Curious, how many of you... - Bimmerfest - BMW Forums
Old 07-15-2003, 06:22 PM
///M Rakete's Avatar
///M Rakete ///M Rakete is offline
Rocket Scientist
Mein Auto: 2010 M3 and 2011 135i
...have your engine oil drain plug access cover missing from the plastic undertray on the S54? Me thinks my dealer either didn't put it back or did so improperly causing it to be lost.
2015 BMW M5 Sedan w/Competition Package and Carbon Ceramic Brakes, Alpine White / Sakhir Orange Extended, and a Trunk Monkey known as "Der Stig",
plus the daily driver...
2017 RAM 1500 Rebel Crew Cab, Granite Gray.
Old 07-15-2003, 06:30 PM
scottn2retro's Avatar
scottn2retro scottn2retro is offline
into things retro
Mein Auto: '02 M3 SMG & '08 135i
Last I checked, still had mine (after 2 dealer oil changes).
facebook.com/sctsracing
02 M3 SMG Coupe - prepared class BMW Club racer
08 135i 6sp - stock class BMW Club racer
Photo gallery
Old 07-15-2003, 07:42 PM
DannO's Avatar
DannO DannO is offline
Mein Auto: //M Coupes
Some of the guys at work noticed mine sitting in my parking place when I left for lunch a week or two ago. Just fell off, I guess. Bizarre. I'll put it back on the next time I'm under it.
Old 07-15-2003, 07:56 PM
elfhearse's Avatar
elfhearse elfhearse is offline
Mein Auto: 00Z3MC,10e91-ZMP,14e8928i
That's parts ok but one of my S52 engine cover access "plugs" popped off ( the black background with silver lines). I changed the plugs recently and the tab must have failed because I reinstalled it correctly.
(I did happen after I had to walk a WRX that was up my butt on the Interstate. They may be fast off the line but over 70mph, you downshift and start to pull away....... )
Old 07-15-2003, 08:28 PM
Ron Stygar's Avatar
19,585 Miles
Mine never fell off.
It's off now, sitting in my spare room, because I removed it with the underbody panel.
Old 07-15-2003, 08:37 PM
Rocket Scientist
Ron, why did you remove the panel? Better cooling?
Old 07-15-2003, 08:53 PM
Ron Stygar's Avatar
19,585 Miles
It was a pain to remove (more of a pain to install) when working on the car. Less weight. 11 or so pounds if I remember weight. My remember rights are not as accurate as I get older.
I assume that it was added when they raised the speed limiter from 137 to 155. I believe that all of the Euro M coupes had it.
My car does run cool. 190 > 205 oil temperature. A hot day doesn't seem to matter.
I also run the aux. fan at low speed automatically for up to 30 minutes on shut down depending on engine run time. Can also run it on demand. I'm doing this using one of John Firestones mini controllers.
Old 07-15-2003, 09:05 PM
Rocket Scientist
Yeah, it looked pretty thick (good, not flimsy) when I was underneath today checking (ran over some freeway debris/scrap/body part) and noticed the access panel was history. Whatever it was made the slightest scrape mark only to be run over by the next person behind me.
Anymore observations on the Injector?
Old 07-15-2003, 09:15 PM
Ron Stygar's Avatar
19,585 Miles
Right now, I'm running it with sport mode disabled on start up using another one of John's mini controllers.
John sent me a new main controller Tuesday with a data logger mode.
Once it and my lap top arrives, I will be doing some checks.
Will also be doing some OBDII checks using the software and cable I purchased from: http://obd-2.com/
Old 08-15-2003, 07:35 AM
Rocket Scientist
That S54 engine/transmission undertray served its purpose yet again this morning. Another piece of debris/scrap/body part deflected.
BMW might have thought it was for aerodynamics but where I live it's more like body armor.
Old 08-15-2003, 08:23 AM
JonM's Avatar
JonM JonM is offline
Moderator
Mein Auto: 01 Mc, 08 M3, Motorrad x2
Mine came off. Ordered a new one and it looks like an updated part.
Jon Maddux
16 X5d | 08 E90 M3 | 06 M Coupe | 01 M coupe | 99 M coupe
http://coupenut.blogspot.com/
http://x5nut.blogspot.com/
Old 08-15-2003, 09:24 AM
Rocket Scientist
My replacement cover just came in at the dealer.
Maybe the foam makes for a tighter fit which will keep the cover in place? Doesn't seem likely it is to keep the undertray from deflecting up. Anyway there's no way I'm taking mine off with all the crap littering the freeway.
Any update on the spare tire kits? (I realize you're getting ready for HC.)
Old 08-15-2003, 09:29 AM
AndyM's Avatar
AndyM AndyM is offline
Suede Master
Mein Auto: '02 3.0i Z3 Coupe
The covers should be in my hand any day now. Getting a bit tired of waiting.
