emergency call failure - Page 2 - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 6 Series > F06 Gran Coupe (2013 - 2018)
BMW's entrance into the 4 door coupe segment to go head to head with the Audi A7 and MB CLS
Old 09-09-2019, 05:00 AM
alboko178 alboko178 is offline
Mein Auto: 2016 640i GC
I started getting intermittent SOS warnings after a few of days of getting the car (I'm a second owner). Then I have updated the software to the latest from https://www.bmw.com/content/bmw/mark...e-updates.html and haven't seen the warnings since.
I also emailed my service adviser and got the following respond:
The emergency call malfunction could be coming on if the dealer you purchased it from did not contact BMW to let them know you are the new owner. You can try pressing that SOS button in the car and when they answer just let them know what you are seeing and they should be able to help you. If not and they say the car needs to be looked at then we can schedule you in and take a look.
You may try that as well.
Old 02-03-2020, 01:51 PM
mparikh mparikh is offline
FOBManny
Mein Auto: '14 BMW M5
I have the same issue in my '14 M5. Over the weekend the "SOS Service Malfunction" warning came on. I took it into the dealer today (charged me $100 just for the diagnostics) and they told me the TCB needs to be replaced. I am finding the part 84109297787 online for about $27. Does anyone have any videos or instructions on how to replace it as a DIY task. Or is this something that I have to take to a mechanic?
Old 02-03-2020, 02:01 PM
DBU's Avatar
DBU DBU is offline
Mein Auto: Glacier Silver X4 M40i
I had a similar warning and it turned out to be a simple battery replacement. There is a small battery in the unit (TCB??) in the trunk - left-hand side. The black plastic cover slides off in the direction of the arrows and there is the battery. No need to remove the unit (all assuming this is in fact your problem). Good luck.
His: 2017 X4 M40i - Glacier Silver with all the options (except cold weather stuff) - not needed in SoCal
Hers: 2015 X4 28i - Glacier Silver - loaded M-Sport
Old 02-03-2020, 04:25 PM
FOBManny
Well, I was actually told that it was a 2 hour labor job and that they would have to remove part the roof or ceiling or something. I'll try to get more accurate description from the dealer.
Old 02-03-2020, 04:48 PM
BabyUnicornTaco BabyUnicornTaco is offline
Mein Auto: 2008 X5 4.8i E70 Sport
SOS issues in the past have sometimes been solved by deleting all paired Bluetooth devices and then reinstalling. Different BMW but worth a try. Worked for me.
2008 X5 E70 4.8i M-Sport
2008 550i RPI Exhaust, RPI Ram Air
Old 02-03-2020, 05:04 PM
FOBManny
when I go pick up my car from the dealer tomorrow, I will try out all of the above mentioned solutions. I can't believe I freaking paid $100 for them to do a diagnostic test. What an idiot I am
Old 02-03-2020, 05:11 PM
A low battery after a few short drive startups causes random faults. One headlight not working, SOS failure, etc. keep that in mind.
