water leak SOLVED - Bimmerfest - BMW Forums
The X5 SAV Forum
Old 06-06-2019, 03:59 PM
Loperamide Loperamide is offline
Mein Auto: BMW X5 4.4i 2003
water leak SOLVED
Passenger side (UK) floor mat getting water on it via wet glove box.
What could be the cause?
2003 X5 4.4i
Old 06-07-2019, 12:57 PM
Fifty150hs Fifty150hs is offline
Mein Auto: SF Bay Area
If you have the panorama roof it is likely a clogged drain from that.
Old 06-07-2019, 05:23 PM
its not panorama, just a normal sunroof.
2003 X5 4.4i
Old 06-07-2019, 05:43 PM
According to this you have a drain on that type of roof as well. Right front. https://www.realoem.com/bmw/enUS/sho...diagId=54_0262
Old 06-08-2019, 03:40 PM
water leak SOLVED
So i fixed the leak. The rubber pipe came off of the sunroof drain above the headliner so i super glued it back on to prevent it coming off again in future
2003 X5 4.4i
Old 06-08-2019, 04:09 PM
Doug Huffman's Avatar
Nuclear engineer
There are four, left & right, front & rear.
Old 06-08-2019, 04:39 PM
The others aren't leaking. I will cross that bridge when I come to it
2003 X5 4.4i
Old 06-17-2019, 08:21 AM
CVX20 CVX20 is offline
Mein Auto: E53 X5,Hemi Ram
Just went through the same thing with my 02 with a normal sunroof.Both tubes were kinked in half part way down the A pillar.Looked like it was done intentionally.Tubes weren't in the holder and you would need to pull up 2 to 3 inched of tube from the pass through tubes in the dash to fold them in half.Not happy as my carpets are soaked now.
