Can you plug or patch run flats? - Bimmerfest - BMW Forums
Old 12-03-2015, 03:52 AM
12 Handicap 12 Handicap is offline
Mein Auto: 2013 X1- Midnight Blue
What would happen in a pinch? 2000 mi. brand new effing tires and the L.F. light came on.
Old 12-03-2015, 04:06 AM
MRCW MRCW is offline
Mein Auto: Cars and trucks and boats
Go to and independent tire shop. .. The big b scare with RFT repair is if it ever really went flat and you actually drove on it. ..
I successfully had plugged two nail holes in my RFT's and put over 15000 more miles on them before they wore out and I could replace with non RFT's
2013 X1 3.5i MSport
2006 530xi Touring (gone)
2002 X5 4.6is (gone)
1995 525xit (gone)
Old 12-03-2015, 10:57 AM
bmw_again bmw_again is offline
Mein Auto: 2001 325i manual
Depends on the tire brand and on the shop. What brand do you have? Several of the manufacturers have language that they "don't recommend repair", correspondingly many shops would not do it because of liability concerns. For instance Discount tire won't repair Pirellis.
Also, in some cases there is short term road hazard warranty with the tire. Again example with Pirelli - 1 year or within the first 2/32 of the thread free replacement, then prorated.
Old 12-03-2015, 01:32 PM
SilverX3's Avatar
SilverX3 SilverX3 is offline
Mein Auto: 130i & E92 325i, E90 SOLD
Plug is illegal in some countries like Asutralia
Residence - StarTrek Enterprise
Job - Captain
Current Starship Fleet:
06 130i - ROCK SOLID Performer
MY11.5 X1 Xdrive25i
2013 VW Golf R - Rising Metallic Blue
Old 12-03-2015, 07:31 PM
They are Conti's. I have a plug kit. Or should it be patched?
Old 12-04-2015, 12:03 PM
I think Continental is free replacement (first year/first 2/32 wear). Check your particular one on tirerack, they usually list all the warranties. You have only 2k miles, try to get a new tire. The dealer most likely will tell you there is no such thing, so I go to one of the big tire retailers.
Old 12-04-2015, 12:44 PM
hd333 hd333 is offline
Mein Auto: A JEEP! My wife '13 328x
My wife's Conti RF's were plugged last week. At least we can buy some time before we buy 4 new ones now.
Old 12-04-2015, 02:16 PM
Believe me when these wear out ,no more run flats for me. The ride sucks compared to most tires and I will keep a plug kit and compressor on board should I need it.
Old 12-04-2015, 06:43 PM
outlawdevil outlawdevil is offline
Mein Auto: 2 Legs
My bro patched his nail hole in 500 miles, it is just too new to get a new one. Tire shop didn't give him any problem.
Old 12-05-2015, 07:48 AM
JimH46 JimH46 is offline
Mein Auto: 2014 X1 xDrive28i
Did you check the tire pressure? It could just be an issue with the tire pressure warning system. Tires gradually loose pressure over time and if you've had some cold weather, that will lower it further. May only need pumping to proper pressure and resetting the warning system.
Old 12-06-2015, 06:32 AM
Nice shiny screw head looking at me.
Old 12-06-2015, 06:59 AM
OK. If you did not drive with the tire flat but just a bit low on pressure, you should be able to patch it. A plug is only temporary. Proper repair is to take the tire off the wheel and apply a patch to the inside.
Old 12-06-2015, 09:43 PM
vstolpner vstolpner is offline
Northern BMW Fan
Mein Auto: 2013 BMW X1 xdrive28i
Or you can use a plug that's meant to be inserted from the outside....
Search pocket plug repair on Amazon
Old 12-07-2015, 05:15 AM
Not recommended. Read this.
http://www.tirerack.com/tires/tirete....jsp?techid=77
Old 12-07-2015, 08:41 AM
Northern BMW Fan
Originally Posted by JimH46 View Post
Haven't seen that before, thanks for letting me know. I'll have to keep it in mind when I get a flat.
Old 12-07-2015, 11:02 AM
Why don't you try to get a new tire? You said all of your tires are practically new, so there are no issues with different threads remaining.
Old 08-21-2016, 01:53 AM
luigi524td luigi524td is offline
Mein Auto: '17 540xDrive; '98 Z3 2.8
Exclamation OLD POST BUT WORTH MENTIONING - Manufacturer's Road Hazard Warranty
OLD POST BUT WORTH A REPLY FOR THE BENEFIT OF OTHERS!
Depending on brand and tire ... your BMW dealer is not a tire store but can handle tire manufacturer tire warranties ... Story similar to yours - I had 2 Conti RFTs replaced with new at no cost to me (incl mounting and re-balancing!) in separate incidents after punctures - one by nail - one by screw ... both in outer tread section. the kind of puncture that most reputable tire shops should not repair even in a conventional tire.
SOooooo investigate your tire manufacturer warranty - you might be in for a pleasant surprise!
My opinions are free - you'll get exactly what you pay for!
Current: '17 540 xDrive | '13 X1 MSport | '98 Z3 2.8
Past: '13 535xDrive|'07 530xi|'01 740i|'98 740i|'94 740i |'86 524TD
"Seek and ye shall find" - start with your owner's manual!
Click on the MrRebates logo/link for cash back savings at on-line stores like Tirerack!Mr. Rebates
Old 08-21-2016, 11:33 AM
Doug Huffman's Avatar
Doug Huffman Doug Huffman is offline
Nuclear engineer
Location: Washington Island, Wisconsin, thru Death's Door
Mein Auto: CPO2012 X5 35d M57(E70)
There is more profit is selling tires than repairing them. Find a shop that services customers' tires.
Scepticism and Animal Faith (1923)
Scepticism is the chastity of the intellect, and it is shameful to surrender it too soon or to the first comer: there is nobility in preserving it coolly and proudly through long youth, until at last, in the ripeness of instinct and discretion, it can be safely exchanged for fidelity and happiness.
(The Works of George Santayana p. 65)
Eschew eristical argumentation. I am responsible for what I write, not for your understanding of it.
Old 08-21-2016, 04:42 PM
SilverX3's Avatar
1. get a plug kit : easy to DIY
2. if nail in in the safe zone of the tire, you can repair but have to go to little shop. Large tire shop won't repair as they prefer to sell you a new tire
Job - Captain
MY11.5 X1 Xdrive25i
Old 08-23-2016, 05:32 AM
themishmosh themishmosh is offline
Mein Auto: X1 XDrive35i
I've tried two plug kits: dynaplug and the old slime kits. The Dynaplug was expensive and hugely disappointing. Never sealed the hole which was a nail puncture. The slime kit seemingly did the job but had a slow leak that caused a flat tire overnight. There is no replacement for a tire guy putting in a plug/patch on the inside. I do carry the slime kit in all my cars now with an air compressor because I do think it's easy to use and can get you out of a pickle at least temporarily.
