Getting an ignition +12v wire at the rearview mirror - Bimmerfest - BMW Forums
Old 10-27-2014, 02:13 PM
Brandon540/6M Brandon540/6M is offline
Mein Auto: 03 540-6 speed
Trying to hook up a dash cam and wiring it in somewhere up by the map lights / sunroof switch panel. EDIT: Found my problem was my own fault - use the green / white wire for +12v and the brown for ground. Just make sure you check the wires you tapped into twice to make sure you got the right ones
03 540 6-speed
Dinan exhaust, short shifter, sway bars, so far...
Old 10-27-2014, 02:46 PM
JKRIT JKRIT is offline
Mein Auto: '03 525i
I always use the green/white wire up there for a radar detector. Its unfortunate if that doesn't provide enough current for your purposes.
'12 328i Cab Deep Sea Blu/Tan
'03 525i Sapphire Blu/Grey, SP, Nav
'03 530i Sterling Gray/Blk, SP
'02 325it Orient Blu/Grey, SP, Nav
Old 10-27-2014, 03:17 PM
Typing /radar detector f3 in the bestlinks nets this.
- Adding new fuses & wiring in the engine bay (1) & all about the BMW Glovebox Flashlight Cigarette Lighter Power Adapter (1) (2) (3) & how to install a Valentine or Escort radar detector (1) (2)
Old 10-27-2014, 10:01 PM
Ok, I'm embarrassed to admit, i somehow snagged the wrong ground wire and got the illumination wire instead of ground. DUR, that's what I get for wiring in the dark and using my cell phone flashlight for light. Wow, well looks like green / white is still the wire to use, and BROWN is the proper ground
By the way bluebee, I was originally searching for that part you listed (BMW Glovebox Flashlight Cigarette Lighter Power Adapter) a few weeks ago and that part is discontinued. Couldn't find it anywhere!
03 540 6-speed
