the sunroof drains are whistling? Where do they drain at?
Old 02-13-2020, 05:36 PM
Open the sunroof and using a glass of water and a straw, suck a mouthfull and squirt it down each corner, there are 4 drain tubes.
Look under the car and you will see it dripping. fronts inside the back of the front wheels and the back just about inside the jack points
Ned,
2016 X3
15 535i x Drive
Old 02-13-2020, 05:43 PM
after reading your post, yes you can could mask off the 2 front drain holes from the sunroof seat but not the back ones, of course it would be better to completely mask off the gap between the glass and the body and see what happens
Did you pop the wiper?
Its not clear to me how the mirror would make the noise though.
If the car is in warranty, have BMW fix it.
Ned,
2016 X3
15 535i x Drive
Old 02-14-2020, 06:48 AM
I'm not sure BMW would be able to fix it. I'm wondering if it started because of the really dense air outside. It's 17 outside right now in Oklahoma. I masked off the gaps in the mirrors, the top of the windshield where it meets the roof, the lower cowling, and I raised the wipers into the service position and drove that way. No changes. I notice the noise is louder with the sunroof open, so I think the whistling noise may be coming from there.
I may have BMW take a look, do you think they'd look at it under warranty just for that issue? Again, if I can't figure it out im not sure if they can.
Old 02-14-2020, 10:29 AM
Another simple check. I noticed my sunroof creaking at times when it's "cold" outside. I lubricated the trim and the edge of the sunroof I could reach with the roof open and creak gone. Maybe through some trim conditioner on that area and see what that does. I used 303 Aerospace Protectant.
Mike
Old 02-14-2020, 01:22 PM
Mine isn't creaking. The outside whisting noise is louder with the roof open. I can hear it quite well when I have the roof open and I hold the wind deflector down with my hand while driving. Its driving me mad, maybe its just the cold dense air? I know the dealer isn't going to be much help.
My 15 year old E60 530i has no wind noise. I'm starting to think the E60 was a better built car. =(
Old 02-14-2020, 07:53 PM
I was more or less equating a creak with a leak.
Mike
Old 02-20-2020, 10:39 AM
bmrboy2008's Avatar
Nerdboss:
Any further info or a possible solution? My car is still whistling away.
Thanks.
Old 02-20-2020, 10:55 PM
MunichMark MunichMark is offline
Munich Mark - 2014 535XD
Mein Auto: 2014 535XD (German Model)
#1 place that I have seen is the window seals at the base of the windows where it meets the doors. With Windows down you can press this trim inwards to help close up any gaps. Taping off as well should prove the point but the very best way to Effectively measure is with a Noise Measuring dB device, yes there are apps now for your smart phone, not so accurate but good enough to measure differences and frequencies.
Regards,
MunichMark
2014 535XD LCI
Euro 313HP
465 TQ @1500 RPM
Alpinweiss - Nappa Mocca
AC Schnitzer 30-30 Springs
18" Michelin Pilot Supersport / PA4 Winter
Old 02-21-2020, 06:52 AM
Nerdboss:
Thanks.
Not yet. Seems to be tied to very cold weather. I'm in Oklahoma and it's in the low 20s right now. Once it's like in the 50s outside, there is no wind noise. I'm guessing the cold dense and dry air is more prone to making noise. I checked all seals and they're fine. Idk what could be the cause.
